Author Topic: 1/32 scale Wingnut Wings Halberstadt Cl.II (early) (Complete)  (Read 4610 times)
Offline Robin
Re: 1/32 scale Wingnut Wings Halberstadt Cl.II (early)
« Reply #30 on: July 02, 2025, 09:11:24 PM »
Sublime!
Robin  :)
« Reply #31 on: July 03, 2025, 06:20:15 AM »
Thanks for checking in Robin & Alexis.
Fantastic work so far on this project , have made notes on some of the fit of the parts . Have the late version in the stash .
Alexis - after working through this build I'm sure I could tackle my late version in half the time! I hope to summarize my findings at the end of the build since I believe the model builds up into a very attractive German two-seater with it's scheme & minimal rigging. And speaking of rigging I've been able to complete the first bit here with the top wing and undercarriage on. I've tried to leave off a large part of the breakable-offable bits to this point, because of all of the handling that takes place during the agony of rigging. I'm using EZ-Line and 1/48 Gaspatch turnbuckles Type C. Cheers!
Offline Richtrad
« Reply #32 on: July 03, 2025, 10:13:08 AM »
Wonderful work as usual Gary. Everything is great, especially the paint.
« Reply #33 on: July 04, 2025, 03:34:55 AM »
Thanks Warren - much appreciated.
One of the small tasks I had to figure out was that the water pipe leading from the radiator to the front of the engine was not quite long enough. A 1.0mm donut of styrene tubing was added as a fillet, and held in place drilling centered holes and adding a wire at the radiator end.
I tried a different approach to painting the exhaust manifold, spraying it with Alclad brass, then going over it lightly with diluted NATO black. This was followed before installation with some light grey pastel chalk powder. I'm less inclined to think that the exhaust piping rusted as badly as I see them sometimes portrayed.
The tail end of the aircraft had some very tricky rigging to do. The rudder itself had four control lines, each with a turnbuckle attached that barely fit the small distance before disappearing into the fuselage. The attachment points of the rudder (and ailerons) were pinned using small pieces of copper wire. They are very delicate and inevitable get bumped when I clumsily handle the model.
Pre-rigging photo of the underside with some oil paint weathering and the small fillet added to the coolant pipe to lengthen it by 1.0mm
Exhaust pipes base coated in brass, then oversprayed in diluted NATO black. Paste chalks added later.
A fair bit of faff was needed to get the tail section rigged with control lines. Both Gaspatch and RB Productions turnbuckles were used here.
« Reply #34 on: July 04, 2025, 08:05:39 AM »
Every added bit makes it more and more spectacular.
« Reply #35 on: July 04, 2025, 08:23:32 AM »
Thanks Prze - you're very kind  :)
I wanted to add a few extras to the upper wing as seen in photos of this aircraft. It featured a goal-post style of guard to prevent the MG gunner from shooting the propeller, and also a goose-neck pipe on the front of the radiator. To make the funnel-shaped end, I turned my DSPIAE sanding pen into a mini-lathe and made the required part with sprue of an appropriate diameter (3mm) using a #11 blade.
Brass wire and styrene tubing was also used for these details. Cheers!
The funnel shaped end was fashioned from kit sprue in my DSPIAE sanding pen.
The details on the upper wing to be painted by hand afterward. The funnel did turn out slightly larger than in the photos in retrospect, but it's adequate.
« Reply #36 on: July 04, 2025, 09:39:51 PM »
Very nice build. What a lovely Halberstadt.
« Reply #37 on: July 05, 2025, 12:09:55 AM »
My Halberstadt Cl.II is now complete, and for what it's worth I went through the instruction sheet and jotted down a few notes to summarize my build. Although I found this model a bit of a challenge at times, I have to say that when finished, it has a very attractive appearance and has to be my favourite of all the six German two-seaters I've built so far  (...well maybe except for my Taube!). I'll try and get a few photos posted in the Completed section of the Forum when time permits.
Build summary:
1. Seatbelts could use an improvement even if it's adding copper wire wound springs the the existing etched metal ones.
2. Eny enhancements to the engine need to be test-fitted since the space tolerances are very tight. The Barracuda studios insulated intake manifold, for example would not really work without a fight. The engine and it's mount are a tight fit and needs to be centered correctly so that there are no alignment issues later. I used small copper clamps to hold everything together when cementing the assembly.
It is essential to fit the engine mount into the slots of the fuselage on both sides to ensure the engine sits centered, and the frame fits over the front properly.
3. The forward firing MG08 fits very snug in it's allotted space, and has to be dead straight or it will interfere with the cowlings.
4. Part D-16 the tailplane & elevator fit on my build had to have the fuselage fittings trimmed away before it would fit straight in place. Because of this interferance, the thin elevator bowed upward at the outside ends until this was corrected.
5. Step 8 in the instruction sheet has the forward cabane struts added, but doesn't show where exactly and this was the major hitch on my build. A more accurate illustration is on the Late version instructions  (which I just looked at) available on-line if you don't have that kit.
6. The flash guard etched metal piece P3 is glued to the inside edge of the cowling part F13, then carefully bent at the top to fit over the intake manifold of the engine. I could only do this my positioning the assembly by the engine ...marking it with a felt tip pen, then somehow bending it around an appropriately sized drill bit. My coolant pipe was too short to fit between the front of the engine & radiator, and needed a 1mm styrene shim added. This was held in positioning by drilling centered holes and using a small wire to align & hold it together with cement. (Edit added) I had to install a fillet of styrene to fill a 0.8mm gap at the top front of where the cowlings meet.
7. The wheel hubs parts A43 need to be trimmed down so that they fit properly into the wheels. I never use the clip  part A1 allowing the wheels to turn unless one wants to play with their model in their sand pit. I cement the wheels together, paint them, and cement them in place after weathering.
8. The MG mount locking arm on part A80 should be separated and articulated by swinging it forward as seen in many period photos. I cut mine off and added a small wire pivot to allow this to be more authentic looking.
9. Reference photos and illustrations in the instruction guide seem to show more details present on these aircraft than the kit actually provides. The goose-neck pipe on the radiator front and propeller guard for the rear MG are good example of this (on my chosen aircraft) and there are enough clues provided to make a more accurate model if one chooses.
10. The WnW hints & tips on how to paint the stipple camo worked well, along with the previous builds I looked up here from fellow modellers. Some experimentation is needed since everyone's airbrush works differently, but I managed to spray a decent splatter with my cloudy yellow paint to thinner ration a bit thicker than normal (less dilute)  and a pressure of 9psi and the H&S airbrush nozzle opened a bit wider than normal...lots of variables.
Cheers!
« Last Edit: July 06, 2025, 02:38:46 AM by gedmundson »
Offline Umlaufmotor
Re: 1/32 scale Wingnut Wings Halberstadt Cl.II (early) (Complete)
« Reply #38 on: July 05, 2025, 05:14:33 AM »
Love it!
Really a very nicely built early version of the Halberstadt CL.II.
Very nice also the chosen decals scheme of the "Dora" with the Muenchner Kindl.
Also very nice are the fine details on the upper wing.
Servus
Bertl
« Last Edit: July 05, 2025, 06:47:31 AM by Umlaufmotor »
Offline Richtrad
« Reply #39 on: July 05, 2025, 07:14:11 AM »
A serious thanks for taking the time to document the tips and potential pitfalls Gary. If this kit were to be reissued in my lifetime :P I will certainly benefit from this thread.
Warren Q
« Reply #40 on: July 05, 2025, 10:01:27 PM »
What a nice build to follow! Very good results too, i hope you're happy with it!
« Reply #41 on: July 06, 2025, 02:45:05 AM »
Thanks Bertl, Warren & Fredrik - your comments are very much appreciated!
Warren Q
Thanks again Warren - I actually just added and edit to mention about adding a fillet of styrene where the cowlings didn't meet at the top at the front (no idea how that happened). As far as the availability of this model (or the late version) I certainly have seen a lot of modellers (collectors?) advertising their kits for sale as they realize they'll never make them, especially on Facebook. Maybe there's a chance one could find one without paying a high price on ebay for example.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #42 on: July 07, 2025, 05:21:07 PM »
What a stunning model you have created! Just beautiful!
Thanks for taking the time to add the notes for us to use on our own build  :)
To me the Halberstadt design is lovely and unique, I can see why you have it as one of your favorite 2 seaters  ;)
//Ben - @AngryJazz_Models
