Author Topic: Wingnut Sopwith Triplane  (Read 4870 times)
« on: May 07, 2013, 10:18:35 AM »
This is my Wingnut Wings Sopwith Triplane at the end of the construction phase with rigging about to begin.
The kit has some design flaws which have been discussed here but once the problem areas are fixed it goes together nicely.
The kit is OOB and as with all of my models, is brush painted. The prime colour used is Humbrol #10 Service brown slightly lightened with semi gloss white, and finished overall with a blend of Pollyscale Flat and Satin finishes.
The propeller and struts are finished with Winsor & Newton oils applied over a base of Foundation/ Citadel Paints Ivanden Darksun Ochre, then overcoated with a mix of Tamiya clear yellow & clear orange.
Weathering is yet to be applied but it will focus on some wear around the engine cowl and mud/ caster oil stains on the undercarriage and undersurface areas.
 Happy modelling!
Re: Wingnut Sopwith Triplane
« Reply #1 on: May 07, 2013, 11:01:40 AM »
Very nice work. Your brushwork is flawless. Looking forward to the rigging stage.
« Reply #2 on: May 07, 2013, 11:30:22 AM »
Truly brilliant work, Dave.  I'm always blown away by you guys who can create such silky smooth finishes with a brush.  If I tried that, it would look like it was painted by a 7 year old.
« Reply #3 on: May 07, 2013, 12:00:25 PM »
Beautifully done Dave, this is a superb example of brush painting. The model looks great and the colour is perfect, despite the few minor issues you had with construction it has turned out to be a remarkable model, the rigging will be the finishing touch.
Offline kinnies
  • Biggles flies low
« Reply #4 on: May 07, 2013, 12:01:17 PM »
Very, very nice! It's great to see all the Tripes being built. As other have said, your brush work is impressive indeed. What brand of paint and colour did you use for the PC?
cheers,
John
« Reply #5 on: May 07, 2013, 01:30:54 PM »
A very handsome specimen, congratulations!
Offline Whiteknuckles
« Reply #6 on: May 07, 2013, 02:56:14 PM »
Beautiful brushwork Dave, do you have a particular method to produce such a smooth result?
Eternal Apprentice
« Reply #7 on: May 07, 2013, 04:26:39 PM »
Lovely paint job, Dave  :)
Looking forward to seeing the final touches.
BVB
« Reply #8 on: May 07, 2013, 06:21:06 PM »
Wonderful model, Dave.  Hard to imagine such a perfect paintjob
with a brush.  I shudder at the thought of trying that one!  Looking
forward to seeing the finished product.  Thanks for sharing with us.
Best Regards,
Ernie
« Reply #9 on: May 07, 2013, 10:46:03 PM »
She's a real beauty Dave! I'll chime in with the others and tip my hat to you for your skill with a brush. Why would a fellow use an airbrush when he can attain superb results like this with a brush. I'm afraid that such results are beyond my abilities. Not to put any pressure on you but I'm looking forward to seeing her fully rigged.
« Reply #10 on: May 07, 2013, 11:39:16 PM »
  Dave,
She's one outstanding Tripe my old friend. Beautifully constructed and so well painted. Your brush work is superb. Looking forward to seeing your next update.
« Reply #11 on: May 08, 2013, 12:00:34 AM »
Beautifully done Dave! I hope I can achieve as nice of a finish Airbrushing as you did with the Brush! Outstanding Tripe!!!
Offline Epeeman
« Reply #12 on: May 08, 2013, 12:18:21 AM »
Great work so far Dave -
Always good to see another brush painter on these forums - looking forward to the end result!
Offline michael
« Reply #13 on: May 08, 2013, 12:23:15 AM »
I can only echo what has already been said - Fantastic Dave  :)
michael
Offline bbrockel
« Reply #14 on: May 09, 2013, 01:01:27 AM »
Beautiful work, Dave.  An with a brush no less.  Do you thin your paint a lot to get the smooth finish.  Hope I'm not asking you to refeal trade secrets.
"If at first you don't succeede, use a bigger hammer"
