Author Topic: 1/32 WnW Sopwith Triplane (done)  (Read 4169 times)
Re: 1/32 WnW Sopwith Triplane
« Reply #15 on: April 28, 2025, 01:48:12 AM »
Fantastic Triplane in the making. I also love the idea how to align the dots on the metal parts. I will keep that in mind.
« Reply #16 on: April 28, 2025, 07:18:44 PM »
This is looking very nice indeed. Your approach to the turned metal effect is brilliant and works really well IMO, bravo!
« Reply #17 on: April 29, 2025, 10:19:59 PM »
Thanks Andreas & Nigel. Trying to find a suitable screen for that task was the hardest part of that exercise.
If possible, I've found it preferrable to paint on my roundels using masks. I have used Montex masks for a couple of Spitfire models in the past which worked well, but purchased a fairly expensive cutting tool to help make my own. The DSPIAE cutting tool is a bit more refined than the Flex-I-File compass cutter I was using previously, and has a large bearing to guide a spring-mounted blade. To cut concentric circles, the tool has to be placed over the mask in exactly the same position in between blade adjustments, for which they sell a "Locator". I made my own positioning guide using a small square clamped to the bench and it works fairly well.
Masks were cut for the wing & fuselage roundels, and painted using mixes of off-white, Red with a touch of Red Brown, and XF-8 out of the bottle. Cheers!
« Reply #18 on: April 30, 2025, 04:06:53 AM »
Nice job! That circle cutter really is the business (once you master getting the tension of the spring right....).
« Reply #19 on: May 01, 2025, 02:19:20 PM »
I agree about that spring tension, Nigel. I was almost ready to take the thing back until I figured out how that worked...with no instructions it took me a bit of playing around with it to figure things out.
Continuing with my build, I knew there was a very slight "ghost seam" down the spine of the fuselage. But dealing with it was not that necessary, I had decided. It was only visible under certain lighting...but there it was staring at me. That seam grated on me for a while to the point where - always late in the game - I decided to actually do something about it. At the risk of causing more damage than I was fixing...the sandpaper and putty came out, and I tackled it as carefully as possible not to mar any of the surrounding finish & decals. Glad I did, and am continuing with the rigging. Lesson learned. Cheers!
The seam was sanded down with fine sandpaper sticks.
Taping off the area close to the seam, I laid down a couple of beads of Mr, Surfacer 1000 and let it dry for 24 hrs.
After sanding the area down with a number of fine sanding sticks, the area was repainted and rigging work continued.
« Reply #20 on: May 01, 2025, 06:13:45 PM »
Ghost seams can often come back to haunt you......at least this one won't! Well worth the effort.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #21 on: May 02, 2025, 05:52:24 AM »
Stunning work! I'm impressed how quickly you are moving through the build - all while making it looks amazing!
Also great work on the seam, getting the colors blended in afterwards - flawless!  :)
//Ben - @AngryJazz_Models
« Reply #22 on: May 02, 2025, 11:52:08 AM »
Lovely work again Gary!
Starting into a "valuable" model is somewhat daunting, but I always think a kit is just a box of plastic parts waiting to be turned into a nice replica of something.
I know it's not my kit (and money) but I'm another who's glad to see you building it.
« Reply #23 on: May 03, 2025, 01:26:32 PM »
Thank you Nigel, Ben & Zac.
I've spent a bit of time weathering the lower surfaces of the aircraft, and decided to add lighter paint to the rib tapes of the wings based on studying the period photos. I also had to cut the WnW decal sections to make the correct serial number stencils found under the wings & tail sections...very microscopic work.
Cheers!
« Reply #24 on: May 03, 2025, 06:30:23 PM »
This is coming along very nicely, I like your weathering so far.
Offline hrcoleman66
« Reply #25 on: May 04, 2025, 09:07:28 AM »
I don't think you had any worries about doing this "Valuable" kit justice.
I've always had a soft spot for the Triplane.  But I'm a little conflicted.  Most full size examples were finished in a more brownish PC12, which I can't bring my self to finish a model in.  I built the old Eduard kit many years ago but have never ventured into building a larger scale version.
I did have this WNW kit in my stash for a short time and have another Eduard example still in my stash.
I have the 140 odd ribs needed to build a 1/6 scale RC version sitting in my workshop, waiting to be grafted to an old now defunct Balsa USA Pup fuselage as well.
Looking forward to seeing your finished model.
Hugh
« Reply #26 on: May 04, 2025, 10:41:51 AM »
Hugh
Well thanks Hugh, you have brought up a very interesting point and are the first to mention it. I spent a long time debating how to paint this aircraft and certainly feel the same as you...I really find that brownish PC12 a very unattractive finish to any of the late war British aircraft. I built Barker's early Snipe a while back and painted it in the brown PC12 and it now sits in a box out of sight since I'm just not at all pleased with the colour. At the risk of it being inaccurate I chose a more "green" mix to my finish on this one and am happy with it. Good luck with your 1/6 RC version - sounds very cool indeed. Cheers!
« Reply #27 on: May 05, 2025, 06:25:29 AM »
Another great model in the making. Really lovely!
« Reply #28 on: May 05, 2025, 03:10:27 PM »
Good choice to go back and sort out that seam, even if most viewers probably wouldn't know the difference.
Looks good!
Online Richtrad
« Reply #29 on: May 05, 2025, 03:20:03 PM »
Gary: Continued inspirational work, and very brave to redo the seam. I see you had hand mixed your PC10. How do you match the custom mix for the redo?  I've tried keeping tabs on ratios like 5 drops yellow and 1 drop red, but can never exactly repeat the hue. Yours looks spot on as usual. Any ideas are much appreciated.
Warren Q
