Author Topic: DH.9a Ninak (Post War), Wingnut Wings 1/32  (Read 6788 times)
Re: DH.9a Ninak (Post War), Wingnut Wings 1/32
« Reply #30 on: May 16, 2025, 05:24:39 PM »
Just caught up on this one. Lovely interior, great progress.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #31 on: May 16, 2025, 10:37:11 PM »
Thanks Fredrik, Borsos and Sandy  ;D
Work had me traveling to Italy this week, so not much modeling has been done... but I did get some great hours with colleagues  :)
Before I left I managed to get the Ninak primed and base coated.
I mixed AK Extreme matte aluminium with AK Realcolor Medium Grey to get the doped aluminium color(2 to 1 ratio). It could maybe have been a bit more shiny, but after some varnish I think it will be close enough.
Today I masked and painted the aluminum and red parts. Next up is some detail painting of brackets etc.
//Ben - @AngryJazz_Models
« Reply #32 on: May 17, 2025, 01:41:40 AM »
Interesting Jazz .....
« Reply #33 on: May 17, 2025, 06:04:13 PM »
Good progress here, this is going to look very impressive when done.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #34 on: May 28, 2025, 04:39:03 AM »
Thanks for the comments  :)
Been a while since the last update. I have just slowly been working on the Ninak.
Got all the small details painted.
Decals applied... Was a disaster... just like my Dolphin build. Decals were very brittle, so they cracked if you touched them too much.
They did not react to Microsol... Well not until I heated a lot with a hairdryer on MAX  ::)
Then it was many rounds of heating... Microsol.. rest... repeat.
After semi gloss varnish I shaded the ribs with a black / brown mix.
It looked a bit too strong so went back with the base color to tone it down. It still looks a bit strong, but the black is very hard to cover up. So I will remember this next time  ;D
Well it's not too bad now... its workable. The camera makes it look worse than it is.
Next is pin wash / oils and assembly before starting the rigging and attaching the wings.
Offline Allan31
« Reply #35 on: May 28, 2025, 12:45:35 PM »
Now THAT is looking splendid !!
« Reply #36 on: May 28, 2025, 05:54:59 PM »
I have always considered DH.9a in silver livery as spectacular models. Yours is no exception.
« Reply #37 on: May 28, 2025, 06:33:53 PM »
Those damn WNW decals! What a pain, but you got them looking OK. This is going to be a very impressive and colourful build. The rib taping effect is a bit strong for my liking but as you say it's a lesson learned. Still a lovely looking build.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #38 on: May 28, 2025, 06:40:34 PM »
Thank you very much Allan, Przemol and Nigel  :)
I fully agree on it being a bit too strong of an effect, but i'm not sure I want to press my luck further now that the decals are on.
I have hit a small problem and could use a tip or two.
My Modelkasten rigging can't go through the RAF turnbuckles 1/48.... I can get my 0,12mm fishing line through but its not flexible...
Should I order the 1/32 Turnbuckles?
Or else im thinking about ordering some Modelkasten 1/350 line... Its 0,1mm in diameter, so should in theory fit.
Alternative is Infinimodel 1/48 rigging line (0,082mm)... But im not sure if this brand is "round" when stretched like Modelkasten?
Offline acewwi
« Reply #39 on: May 28, 2025, 07:25:36 PM »
Hi Ben,
try the following combination:
1/32 Turnbuckles (resin) - PRYM (flat elastic thread).
Spyros
Offline AngryJazz
    • @AngryJazz_Models
« Reply #40 on: May 29, 2025, 04:46:10 PM »
Thank you Spyros, I have ordered come 1/32 turnbuckles.
To not waste my 1/48 turnbuckles I have ordered some 1/48 Infinimodel rigging line to try out.
I will look for the Prym line too.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #41 on: June 03, 2025, 06:42:55 AM »
I got my order pretty fast!
The good news is that Modelkasten 0,13mm line fits easily on the 1/32 turnbuckles. However the 1/32 do look a bit oversized to my eye... They can work, but yeah.
The 1/48 Infini model rigging does not fit the smaller 1/48 turnbuckles... A line up to 0,1mm should fit (noticed there was a guide in the box  :-[), but they don't(0,082mm). It doesn't help the line is very flexible so it can't be forced in like say a fishing line.
A smaller Modelkasten line may work... They are a bit more rigid, but i'm not sure i'll spend another 60? to test it  ???
Apart from drilling through the wings to be able to tighten the fishing line with 1/48 turnbuckles - i'm not sure how to do it. I may go with the 1/32 or even skip the turnbuckle.
Size difference
Guide
Edit a picture of the primed 1/32 turnbuckle on the wing for refference
« Last Edit: June 03, 2025, 06:49:36 AM by AngryJazz »
« Reply #42 on: June 03, 2025, 10:52:06 AM »
There are magnificent builds on here where things like same-scale turnbuckles (and linen decals) take me out of, for lack of better words, my suspension of disbelief that making a model attempts to achieve. They strike me as being too big, but I speak from (I believe) the reverse perspective of many modellers where I've seen 1/1 turnbuckles in use on WW1 aircraft in up close and personal far, far more than I've worked on replicating them in 1/32. So the idea of using 1/48 turnbuckles appeals to me...but then you've struck this issue! I hope you're able to find a solution as this model really deserves it.
« Reply #43 on: June 03, 2025, 03:06:27 PM »
Hi,
I've used the 1/48 version with 0.1 mm fishing line and I think I used a metal wire of the right diameter to clear the path, so to speak. I suspect that the elastic thread you're using is the main problem.
Good work though and I don't think you'll find the 1/32 scale version odd, once it's all done.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #44 on: June 03, 2025, 03:30:42 PM »
@Zac - Thanks for your input. I may be overthink the issue and the 1/32 will be fine once in place.
@Fredrik - thanks for your suggestion. I found the fishing line is perfect for 1/48, but getting the line tight enough may be hard.
Im sure I will think of a perfect solution once im done with the rigging  ;D
By the way the Infinimodel 1/48 rigging line is slightly flat and not round. Just if anyone needs to know for future builds.
