Author Topic: WnW Sopwith Pup RNAS  (Read 5586 times)
Offline Kreston
Re: WnW Sopwith Pup RNAS
« Reply #30 on: March 09, 2025, 01:46:36 AM »
The cowling looks fantastic!
Kreston
« Reply #31 on: March 09, 2025, 05:47:55 AM »
That's looking really good. I too like the cowling, very realistic. It's worth spending time on the weathering IMO and this is looking good so far.
« Reply #32 on: March 12, 2025, 12:47:45 AM »
Kreston & Nigel - thanks for that!
Nigel - I certainly agree. I spend more time weathering a model than I do the overall painting, and always feel like I've never done enough when finished.
After placing some tiny copper loops into the struts and fixing in the MG mount & windscreen, I'm ready to glue on the upper wing and rig this puppy  ;)
Cheers!
Offline DaddyO
« Reply #33 on: March 12, 2025, 01:27:40 AM »
Brilliant work on this one so far. Just loving following along with your progress  8)
« Reply #34 on: March 12, 2025, 01:51:41 AM »
Always learn something following your work , just fantastic !
« Reply #35 on: March 12, 2025, 05:03:31 AM »
Awesome!
« Reply #36 on: March 12, 2025, 07:09:00 PM »
That close up looks fantastic, lovely work.
« Reply #37 on: March 12, 2025, 08:16:19 PM »
Totally agree
« Reply #38 on: March 13, 2025, 07:11:38 AM »
Thanks for that Alexis - glad to see you back here. Thanks also to Nigel, Paul, Rick & andonio64 for the kind remarks.
No pics yet - but the top wing went on OK and the rigging is going slowly and all the cursing in the world doesn't help. I'm using a new brand from Japan called QW Model becasue I could not source either EZ-Line or ModelKasten at the time.
Offline Allan31
« Reply #39 on: March 13, 2025, 07:58:00 AM »
Nice job Gary, weathering looks perfect, you can't go too heavy with the castor...
« Reply #40 on: March 21, 2025, 07:49:43 PM »
Thanks Allan!
As I continued with the rigging I realized that although this model seemed simple & straightforward, it was not that easy to manage - or I am getting sloppy in my old age. I never did master the art of adding "flat RFC bracing wires", and have just used the elastic line for everything...except for the couple of tricky parts of the rear flying wires and tail skid control wires. Captions have been added to each photo.
Cheers!
After adding 1.5mm sections of 0.4mm diameter brass tubing, the lines were taped with tension after passing them through the copper loops, and then secured with tiny drops of cyano glue.
The wings were done first before continuing with the tail & landing gear. With all of the handling, I was glad to have painted on most of the markings and sealed all the surface with Future floor acrylic.
The instruction sheet has 10 control wires leading back from the cockpit, so there ends up being two pairs attached to the rudder control horn. I also added the tail skid wires from stretched sprue, which had to be repaired countless times as I manhandled the model during the process.
The rigging fasteners were painted dark grey and then highlighted with toned-down silver printers ink.
The rear flying wires pass through the lower wing and attach to the top of the landing gear legs. I made small ends from stretched sprue and brass tubing to emulate this, and made sure they lined up with the lines above the wing before gluing them in position and painting them.
The fairing behind the cowling has to be added AFTER the landing gear assembly is glued into position and can easily be forgotten later in the building stages (from what I have seen from WnW "Customers Models").
« Reply #41 on: March 21, 2025, 09:08:51 PM »
That's looking really good Gary, I love the way you have handled the rib tapes on the underside, they look really effective. Very nice work indeed!
Offline Allan31
« Reply #42 on: March 21, 2025, 10:07:25 PM »
This is looking splendid Gary. The way you handled the rib tapes both bottom and top is subtle and very realistic.
Great job on the engine turning sheet metal.
I for one would vote for more weathering as these little Pups were inherently incontinent but I guess this is the beginning of 6453s career.
« Reply #43 on: March 22, 2025, 12:34:28 AM »
The rigging looks Fantastic! Glad to see/hear that I am not the only one that falls back on Stretched sprue for some things that are difficult to rig otherwise!
PS: I have never bothered with the "Flat" RAF wires either. Not a lot of difference in scale. IMHO.
« Reply #44 on: March 22, 2025, 01:19:55 AM »
Thanks Rick, Alan & Nigel!
Nigel - I stole a page from a couple of Haris Ali articles and painted those lower rib tapes with a pass of Tamiya X-19 smoke. Lots of masking there but I wanted to try it. Haris also suggested a pass of lighter PC10 for the upper rib tapes which I also did, and I was happy with the effect. Always looking for new tricks  ;)
