Author Topic: Albatros D.III (1/72, Roden)  (Read 19570 times)
Re: Albatros D.III (1/72, Roden)
« Reply #60 on: June 12, 2013, 05:05:21 PM »
You may see the photo on the web. I have just typed "Albatros D.III Strahle" in Google and it gave me a link with Page 32 of the above mentioned book.
Offline IvotB
« Reply #61 on: June 12, 2013, 05:47:53 PM »
Yes, I have seen the picture and it is clear to see what is shining through the paint.
regards,
Ivo
« Reply #62 on: June 13, 2013, 07:08:32 AM »
Wash and dirt are now varnished. Spandaus, control horns on the elevator, windshield and the exhaust are on. Everything is now prepared for mounting the upper wing. Stay tuned.
« Reply #63 on: June 13, 2013, 01:09:18 PM »
The Albi is looking very good.  The paint scheme/weathering is
really attractive.  I'm looking forward to more photos of your
work.
Ernie
« Reply #64 on: June 14, 2013, 11:38:16 PM »
Beautiful work. What flat coat do you use? Cant wait to see the final product!!!!
« Reply #65 on: June 15, 2013, 02:15:04 PM »
Gorgeous work Prez, with one exception (and that's my own personal view...) - the panel lines!
 As a pilot, I'm up close with aircraft every day and panel lines are just not that visible. Panels usually overlap, there is no gap that looks dark!  I'm not sure quite why it's become so "de rigeur" for modellers to emphasise panel lines so much, but to me it spoils a very nice model...
Just my personal opinion, and still great work!
« Reply #66 on: June 15, 2013, 08:57:29 PM »
I think it it just superb, a little jewel.
Regarding the panel lines... our "Red Baron" (Justin) once wrote something here I thought was very cogent -- I wish I could find it to quote it exactly. Anyway, his comment was to the effect that there were two sepearate ideals in modeling; one being to create an exact scale replica, the other to capture the essence of the subject. I think the panel lines fall into the second category; the Albatros was fashioned from slabs of plywood and this treatment hints at this part of the story, just as the overpainted decals tell the story of a long career...
Offline mc65
« Reply #67 on: June 15, 2013, 11:54:28 PM »
how to disagree?
I would add something in between: a plane that works gets dirty, let alone a plane that fights!
although the European rules require cleaner airplanes, at the cost of heavy fines, here is an example of how I go around:
1409
1406
certain in scale would only be subtle signs, but to make the eye of the beholder able to seize them, exaggerate a bit 'becomes indispensable, I think.
the work of painting the fuselage (blue on blue) is wonderful, my heartfelt congratulations!
Offline KevinM
« Reply #68 on: June 16, 2013, 04:02:31 AM »
I love it !! Beautiful work all the way around as to the panel lines looks like a good artist at work just right to draw the beholder into the subject.;)
« Reply #69 on: June 16, 2013, 06:42:44 AM »
Wow, great to see such a discussion evoked by my rendition of panel lines. I realise that it may not be totally real. However, I have seen so many Albatros models with completely monolithic fuselage, that I decided I had to do something to suggest the panelled surface.
Some more progress includes the upper wing and the rigging threads pulled through the holes but still not tightened. Before starting with the upper wing I have let all the rigging lines into the prepared holes in the lower wings.
To get the upper wing on required some corrections to the struts. When compared with the scale drawings from WDS Albatros D.III the interplane ones were some 1 mm too long. I had to trim the lower tips and carve the pins. Then the struts were attached to the upper wing and after the glue set, this subassembly was glued to the lower wing. In this way it was quite easy to control the geometry. Then it obviously came out that the cabane struts were too long, too. They had to be trimmed by some 2 mm. The single front ones were easy to correct. The Vees had to be cut at the lower joint, slightly bent one toward another, glued, sanded and painted. After several trial and error attempts I managed to trim them to the correct length and when attached they nicely constrained the entire structure.
« Last Edit: June 20, 2013, 08:10:57 PM by PrzemoL »
« Reply #70 on: June 16, 2013, 08:54:35 AM »
Great attention to detail! The weathering is evident without
being over the top.
  What do you use for rigging in this scale?
Ernie
« Reply #71 on: June 17, 2013, 04:12:01 AM »
Pepperman, I am sorry, I have overlooked your question. The flat coat is actually a satin one, which is a mix (about 1:1) of Pactra clear gloss and Modelmaster clear matt.
Erni, I rig 72nd scale models with a black elastic thread taken from stockings.
« Reply #72 on: June 17, 2013, 06:06:01 AM »
The rigging lines are tightened and the excess over the upper wing cut. The radiator pipes made of tin wire are attached.
The elevator control wires in place
And I have started making up the mess on the top wing, the holes left by the rigging are now filled with a half-dried paint. When it is dry I will delicately sand these blobs flush to prepare the surface for the paint.
« Reply #73 on: June 17, 2013, 11:51:19 AM »
Exceptional execution!! Thanks for the satin coat cocktail.
« Reply #74 on: June 18, 2013, 06:05:36 AM »
Beautifully painted and rigged!
