Author Topic: Multi-Seat 2026 GB Roland C.II 1/48  (Read 1964 times)
Re: Multi-Seat 2026 GB Roland C.II 1/48
« Reply #15 on: May 09, 2026, 07:09:09 AM »
Good start Alexis. I too do not bother with interiors that will never be seen - life is just too short and there are too many projects waiting in the pipeline!
« Reply #16 on: May 11, 2026, 10:49:41 AM »
Thanks guys !
Can relate to that guys on adding detail which will never be seen but I still enjoy the super detailing but keep that to more of my favorite aircraft .
Prze , believe you are right on the interior colour based on the WNW kit but this build is about enjoying the build and having fun with it .
Alan , yes will doing the box cover scheme .
Was able to get the fuselage glued up and is drying right now , tomorrow clean up the seems and get some progress pic's for you gents
« Reply #17 on: May 11, 2026, 11:47:50 AM »
Very nice start Alexis, looking forward to more!
« Reply #18 on: May 12, 2026, 09:05:03 AM »
Thanks Tim !
Bit of progress to report , inner parts are fixed in place and the halves closed up which I had to go back and split this apart to fix the instrument panel after it came loose . I had to trim the edges of the PE parts , after this it the fit like a glove . The gun ring part didn't fit all that great requiring sanding and filling . Lower wing is a hard place t sand and fill that seem . It isn't bad but not all that great either , passable after some weathering . I did have to replace the one access panel on the chin form cleaning up the seem . All rigging holes are drilled , I sometimes forget to it at this stage . Ready for the home made turn buckles . The exhaust got drilled out and the landing gear legs are pinned for added comfort . Guns barrels got replace with brass tubing .
« Reply #19 on: May 12, 2026, 09:05:40 AM »
« Reply #20 on: May 12, 2026, 09:06:55 AM »
« Reply #21 on: May 12, 2026, 09:07:40 AM »
Online NigelR
« Reply #22 on: May 12, 2026, 05:58:36 PM »
That interior looks very nice and it's good to see the rest of it progressing pretty quickly. Looking forward to seeing more.....
« Reply #23 on: May 12, 2026, 06:57:18 PM »
Progressing nicely! Pity that so nice an interior is buried so deeply...
« Reply #24 on: May 23, 2026, 05:30:58 AM »
Outstanding interior Alexis! Looking forward to your progress as always!
« Reply #25 on: May 24, 2026, 11:34:47 AM »
Really appreciate you guys following along on this build . It is Prze , not a lot will be visible , even when viewed form the windows .
Made a bit more progress on the painting . The rib locations got masked off once the black base coat was dried followed  by a messy spotty over spray of Tamiya med blue . Tamiya white was next done in the same manor . Mixing up some Tamiya light grey , light blue and white a base coat was sprayed over . with even a lighter shade with more white added in the mix . This is the same method I used on the Hell-diver I did . Once this has dried over night the white fields need to masked off and sprayed on the wings surfaces-es
« Reply #26 on: May 24, 2026, 11:35:24 AM »
« Reply #27 on: May 24, 2026, 11:36:35 AM »
« Reply #28 on: May 24, 2026, 11:38:15 AM »
Online NigelR
« Reply #29 on: May 24, 2026, 06:34:53 PM »
Very nice work on the core colour of this one. I was a little worried that all that preshading might show through a bit too much but you've done a great job and it looks spot on to these eyes.
