Author Topic: 1:32nd scale OEFFAG Albatros D.III  (Read 1706 times)
« on: May 23, 2026, 03:40:25 AM »
While I'm waiting for the MDesign AW FK.3 kit to arrive, I'm working on another model.
It's the older resin cast Oef D.III (Albatros) from Lukgraph (not the later 3D printed kit).
The aircraft is D.III (Oef), Series 253.12 as flown by Oberleutenant in der Reserve Ludwig Hautzmayer, Commanding Officer of Flik 61/J, operating from Ghirano, Italy, during the the
Summer of 1918.
Some details of the cockpit needed modifying to better reflect a Series 253 series aircraft.
The pilot's instrument panel was not a single span panel, but two separate panels (left and right).
The rear of the two machine guns were mounted on a cockpit cross bar.
Also, the pilot's seat was not normally solid wood, but had several large lightening holes
Therefore, I've cut the instrument panel into two panels, added a Brass rod/tube cockpit cross bar for the machine guns.
Also added lightening holes in the pilot's seat.
I've removed the cast hatch panels and cooling louvres from the fuselage.
Kit photo-etch alternative panels fitted with 'Proper Plane' replacement cooling louvres.
Support rods added to flight control surfaces etc,
« Last Edit: July 02, 2026, 07:38:28 PM by Mike Norris (UK) »
Offline DaddyO
Re: 1:32nd scale OEFFAG D.III
« Reply #1 on: May 23, 2026, 04:11:13 AM »
Nice start on this one Mike  :)
It's one of the few 1/32 kits I own (in the alternative Polish boxing) I did wonder about the cockpit and briefly considered just lobbing a pilot in to fill the space and distract from the errors, but think your way is a better option so following along with interest
« Reply #2 on: May 23, 2026, 06:19:25 PM »
I have this one on the shelf to do at some point so I'm following with interest. I'm definitely going to put a pilot figure in it to hide the incorrect cockpit (much of it is wrong), unlike Paul I'm lazy! I'll just correct the instrument panel.
The big thing that's putting me off doing this one is removing the rib tapes. Not only are they overdone the kit IMO, there weren't any rib tapes on the Oeffag DIII anyway so they should be removed completely. Koloman Mayrhofer established this in his research for his DIII replica builds - they stitched the wing fabric directly to the ribs without rib tapes, see below:
« Last Edit: May 23, 2026, 06:24:29 PM by NigelR »
« Reply #3 on: May 23, 2026, 07:52:01 PM »
Hi Nigel,
Yes removing the cast rib tapes should be straight forward enough.
Representing the stitching could be a the problem though - we'll see,
« Reply #4 on: May 23, 2026, 09:45:01 PM »
That's another thing that's been putting me off doing  this one! I might try some of the Archer stitching transfers now these are available again, although none of them are quite right. However, I plan to do a scheme that uses the sworl camo on the upper surfaces so they would barely be visible on that.....
The decals are very transparent in this kit FWIW, the white in particular is not very opaque.
« Reply #5 on: May 23, 2026, 11:21:18 PM »
Yet again working on a less than stellar kit with lots of issues. I am certain you will do it More than Justice!
« Reply #6 on: July 02, 2026, 07:03:00 AM »
Some progress on the Albatros.
This is the original resin cast model from Lukgraph.
I've modified as much as I could to make the cockpit a series 253 version (kit is I think a series 153 version cockpit).
The fuselage is painted ready for applying external wood effect.
I've also removed most of the flight surface rib tapes.
As Nigel points out, these aircraft had the linen covering stitched directly to the wings, so no rib tapes as such,
« Reply #7 on: July 02, 2026, 06:53:53 PM »
Nice progress on this one Mike. I think the cockpit looks pretty good, splitting the instrument panel makes a big difference and makes it look like a 253 series.
How big of a job was removing the rib tapes? This is the one thing that keeps me putting off doing this....
Also, did you do anything about those annoying three "faux" cooling slots on the nose? LukGraph cast them as raised lines instead of making them cooling slots.
There's so many annoying little things wrong with this kit that could easily have been corrected.
« Reply #8 on: July 03, 2026, 06:49:20 PM »
Hi Nigel,
They needed sanding off as then drilling out.
Also the join seam down the centre of the nose cowl needs reducing or removing.
Photographs of the 253 series aircraft show a very faint line that could be that joint seam,
Re: 1:32nd scale OEFFAG Albatros D.III
« Reply #9 on: July 03, 2026, 11:20:30 PM »
I guess that's the right way to deal with those slots. Sadly precision drilling isn't one of my strengths.... :(
Thanks for the heads up on the join line.
« Reply #10 on: July 12, 2026, 05:25:51 AM »
The nose cowl required three modifications.
When offered up to the joined fuselage halves, the outer edges of the nose cowl overlapped the edges of the fuselage.
Therefore, those edges were sanded until they aligned to the fuselage edges.
The joint seam down the centre of the nose cowl is printed as raised, when it was a shallow joint with fasteners (thanks Bertl for the heads up).
The vertical seam/joint running down the centre of the nose cowl was sanded away.
The joint line was scribed into the cowl.
The five cooling slots at the bottom, centre of the nose cowl were printed as raised ridges, not as slots.
A rectangle was cut out of the nose cowl to remove the five raised cooling 'slots.
A strip of masking tape was applied to the inside of the nose cowl to cover the opening.
Thin strips of plastic rod were cut to length then located into the opening and held in position on the masking tape.
The strips were then secured in position using thin CA adhesive.
The masking tape strip was removed and the nose cowl painted,
« Last Edit: July 12, 2026, 11:32:50 PM by Mike Norris (UK) »
« Reply #11 on: July 13, 2026, 03:15:32 AM »
Thanks for that Mike, really helpful! I think I can manage those cooling slots now.
« Reply #12 on: July 14, 2026, 01:32:04 AM »
I've applied light plywood effect by brushing Windsor & Newton Griffin Alkyd (Raw Sienna) oil paint over the fuselage, fin and tail skid.
Once fully dry, used a 1.0 mm Rosie Riveter to represent the panel nail lines.
I then brushed Flory Models dark dirt wash wash along the nail lines then wiped off the excess.
Finally sealed the finish with Tamiya Semi-Gloss (X35) clear coat.
Now it's onto adding the fuselage photo-etch parts,
Offline Umlaufmotor
« Reply #13 on: July 14, 2026, 07:13:25 AM »
The nail heads - how well does that work with this resin material using the riveter, Mike?
Servus
Bertl
« Reply #14 on: July 14, 2026, 08:52:39 AM »
Servus
Bertl
Hi Bertl,
OK really.
Just have to be careful you don't apply too much pressure as the cast resin is quiet soft compared to plastic.
Other than that, no problem,
