Author Topic: Multi-Seat 2026 Group Build. Ilya Muromets rebuild. (Maquette 1/72)  (Read 1625 times)
Offline PJ Fisher
    • Aero Rarities
Re: Multi-Seat 2026 Group Build. Ilya Muromets rebuild. (Maquette 1/72)
« Reply #15 on: April 29, 2026, 09:17:46 AM »
I need some popcorn for this build. Exciting!
Offline Flamingo
« Reply #16 on: April 30, 2026, 03:11:23 AM »
That is a great rebuild!
jets are for kids
Offline Dirigible-Al
« Reply #17 on: April 30, 2026, 03:50:22 AM »
I have wondered how they fly. There seems to be little weight in front of the wings and the tailplane is so massive the whole thing should drop almost vertical once in the air.
Alan.
« Reply #18 on: April 30, 2026, 10:24:46 AM »
Looking very promising so far Tim .
When you built it , did you add details to the cockpit ? I notice the wooden walk planks for the engines ....this is not in the kit for what can recall , are those plastic card or PE ?
« Reply #19 on: April 30, 2026, 10:55:02 AM »
Thank you Alexis. Yes, the interior is pretty well detailed. I don?t like the wood effect I used back then but it can?t really be seen all that much. The wing walks are very thin plastic card. I added the fuel lines from brass rod because the Macquette model doesn?t have them. I have a real problem that the pilot seat has broken loose and is rattling around inside the cockpit!  Hopefully I?ll be able to fix it.
All the best,
Tim
« Reply #20 on: May 04, 2026, 09:06:03 AM »
Part 4.
Thanks all, I am enjoying this rebuild.  After getting all the undercarriage constructed, I began to build the engine mounts and wing walkways. The Russians sure used a lot of lumber on this project!
Next up I decided to complete the tail section.
The two outboard rudder fins actually were braced with metal rods. The kit parts are thick wood planking and not correct.
Here is everything assembled. There is more rigging on this tail than most whole WWI aircraft!
Here is where I?m at now. Ready to start the Argus AS-II 140 HP engine rebuilds.
Thanks for looking in!
Tim
« Reply #21 on: May 04, 2026, 10:09:01 AM »
Lovely work Tim, my goodness the rigging!
« Reply #22 on: May 04, 2026, 03:59:03 PM »
Wow, just wow! What a beast!
Online NigelR
« Reply #23 on: May 04, 2026, 06:37:47 PM »
This looks amazing. And that rigging!!! :o
« Reply #24 on: May 06, 2026, 04:01:40 PM »
Part 5.  Argus AS-II engines.
The Maquette kit really has some major flaws. One of which is the very poor representation of the Argus engines. So bad that I actually scratch built them. These don?t look very good either but are much better than the kit offerings.
I?m going to strip them down and see if I can rebuild them to a little higher quality.
I?ve repainted them and will add new push rods from copper wire.
The engines are mostly complete and I added the scratch built radiators. These were assembled from brass strip and rod.
Once again the Maquette kit had really poor radiator moldings.
Here?s the front view. The radiator plumbing was hard to gather aligned. The engine exhaust pipes are cut brass tube.
My attempt at getting an interior shot.
I guess you can see some of the interior details.
Still haven?t fixed the loose pilot seat though!
That?s all for now, thanks for looking in!
Tim
Offline Flamingo
« Reply #25 on: May 06, 2026, 04:07:45 PM »
That is mighty fine!
Have one in my stash so know about the poor quality.
Regards Joachim
jets are for kids
« Reply #26 on: May 06, 2026, 04:10:13 PM »
Thank you Joachim. Yes.  If you consider building an Muromets, look for the ICM kit. It is much more detailed.
« Reply #27 on: May 06, 2026, 04:27:17 PM »
I continue keeping my fingers crossed. Great recovery underway!
Online NigelR
« Reply #28 on: May 06, 2026, 05:28:06 PM »
Wow again, those engines are pretty good and the radiators and plumbing are superb. This really will be a superb model when it's done.
« Reply #29 on: May 07, 2026, 09:55:36 AM »
Some really nice work on the rebuild Tim , that is a lot of rigging on the tail ! Don't think I will be building the one I got in the stash still any time soon
