Author Topic: WNW DH2  (Read 7403 times)
Re: WNW DH2
« Reply #15 on: February 27, 2013, 04:27:11 AM »
.............. but an enjoyable build I would recommend to all to have a go at.
I will take you up on your recommendation and build this.................soon.  Your is truly outstanding.  I like the CDL wings.  What did you use for rigging?  Looks good.
Offline gcn
Re: WNW DH2
« Reply #16 on: February 27, 2013, 06:14:07 AM »
Thanks for the comments everyone they are much appreciated.
Mark, the rigging in detail.
Homemade eyelets then knit in elastic threaded through a brass sleeve, looped through an eyelet and back through the sleeve but not glued at this stage.
And then the other end I just thread through a brass sleeve once and then through the eyelet and glue with extra thin CA. Your sleeve angles are then set properly and the glue sets instantly. I glue at the top and bottom of the sleeve to be sure everything is set and then I glue the top and trim.
Control wires were thin ez line. This is easier to thread as its thinner so both ends get looped.
I hope that makes sense.
Offline drdave
Re: WNW DH2
« Reply #17 on: February 27, 2013, 08:17:47 AM »
Superb work!
Re: WNW DH2
« Reply #18 on: February 27, 2013, 09:42:17 AM »
Beautiful work Gary.
Did you temporarily cross-brace the tail boom when doing the rigging? My concern is that I'd warp the booms when pulling the lines taut.
Offline gcn
Re: WNW DH2
« Reply #19 on: February 27, 2013, 05:15:31 PM »
I rigged everything I could with the Booms flat on the desk, then fixed the booms and rigged what was left.
Using elastic I didn't have any trouble with the booms flexing out of line, I didn't tug them too much but enough. I'd imagine with fishing line it would have been a totally different matter.
Re: WNW DH2
« Reply #20 on: February 27, 2013, 11:23:20 PM »
Thanks for the explanation. I think elastic line would be a good fit on this and the Fee.
Re: WNW DH2
« Reply #21 on: February 27, 2013, 11:44:18 PM »
Gary, your DH2 is gorgeous. ;D
I am interested in your rigging.  You mentioned using EZ Line for the control wires and something you referred to as "knit in elastic" for the bracing wires.  I am unfamiliar with this product, but it seems to have worked brilliantly for you on this model.  Can you please elaborate, re: type of material, brand name, size and from where it might be available?  Thanks much for your help.
Offline gcn
Re: WNW DH2
« Reply #22 on: February 28, 2013, 02:19:11 AM »
Hi Bob, thanks for the comments.
http://www.purplelindacrafts.co.uk/prym-knitting-in-elastic-200m-invisible-elastic-thread-8896-p.asp is the stuff, I think Gold Zack is another brand name. WNW sell the same stuff for quite a bit more. It's also way cheaper than EZ line, in the UK we get 100ft for £12 whereas this is £2 for 200m. It is readily available in the UK from a multitude of places.
It's similar to EZ line but it is thicker and has a flatter profile so to that end it's more suited to the RFC style wires, but IMO in our scale it doesn't really matter.
The WNW builds on their site (not the customers builds) always seem to use this stuff for RFC planes.
If you are using brass sleeves it is harder to thread through the 0.3mm id tube due its width and flexibility. I found cutting it at an angle helps and when threading it through the tube for the 2nd time if you stretch a piece between your thumb and forefinger with the sleeve in the middle of the stretched bit this narrows the thread thats already in the tube making the gap bigger. Failing that a sharp knife will cut the thread in half length ways. I hope that makes sense, a picture would explain it much better.
As to size I'm not sure exactly put its not a precision product and like ez line can vary in width along its length. This is worth remembering actually because looking for a thinner width piece to thread through the tube may save you a lot of time against loosing a few cm's of thicker thread.
oh and I almost forgot you can paint it but I left mine as it came. I would recommend using extra thin CA to fix it as this stuff has the consistency of water and sets immediately.
« Last Edit: February 28, 2013, 02:25:42 AM by gcn »
Re: WNW DH2
« Reply #23 on: February 28, 2013, 06:46:41 AM »
  Gary,
Thank you for the heads up on the knitting in elastic and the helpful tips in rigging with it. I'll have to see if I can find a simular product over on this side of the pond. Your rigging both with the EZ line and knitting in elastic is outstanding my friend. I appreciate your build thread for the DH-2 very much and plan to use it as a reference at some point for both my WNW and Roden DH-2's.
Offline gcn
Re: WNW DH2
« Reply #24 on: February 28, 2013, 09:12:33 AM »
Gregory if you can't get anything similar I'd quite happily buy a couple of reels and ship them out to you.
Just as long as you keep complimenting my builds  ;D
