Author Topic: 1:32nd scale Caudron G.3 (Anzani engine)  (Read 7559 times)
Re: 1:32nd scale Caudron G.3 (Anzani engine)
« Reply #60 on: July 17, 2025, 06:26:22 PM »
Wow, more amazed gasps from me. Wonderful rigging work!
« Reply #61 on: July 17, 2025, 10:47:16 PM »
More wing rigging completed.
Outer interplane strut incidence wires.
Outer lift strut incidence wires.
Outer lift strut bracing wires.
Twin wing warp control cables.
Single wing warp control cable.
Lower to upper wing bracing wires.
Now the basic wing rigging is finished, it's onto assembly again.
I need to fit the two tail booms and tailplane before I can complete the rigging on those components,
« Reply #62 on: July 19, 2025, 04:52:52 AM »
A bit more progress.
The tail booms and bracing struts are fitted.
The three different bracing wire sets for the lower wing to tail booms has also been completed.
The bracing wires from the lower wing back to the tail booms will be final rigged later, once the tail unit if fitted.
So now it's onto assembly of the tail unit,
« Reply #63 on: July 19, 2025, 06:16:18 AM »
Front end on its wheels,
« Reply #64 on: July 19, 2025, 06:34:37 AM »
Great job on that maze of cables.
« Reply #65 on: July 21, 2025, 08:27:08 AM »
The tailplane of this aircraft could be adjusted to either increase or decrease the angle of attack (AOA) of the tail unit.
Lifting the tailplane leading edge increased the AOA and lowering decreased the AOA.
Bracing struts were fitted between the tops of the king posts on the tail booms and the fins and also between the fins.
As the fin/rudder assemblies were fixed to the tailplane, if the AOA of the tailplane was altered, it meant the fin/rudders would move up or down with the tailplane.
Although the centre strut between the fins could be fixed in position, the outer struts attached between the fixed king posts and fins must have been able to move with the change in tailplane AOA.
With the tailplane AOA in the neutral position, the three struts would most likely be parallel to the tailplane when viewed from above.
If the AOA was increased the fins and therefore the outer struts would move up and rearwards.
If the AOA was decreased the fins and therefore the outer struts would move down and forwards.
My assumption therefore is that the end fittings of the outer struts must have been able to pivot to allow the struts to move as required.
This is all conjecture, but based on the fact that I used the optional photo-etch adjuster brackets and have the tailplane secure in the brackets at a decreased AOA.
This means that the fin end of the outer struts are slightly forwards when viewed from above.
As the distance between the king posts and fins is slightly increased, the kit supplied struts do not fully span the gap between them.
To avoid any problems for those who have not yet built their Caudron, I would advise having the tailplane AOA fixed in the neutral position to allow the struts to fit correctly and be parallel to the tailplane.
« Reply #66 on: July 21, 2025, 06:39:29 PM »
This is looking superb and many thanks for sharing your helpful advice. Your build logs are all a treasure trove of great advice!
« Reply #67 on: July 25, 2025, 12:45:30 AM »
Well, the rigging of the Caudron is finally complete.
I didn't post any more shots of rigging progress as there was too much.
Anyway, here's a couple of general shots.
I've just got the propeller, instruments and windscreen to fit to complete the basic model.
Then it's onto the figures and display case,
« Reply #68 on: July 25, 2025, 08:15:05 PM »
That's looking really good Mike, looking forward to the final touches. A masterwork in precise rigging!
« Reply #69 on: July 27, 2025, 06:43:55 AM »
You never fail to amaze me, Mike.
Truly spectacular work.  :o
BB
« Reply #70 on: July 30, 2025, 04:57:15 AM »
A few shots of the figures and accessories.
Both figures are from 'Kellerkind Miniatures'.
The crate and can are from my spares collection,
« Reply #71 on: August 01, 2025, 05:24:36 AM »
The Caudron will be up in the Completed Modeles page later this evening.
Once again, thanks for your support and comments throughout this build,
« Reply #72 on: August 14, 2025, 03:07:18 AM »
Very inspiring build Mike. I?ll be saving this for reference for sure!
All the best,
Tim
