Author Topic: Phonix DI  (Read 20555 times)
Re: Phonix DI
« Reply #75 on: August 10, 2024, 12:43:24 AM »
Really impressive rigging technique! Lovely biplane!
Offline DMPopa
Re: Phonix DI
« Reply #76 on: August 14, 2024, 09:32:58 AM »
The landing gear struts are made from K&S 3/64 Brass Rod #5161 which are wrapped in an under layer of velum paper and a layer of velum paper is added on top and subsequently painted green primer from the rattle can.  I chose the K&S brass rod as I wanted a material that is larger in diameter and easier to bend than music wire, but stiffer than common wire.   The thicker brass rod will provide more bearing area to the hole drilled in the fuselage to accept it making everything more stable and sturdier than other methods.
This is the first layer:
This is the second layer, painted.  Also shown is the axle which is two layers of paper velum wrapped around .032 music wire.   Here the smaller diameter is desired to facilitate fitting into the wheels.
The tires are made per the kit, two rings of thick cardboard with a solid disk in the middle.  Ready Patch is used as the glace to smooth out the tire.  After sanding and adding more ready path between coats of dark grey primer from a rattle can, below are the results.  A hole is drilled to accept the .032 music wire.
Holes are drilled in the bottom of the fuselage to accept the struts brass rods.
The bungie cords are modelled with Beadalou Elasticity .032 diameter stretch cord and a lot of super glue.
This is the result with the wheels (with wheel covers) added, the stretch cord trimmed, and the support wires added with EZ line and turnbuckles modeled with velum paper as described in an earlier post.
Offline NinetythirdLiberator
Re: Phonix DI
« Reply #77 on: August 14, 2024, 11:59:13 AM »
Landing gear coming along nicely!  Cool bungees too.
Dan
Re: Phonix DI
« Reply #78 on: August 15, 2024, 06:33:32 PM »
Very nice work, this is coming toghether well.
Offline DMPopa
Re: Phonix DI
« Reply #79 on: August 16, 2024, 05:22:26 AM »
The propellor is made per the kit and the propellor repaint is a good rendering.   The propellor consists of a center disk and the two blades.  Rolled up paper is added to the disk, a propeller shaft modelled in .032" music wire is added and the rolled-up paper helps to stabilize this music wire.
The tail skid and radiator on the upper wing are added.   The wind speed indicator included in the kit is not added as this small device is crazy small to model.
Below are pictures of the completed Phonix DI
Re: Phonix DI
« Reply #80 on: August 16, 2024, 07:16:10 AM »
I always liked that machine.  Your model turned out great!  Nice job, my Paper Brother...Dan
Re: Phonix DI
« Reply #81 on: August 16, 2024, 05:36:27 PM »
Well done, this was a LOT of work and it turned out really well. Very nice looking end result!
Re: Phonix DI
« Reply #82 on: August 22, 2024, 05:19:31 AM »
Stunning results! I have enjoyed following your build!
