Author Topic: Newbie Alert ...................  (Read 4423 times)
Re: Newbie Alert ...................
« Reply #15 on: March 15, 2013, 03:56:19 AM »
Welcome Andi!  I'm impressed with your efforts using eyelets and tissue paper.  Such creativity and experimentation will stand you in good stead with WWI modeling, and should help you lick any modeling problems that you may encounter.  You have created a nice selection of connectors that will likely prove useful.  They look great! ;D
I built the SH Morane last year, and it's a good basic kit.  Just be sure to follow the build logs for the usual fit issues and other problems, none of which are overly worrisome.  The rigging of a monoplane can be a bit challenging, particularly with the resin pullies and tiny PE brackets for the cabane posts, but if you take your time you should be fine.  If I could do it, you surely can.  My IRAS Morane is somewhere over in Completed Models, if you want to take a look.  Unfortunately, no build log. :-[   Have fun with it!
Offline Andi Little
« Reply #16 on: March 15, 2013, 08:30:13 AM »
Hi Andi;
Welcome to the forum, you say you are having trouble getting brass tubing, I see you are from the UK, you could try Historex Agents and look under Griffon Models, they do a range of tubing sizes.
http://www.historexagents.com/shop/hxshop.php
Pete.
Pete .............
Thanks for taking the time out to point me in the right direction - 'preciate it.
I've ordered a pack of 0.3, 0.4, and 0.5mm so there'll be no excuse now then! It all adds up to a little more commitment doesn't it?
Ta' again - you'll be amongst the first to know when I make a start on something or other.
KBO ............. Andi.
Online DaveM
« Reply #17 on: March 15, 2013, 05:25:15 PM »
Hi Andi,
interesting process with the turnbuckles using tissue paper.
You could also try Bobs Buckles, http://www.bobsbuckles.co.uk/index.html ,he is UK based and provides a great service.
There is also Albion Alloys in the UK, http://www.albionalloys.co.uk/
Dave.
« Last Edit: March 15, 2013, 11:20:46 PM by DaveM »
Offline kornbeef
« Reply #18 on: March 15, 2013, 10:21:57 PM »
Hi Andi;
Pete.
Hannants too stock micro brass tube when I get jome I'll try to rummage for the link... Oh and welcome Andi.
and as anafter thought Smallcars.com I think is the name do too.
Keith
Offline Whiteknuckles
« Reply #19 on: April 01, 2013, 07:56:03 PM »
Belated hello and welcome Andi  ;)
Eternal Apprentice
