Author Topic: airbrush spray booth - help needed  (Read 2864 times)
Offline s.e.charles
« on: January 03, 2025, 07:47:07 AM »
yes; i did. but after the first 10 responses i realized the fool's errand.
so here we are now:
what type of spray booth do we like for airbrushing?
if you made one, please share how & what components.
thanks
Re: airbrush spray booth - help needed
« Reply #1 on: January 05, 2025, 03:00:58 AM »
OK, I really don't understand the first part of your post, but I use a Mr. Hobby Spray Booth enclosed in a wooden box on my bench. Pardon the mess:
« Reply #2 on: January 05, 2025, 03:36:02 AM »
I use the portable one that's all over the internet, just Google portable airbrush booth. Works fine but it's not massive. You can fit 1/32 two-seaters in it.
« Reply #3 on: January 05, 2025, 08:14:57 AM »
I once bought a cheap one via Amazon. I am still happy with it.
https://amzn.eu/d/dxdPZJ0
« Reply #4 on: January 05, 2025, 08:31:35 PM »
That's the same as mine, except I have an extractor hose out the back (which I stick out the window).
Offline DaddyO
« Reply #5 on: January 05, 2025, 09:25:28 PM »
Yep same here. Seems to do the job nicely and the filter can be easily replaced with new foam filter that is either available on the roll or cut to size.
« Reply #6 on: January 05, 2025, 10:57:32 PM »
I had thought about that but I knew myself being too lazy to open my window every time which is far over my working table almost out of reach?
Offline s.e.charles
« Reply #7 on: January 10, 2025, 11:41:24 PM »
OK, I really don't understand the first part of your post,  . . . .
there's always someone whose knee-jerk response is to "i googled it and found xx amount of reviews"
if i wanted that, i would not have asked here for suggestions.
and yet, still it happened, albeit a tad downward than anticipated.
thanks for the inputs. i have pretty much resigned myself to the Paasche HSSB-22 despite its shortcomings. it will at least provide a good carcass for subsequent improvements should
they be undertaken. on web, it's anywhere from 525$ to 290$ US dollars depending on the source/ supplier.
« Reply #8 on: January 10, 2025, 11:47:08 PM »
Pardon me for not understanding and trying to answer your question then.
« Reply #9 on: January 11, 2025, 05:09:51 AM »
Hmmm, so you don't like people confirming that they use the ones you found in your Google search. Apologies.
