Author Topic: Albatros D2 Boelcke D386  (Read 4101 times)
Re: Albatros D2 Boelcke D386
« Reply #15 on: September 13, 2025, 06:14:13 PM »
That's looking pretty good to me. You can always go further with the detailing, the question is always how far......
Offline DMPopa
« Reply #16 on: October 16, 2025, 07:42:25 AM »
It has been a while, but I have made progress on adding the skin to the fuselage structure.
This is the fuselage skin as a top, bottom, left hand and right hand side pieces.   Also shown is the fuselage structure which is primed in grey overall and with brown paint in the areas where the seams will be.
I place the top skin in place, positioning it with the cockpit in the correct location to the fuselage structure. It is glued in place and secured with hair tie rubber bands.
Nest is added one side, lining up the black cross.   I glue just this area and use hair tie rubber bands to secure it in place.  I have found that trying to line up the entire seam accurately all at once is tricky, so I get one small piece glued in place, properly aligned and glue the rest as a later step.
Side completely glued.
This is after all of the pieces have been added.
It took a lot of time to get the seams right, filling in the gaps with MH Readypatch and painting a matching color.
Next, the engine is installed and the cowling will be added.
« Reply #17 on: October 17, 2025, 07:55:51 PM »
Afraid I cannot comment on your progress as I think you are using Imgur, which is now barred to users in the UK so the images are not visible to me..... :(
Offline DMPopa
« Reply #18 on: November 16, 2025, 11:11:44 PM »
To bad to hear about Imgur.    :-\    I have to think about a workaround.
I got the cowling and forward part of the fuselage done.   It took quite a bit of time to get a satisfactory result.    I believe the intent of he source Albatros W4 model  was to allow the cowling to overlap the fore part of the wood fuselage but I desired to have things to be smooth.   My first try with cutting and gluing paper left gaps at the cowling so plan B is to fill with Ready Patch and sand and paint.  This was done over and over again until I got a good result.   I got lucky with the brown color; I found a can of paint  Old Village 1123 Rittenhouse Ivory that was almost dead on.    Brown is a tough color to achieve a match.
The engine is placed in the fuselage with shims placed at its base to get the proper height to the cowling.  Proper height includes enough clearance for the exhaust manifold to clear the cowling.
This is the final result.
Offline DMPopa
« Reply #19 on: December 28, 2025, 12:02:00 PM »
I have not found a proper work around for Imgur which a prior post says cannot be viewed in the UK.   Does anyone recommend a similar photo hosting site to Imgur that works in the UK?
Got the rudder, horizontal stabilizer and bottom appendage done.
The appendages first cut out of cardboard and music wire is added for attachment support.
The paper skin is glued over the cardboard and music wire.  The edges are painted.   The Horizontal stabilizer has control horns added made from beer can aluminum.
The appendages are attached.  Holes are drilled into the fuselage that align up with the music wire.  Only the bottom appendage is glued in place.   The others are held by the music wire press fit.
I have smoothed out the grey cowling somewhat.    These pictures posted here really show flaws.
I see some more remedial work to be done on the fuselage bottom.
Offline DMPopa
« Reply #20 on: May 28, 2026, 09:35:21 AM »
The lower wings have been constructed and assembled to the fuselage.
A wing skeleton I constructed and the wing skin panel is cut, folded and glued in place.
The ribs are individually cut and two (2) holes are drilled using a pin vice in each for reinforcing music wire.   The leading music wire is .020 K&S Music Wire and the lagging wire is .032 K&S Music Wire.    I cheated here whereby I enlarged the rubs to provide enough width to accept the Music wire.   The length of the ribs are trimmed to the correct length.   However this method lost some of the concavity of the ribs so next time I will need to "squeeze" the ribs to maintain the concavity.
Squeezed together on the music wire allows the ribs to be accurately trimmed.
Pieces of cardboard are glued between the ribs and above the music wire.   It is important that each and every piece of cardboard be the same width to ensure the left and right hand wings are the same length.    At this point the left and right hand wings are assembled to the same pieces of music wire.    Nothing really special with this, it happens to be the way I did it.
A length of .032 K&S Music Wire is run along the leading edge and bent to define the outside edges of each wing.  A groove was cut into the leading edge of each rib to accept the music wire and gel super glue was used as the adhesive.
The leading and trailing edges are covered thin vellum paper.
I process the wing panels different than in my earlier posts.     To achieve the lower wing concavity, or what is left of it, and to have a neater outer edge, I trained the paper by pre-bending into the desired final shape.
Next the edges are glued together; the trailing edge is not glued at this time.  When dry, the wing envelope is slipped over the respective skeleton and the trailing edge is glued at this time.   Clips are used on the trailing edge to get a snug fit.
This is one of the two wing edges post assembly and prior to any "post processing".
Holes are drilled into the fuselage and the wings are attached and glued into place using gel superglue.
The fairings are glued into place.  The trailing fairing should have been glued prior to assembling the wing.    Something that I should have done better is to realize that the fuselage location where the wings are being placed is not flat, but the inner side of the wings are flat; there is a rib at the inner edge.    I used ready patch, paint and cosmetic powder to fix this problem.
Offline NinetythirdLiberator
« Reply #21 on: May 31, 2026, 02:02:07 AM »
Looking good!  Interesting wing construction too.  May need to steal that idea...Dan
« Reply #22 on: June 02, 2026, 11:35:09 AM »
I like it , this is shaping up rather nicely .
