Author Topic: Aces Mount 2025 GB - SE5a (Viper) of DW Grinnell-Milne - FINISHED  (Read 5986 times)
Re: Aces Mount 2025 GB - SE5a (Viper) of DW Grinnell-Milne
« Reply #30 on: September 28, 2025, 06:39:40 PM »
Very nice weathering Mike, some great techniques used there. I looks like you used the metallic pencil for some subtle wear on the engine covers and in other places, I think that worked well. Subtle but very effective and realistic IMO.
« Reply #31 on: September 29, 2025, 09:37:20 PM »
Everything about this build is great Mike, as usual.
This will be another gem.
Online Dirigible-Al
« Reply #32 on: September 30, 2025, 01:53:26 AM »
I agree with the previous comments on the weathering but that aside the whole thing just seems so well done.
Alan.
« Reply #33 on: October 03, 2025, 11:52:03 PM »
I've added the rigging to the tail unit of the SE5a.
No turnbuckles as the tailplane/fin and landing gear bracing wires were RAF Streamlined type.
The rudder, elevator and tail skid control cables were wire wound, but had their turnbuckles in the cockpit.
I used 0.08 mm diameter mono-filament for the control cables and 0.12 mm diameter for bracing wires.
All with blackened 0.4 mm diameter tube.
Now it's onto pre-rigging the wings before assembly,
« Last Edit: October 06, 2025, 07:23:45 AM by Mike Norris (UK) »
« Reply #34 on: October 04, 2025, 06:17:04 PM »
Lovely precise rigging work Mike. Question - what brand/type pf CA do you use when attaching rigging?
« Reply #35 on: October 04, 2025, 07:55:33 PM »
Hi Nigel,
I normally use 'VMS Fleky' CA adhesive (Thin).
Sometimes the 'Slow', 'Resin' or 'Black',
« Last Edit: October 05, 2025, 05:35:54 PM by Mike Norris (UK) »
« Reply #36 on: October 04, 2025, 10:15:56 PM »
Thanks Mike.
Offline Allan31
« Reply #37 on: October 04, 2025, 10:30:53 PM »
Nice job Mike. Weathering looks spot on.
« Reply #38 on: October 06, 2025, 07:28:04 AM »
Thanks to RAGIII for pointing out something I missed.
The book on No.56 Squadron shows that an extra bracing wire was fitted between the inspection window in the tailplanes and the leading edge of the fin.
This was to prevent fin twist in flight.
The previous post now show the additional bracing wires,
« Reply #39 on: October 06, 2025, 10:50:55 AM »
Awesome correction and overall terrific work! Glad I could Help!
« Reply #40 on: October 07, 2025, 02:04:04 AM »
Some stunning effects on this great model, Mike! I'm enjoying this build immensely! Regards, Marc
« Reply #41 on: October 09, 2025, 09:00:19 PM »
The SE5a (Viper) model is now complete.
Here's a few shots of the rigging.
Mono-filament 0.08 and 0.12 mm diameter.
Blackened tube of 0.4 and 0.5 mm diameter.
Proper Plane resin fork end turnbuckles (RD-019).
I'll post shots of the finished dual build of the SE5a and Spitfire Mk.1a once the display case is completed,
Offline Allan31
« Reply #42 on: October 10, 2025, 07:24:55 AM »
That.....is truly grand. Great finish Mike.
« Reply #43 on: October 10, 2025, 05:33:22 PM »
Stunning, simply stunning!
« Reply #44 on: October 10, 2025, 06:31:09 PM »
Superbly done Mike.  Excellent finish and the rigging is so realistic!
