Author Topic: Aces Mounts 2025 GB - Dieter Collins Albatros D1 1/72  (Read 8083 times)
Re: Aces Mounts 2025 GB - Dieter Collins Albatros D1 1/72
« Reply #30 on: August 18, 2025, 04:56:59 AM »
Excellent modelling Paul, well done! It would have been bin time for me......
Offline DaddyO
« Reply #31 on: August 18, 2025, 05:06:29 AM »
You're a much braver man than I Paul!  Great work so far sir.
As we used to say at the Benning School for Wayward Boys: "Continue to march!"
Warren D
 Cheers Warren  ;D
Braver/Stubborn - two sides of the same coin  ;)
Thanks matey (Came really close . . . ) ;D
Offline Allan31
« Reply #32 on: August 18, 2025, 11:46:16 PM »
Great stuff, looks super. Any chance we'll see the Pegasus built?
Offline DaddyO
« Reply #33 on: August 19, 2025, 12:48:06 AM »
Getting there with it Allan (I decided against chickening out and using the Roden kit) so the Pegasus one is what I'm working with. Added some nice brass and plastic details earlier so a picture may be on its way later (once I've finished work, cooked tea, taken the dog out and been to teh dance lesson)  :P
« Reply #34 on: August 20, 2025, 07:29:41 PM »
Continues to be a great work on a not too easy kit. Looking forward to the continuation.
« Reply #35 on: August 20, 2025, 11:34:46 PM »
Wonderful work Paul. Thank you for posting your solutions for the kit bashed parts. Someday I?ll get the nerve to carve my own props!
Offline DaddyO
« Reply #36 on: August 21, 2025, 03:10:29 AM »
Thanks both (Have a go at carving props Tim - it's not as complicated as it seems and at least with these you don't have to worry about balance and pitch distribution like you do with flying ones)  ;)
Anyway as promised here are a few details added to the basic fuz. vents and hatches from spare PART sheets a few bits of 5 thou plastic sanded down and some stretched sprue for connectors on the cowl. With the etch I found that attaching with varnish holds them in place and gives you a bit of time to get them where you want them. Once that had dried overnight I dropped some thin superglue onto them and hopefully by the time I've added some primer they'll be stuck for good  :D
The engine is one of Roden's finest with the expansion tank added to the front and some stretched sprue details. Sadly a lot of the lower engine was lost getting it to fit in the available space, but since non would be seen anyway I'm not too fussed
Albie D1 etch by Paul S, on Flickr
Albie D1 etch 2 by Paul S, on Flickr
Offline Allan31
« Reply #37 on: August 21, 2025, 06:38:46 AM »
Great stuff Paul. You handle the PE stuff in that scale so well.
« Reply #38 on: August 21, 2025, 06:40:52 PM »
Excellent work Paul, especially with those small details in this tiny scale.
Offline Brad Cancian
    • Brad's Models
« Reply #39 on: August 21, 2025, 06:53:32 PM »
Looking fantastic Paul! Keep it up!
BC
Offline DaddyO
« Reply #40 on: August 24, 2025, 08:15:59 PM »
Thank you gents  ;D
With a bank holiday weekend upon us I've been spending a lot of time in the workroom, partially working on this and a companion project which I'll add elsewhere.
Anyway it's all pretty tight around the cowl area with exhaust, guns, struts and engine and it's important that everything fits in it's correct place so a testing and cutting and adjusting meant that I have actually made good progress although it may not look like it  :P
The two lovely guns were mounted on a modified Eduard DR1 ammo box from the spares box for convenience in handling and test fitting (I've kept the feeds from this but will need to make up the spent round chutes later) After drilling out the exhaust I replaced the back feed pipe with 0.5mm brass wire and added a 0.2mm pin to the front one which meant I could fit, adjust, tweak and refit knowing that it will go back in the same place. It also allowed me to drill the holes for the front strut without causing any damage to the details
DI details 2 by Paul S, on Flickr
Here's everything dry fitted together; the guns look a tad high in this pic, but look okay overall and I can get the front strut in the correct gap between the exhaust pipes
DI details by Paul S, on Flickr
Right need a pair of cabanes and then it's time for primer to see what needs further work . . .
Offline Allan31
« Reply #41 on: August 24, 2025, 09:33:18 PM »
Loverly progress.
Offline DaddyO
« Reply #42 on: August 25, 2025, 12:56:34 AM »
Loverly progress.
Cheers Allan  ;D
It's no wonder that I'm so slow. Most of the day spent making up the cabane for this one.  :o (Brass rod filed flat and then bent to shape and then a rod soldered across the top and cleaned up) It's just pushed into the holes at the moment so not aligned correctly, but gives you the idea of how it will look. Time to break out the etch primer for this and the struts that I made earlier  ;)
Albatros DI cabane by Paul S, on Flickr
« Reply #43 on: August 25, 2025, 06:49:55 PM »
More very impressive modelling skills on display. Great progress on this one.
« Reply #44 on: August 28, 2025, 12:00:05 AM »
I really like the work you are doing on this one Paul , she is turning out super so far !
