Author Topic: Multi-Seat 2026 GB - Sopwith 1 1/2 Strutter 1/72  (Read 3944 times)
Offline DaddyO
Re: Multi-Seat 2026 GB - Sopwith 1 1/2 Strutter 1/72
« Reply #75 on: May 27, 2026, 07:24:23 PM »
Cheers guys  ;D
(Cat hair now removed you'll be pleased to know Nigel)  ;)
Offline Dirigible-Al
« Reply #76 on: May 29, 2026, 03:10:17 AM »
Looking really good.
Alan.
« Reply #77 on: May 29, 2026, 05:23:19 AM »
Super painting - I do like your shade of PC 10. I am in the process of applying same shade to my AD 1 Navy Plane and am using acrylia OD from Revell - will see how it goes when I have enough coats on it.
PS bless the cat - sadly I lost my two many years ago which is probably just as well as one of them would have taken to sitting on whatever I am making if he were still around!
Offline DaddyO
« Reply #78 on: May 29, 2026, 06:36:09 PM »
Cheers Alan and Stephen  :D
The PC10 is based on the AK Stephen, but I thought it looked too green so added dark earth till it looked brown in certain light and then a tough of white/grey to lighten and dull it a bit. It looks quite green in the pictures, but I think that's the varnish coats and hopefully it'll go back when the later coats are added
ps - The two cats are my daughter 'Blue mitten ragdolls' and they shed hair as soon as you look at them  ::) Both are banned from the workroom, but that doesn't stop the hairs. On one occasion they managed to get in and once on the desk had a lovely game scattering pieces of model all over the place . . . .
Offline DaddyO
« Reply #79 on: June 02, 2026, 04:30:26 AM »
Right that's the fuselage decalled up at last  :P
(I'll spare you the various attempts at making the red/white rings, but I ended up using a cut down RNAS marking with a separate red centre spot. I managed to mess up the one on the other side which led to a bit of a clean up and re-paint) The numbers were applied individually from various sheets which is as painstaking as it sounds, but at least it's done now. Looking at the blown up image of this side I need to add a tiny spot of red to the corners to sharpen them up . . .
Next up struttery
Strutter decals , on Flickr
« Reply #80 on: June 02, 2026, 11:24:13 AM »
Nice work on those tinny little numbers ...
« Reply #81 on: June 02, 2026, 06:19:43 PM »
More delightful work, worth the effort.
Those ragdoll cats sound delightful but definitely not wanted anywhere near a modelling room!
« Reply #82 on: June 02, 2026, 11:49:11 PM »
It was looking good before. The markings have made it even better!
« Reply #83 on: June 03, 2026, 01:28:03 AM »
I've been following your little build and really been impressed so far, Paul. Great progress on a tiny model!
Offline DaddyO
« Reply #84 on: June 03, 2026, 07:21:30 PM »
Thank you all.  ;D
Spotted yesterday that the tailplane doesn't have the usual PC10 upper surface on the profile and looking a little closer it appears that when the squadron was supplied with their Strutters only the wing upper surfaces were given the PC10 coats, the rest being plain linen coloured. No wonder they added some 'local' dark green to the fuselage areas, but strange that none was added to the tail surfaces at that stage. It does make for an interesting model though.  ;)
Of course our eponymous hero had already painted the tail surfaces in PC10 so they've been stripped and repainted with a dark brown pencil line under the lower surface coats to represent the see through structure.
Everything now had another varnish coat and is currently drying before a spot of weathering
Offline Richtrad
« Reply #85 on: June 04, 2026, 02:41:36 PM »
This is all so impressive not even considering that it is in 1/72.  Just love that wood grain.
Warren Q
Offline DaddyO
« Reply #86 on: June 06, 2026, 08:38:54 PM »
Warren Q
Cheers Warren  :)
Slight delay in proceedings because the oil weathering started to eat into the varnish coat despite drying for a couple of days. I've had this occur before and it's usually down to scrubbing too hard or overworking the oil paint on the surface - bloody annoying.
Of course this meant there were little bits of varnish and stuff on my lovely smoothish surface so I wasn't happy; out with the turps to take off all the oil paint and varnish which then damaged the underlying PC10 (of course)  :'(
Anyway I decided to just pop the model down and step away for a few days. Usually I'd work on a different model at this point, but I've been trying to stick with working on just one model at a  time so had nothing else to drop onto. Opening another box would inevitably mean that this one was put on the shelf of doom.
Fast forward to yesterday and I decided the turps/oil on the surface had had plenty of time to evaporate and I tentatively brushed a couple of thin coats of the original PC10 over the surface and let it dry fully. Not wanting to go through the whole varnish/oil routine again which always adds dust and bits to the surface I decided on a nother approach - when painting figures I usually work wet in wet to get the main areas of shadows and highlights and then use thin glazes to blend and add nuances of colour; would the same approach work on an aircraft? Only one way to find out . . .
I'm pleased to say that the same techniques work just as well on a wing as they do on a frock coat and enthusiasm in all things aircraft related has been restored  ;D
I do think the method has some mileage (for me at least) since it allows a for more artistic approach to painting aircraft that appeals to my creative side rather more than the prescriptive methods usually employed. (I appreciate that using an airbrush can give similar effects and probably more easily, but I only own a very basic second hand airbrush which is useful for blocking in and I feel more comfortable using hairy sticks whenever possible).
Right enough rambling I'm off to the local airfield to watch some big 'uns in a D Day celebration (although given the weather I suspect most of the time will be spent in the cafe next to the airstrip)
« Reply #87 on: June 06, 2026, 11:40:38 PM »
Glad to hear you were able to recover the build! Also good to know your techniques worked  8) Looking forward to the results.
« Reply #88 on: June 07, 2026, 06:07:21 AM »
An interesting description of your travails and success in overcoming them. The fuselage markings look the part, especially the serial which from its size must have tried your patience.
The colour scheme that you have described sounds very interesting: just shows how much variation there could be at the time.
« Reply #89 on: June 08, 2026, 08:13:43 AM »
Looking forward to see the recovery. It would be a pity if this one ended elsewhere off your cabinet.
