Author Topic: Roden 1/48th Bristol F2.B  (Read 8350 times)
Offline NinetythirdLiberator
« on: April 30, 2012, 03:23:01 PM »
Hi Everyone,
This is just a couple shots of this kit for a Roden GB that's going strong.  I wanted Des to know that I used his pencil graphite trick on the wheels and they turned out pretty nice.  Never would have thought of using that!  8)
http://i229.photobucket.com/albums/ee260/smithdr/DSCN4125.jpg
http://i229.photobucket.com/albums/ee260/smithdr/DSCN4124.jpg
I'll be starting a modified Roden Staaken soon.  Keep a sharp eye out!
In the mean time, this Bristol is a really nice kit!
Dan
Re: Roden 1/48th Bristol F2.B
« Reply #1 on: April 30, 2012, 07:11:46 PM »
Your Bristol is looking very nice Dan, the engine turned out really well. What is your overall impression of this Roden kit?
« Reply #2 on: April 30, 2012, 07:32:28 PM »
Very fine looking Biff, Dan.  I've been watching this closely and I'm very impressed with what you've done so far.  I'm about to start the Sunbeam Arab version, so I'm learning a lot from yours.
« Reply #3 on: April 30, 2012, 09:53:38 PM »
  Dan,
Outstanding Biff my old friend.
Offline Whiteknuckles
« Reply #4 on: April 30, 2012, 10:06:53 PM »
Looking great Dan and looking forward to seeing the Staaken ;)
Eternal Apprentice
« Reply #5 on: May 01, 2012, 01:52:21 AM »
Nice work! No real pitfalls along the way?
« Reply #6 on: May 01, 2012, 02:49:32 AM »
Thank you ALL for your comments and questions.  :)  There seems to be a consensus question...what is the kit like!
Locating areas are kind of vague in places and as you are putting things together you aren't quite sure it's all going to fit.  It's not WNW  ;D But it does...with a little work...and all lines up well.  The engine mounting is an example.  As you put it in you are not sure it's really going to match up.  But my Vickers is shooting through the correct hole, nothing is crooked and it all looks suitably busy even without additions as a great OOB kit.  I only redefined and widened a few holes to make things positive.
The bottom wing attachment, for example, worked great and I was worrying about that.  The landing gear struts locate the wing in general and then you add the supporting struts with little heart ache.
My only criticisms so far are that the fuselage fits together but you need to be careful since there isn't much glue surface and things can slide around on you.  I needed quite a lot of correction fluid (a first for me...works great) for both the upper and lower seams.  All the cockpit parts fit in well and are straight.  No unusual clamping for force was necessary but the control column doesn't have a spade grip.  I'm not sure what that means  ???  Lastly, the tails have positive locating pins but they are very small and since the stabilizer is in two pieces, I had trouble getting it all square.  Still a bit wonky if you look at it on a contest table.
I have to say it goes together better than their SSW cockpit/lower wing area!
Well done, Roden.
Dan
« Reply #7 on: May 01, 2012, 07:26:42 AM »
Any Roden as far along as yours is a good thing. Their topics are so interesting and they are certainly prolific with their releases - thats what makes them popular.
« Reply #8 on: May 01, 2012, 11:51:48 AM »
what do you mean by " correction fluid" like liquid paper? is that what the seams are filled with? i must say if so thats a great idea. i have never heard that one. the tamiya surfacer reminds me of liquid paper so its not a surprise if this works well. nice looking biff by the way.
« Reply #9 on: May 01, 2012, 03:13:26 PM »
ALBATROS1234,
Sure is!  Run of the mill type writer correction fluid.  It hardens very fast, is super easy and precise to apply and files/sands nicely.  I wish I could say I thought of it, but I think either (or both) David Hooper or Neil Pinchbeck from many SAMI articles used this.  I just wanted to give it a shot and I'll use it again for fine lines etc.
Thanks for looking and asking  ;D
Dan
« Reply #10 on: May 07, 2012, 06:40:03 AM »
All,
Well...I started making my own turnbuckles based on various sites I've seen and techniques I've stolen with, perhaps, a twist or two.  First thing was to make tons of eyes by twisting electrical wire around a tiny drill bit and cementing these in holes drilled part way through the wings.  This was tedious but not hard to do.
http://i229.photobucket.com/albums/ee260/smithdr/DSCN4133.jpg
Then, I found some tiny tubing for making fly fishing lures and some very thin "tippet" fishing line. I first:
http://i229.photobucket.com/albums/ee260/smithdr/DSCN4135.jpg
1) cut a turnbuckle from the tubing.  In my case, they are about 3/32nd inches long.
2) pull out a piece of tippet about 6 inches long and color it with a black Sharpie marker.  Much easier to see and poke into the tubing.
3) thread it through the tubing and take one free end and put it through an "eye".
4) loop it back through and push into the tubing again.  Not an easy task!
I find that if I dip the tip of the tippet that will be going through the tubing in "Armor All", it slides much easier.  It's really hard to get two thicknesses of tippet through that tiny tubing otherwise.
5) a dab of super glue once it's all tightened.  Seems to look ok but I'm not looking forward to doing this for 8,000 buckles.  My eyes!  My eyes!
http://i229.photobucket.com/albums/ee260/smithdr/DSCN4134.jpg
You can see a shot of the buckles painted grey to give some contrast.  We'll see if this continues to work and if I can actually make the associated other attachments for the upper surface of the bottom wing.
Crikey...
Thanks for looking,
Dan
Offline LindsayT
« Reply #11 on: May 07, 2012, 07:44:35 AM »
Those are fantastic tips on the turnbuckles, Dan! I was really wondering how to do a good looking turnbuckle in 1/48 scale. The build is looking great, keep it coming!
Lindsay
« Reply #12 on: May 07, 2012, 08:11:05 AM »
Turnbuckles are looking great, Dan.  It's a very good technique that really helps strengthen the finished model.
Offline Pete Nottingham
« Reply #13 on: May 07, 2012, 08:15:17 AM »
Looking very nice Dan, love the turnbuckles.
« Reply #14 on: May 07, 2012, 11:14:39 AM »
As the others have said, looking great!
