Author Topic: 1/72 Spad XIII Madon  (Read 6398 times)
Re: 1/72 Spad XIII Madon
« Reply #30 on: July 25, 2024, 02:28:12 AM »
Pic of model on a base with a pilot
Paul,
        How did you deal with the flying and landing wires and the "H" struts in the middle?
Offline DaddyO
« Reply #31 on: July 25, 2024, 02:58:30 AM »
Hi Warren
Inner 'H' struts were made the same as the outers using soldered brass; I used a slightly narrower upright (a bit more filing to make them appear slimmer) and soldered a piece of 0.4mm brass wire as the cross piece which was 'fun' :P although once done and excess solder cleaned off it's surprisingly strong.
Flying wires are just my usual fishing line (1lb) with two holes drilled in the wing surfaces close together.
I did the crossed lines on the inner struts first and made sure they were secure and then did the main flying and landing lines by feeding the inner one inside the H strut and the outer one outside the H strut. Definitely a fiddly job that needed an optivisor :o
Hope that helps
« Reply #32 on: July 25, 2024, 09:22:21 AM »
Hope that helps
Yes it does, thank you very much.
Offline ScottJ
« Reply #33 on: August 01, 2024, 12:13:02 PM »
Great looking SPAD... really enjoyed the subject you chose.  Red can be a tricky color to get it so it looks "right", especially in 1/72.  Yours looks excellent.  Always enjoy seeing what you will put up next... whether it's getting ready to fly the dawn patrol or walking around kicking the tires, you put out an excellent product.
Take care
Scott
E.P. Janney?
Offline DaddyO
« Reply #34 on: August 01, 2024, 05:51:55 PM »
Many thanks Scott.  ;D
(Next up after the Pfalz is likely to be a twin bay aircraft since I've not done one before - so many beautiful early war designs or perhaps something big and 'brutal' looking such as an AK8 or Salmson)  ;)
« Reply #35 on: August 14, 2024, 04:44:48 AM »
Got to agree with all that has been written. Those extras are truly tiny so you have done really well to incorporate them in the model. Super model in the Correct Scale.
Offline DaddyO
« Reply #36 on: August 14, 2024, 05:10:42 AM »
Cheers Stephen.  ;D
Offline Pep111
« Reply #37 on: August 18, 2024, 08:25:19 AM »
That is A great looking Spad!
I could never imagine myself attempting something that small.
Well done Sir
Offline DaddyO
« Reply #38 on: August 18, 2024, 05:04:04 PM »
 ;D
Thanks Pep111 - Bit of a fiddle so I built up some experience on simpler builds first, but since I had a bunch on the shelf I decided to have a go and see what happened.
In truth I made it difficult for myself by making the struts from brass and swapping out the guns. They are a really nice kit and go together well if you take care when fitting the cockpit details (they might need a scrape/sand to ensure the fuselage top fits well) A small jig helped putting the top wing on for me, but plenty of folks could manage without
Do have a go at one. The early versions are easier to paint and the decals adding splashes of colour  :)
