Author Topic: Scratch build DFW Mars  (Read 10136 times)
Offline AngryJazz
    • @AngryJazz_Models
Re: Scratch build DFW Mars
« Reply #15 on: July 29, 2024, 04:44:08 PM »
Great progress! Really like how it's shaping up  :)
//Ben - @AngryJazz_Models
« Reply #16 on: July 29, 2024, 05:02:12 PM »
Really starting to take shape, Stephen.
Great stuff.
« Reply #17 on: July 29, 2024, 06:10:10 PM »
More wows from me, that is looking fantastic so far. Really looking forward to seeing this interesting subject come to life.
Offline Dirigible-Al
« Reply #18 on: July 30, 2024, 05:06:00 AM »
Inspiring as usual.
Alan.
« Reply #19 on: July 30, 2024, 05:16:58 AM »
That is really impressive work on the fuselage and cockpit openings! Wings are looking great. You are well on your way to another Magnificent build!
« Reply #20 on: July 30, 2024, 06:33:30 AM »
I love the stage where all the individual bits come together and start looking like an aeroplane. Really enjoying following along with your progress.
« Reply #21 on: August 13, 2024, 04:33:10 AM »
Evening All,
Thanks to all of you for the very kind remarks. I am sorry to write that I have not been following the GB as closely as I would have liked to have done: life and other events have been a constant distraction from modelling for most of this year, and it is sapping my energy and motivation. Your very supportive comments have really helped me to keep going and I have been plodding along as and when I have felt able to and can report some worthwhile progress at last
After I had joined the upper wing halves I succeeded in painting the model - the white took several coats as I had thinned the paint and had to keep applying layers to hide the filler! The black of the fuselage by contrast was much easier, but because I do not like painting the whole process seemed to take a very long time:
I cemented the lower wing to fuselage struts in place before I attempted to fit the upper wing. The fuel tank was attached to the upper wing but fixing the upper wing to the lower wing and fuselage presented more of a challenge than some biplanes because the inter-plane struts had a large angle of stagger. However a simple pair of card jigs solved the problem by supporting the upper wing while I inserted the outboard struts:
The cabane struts were not painted prior to fitting because I forgot to! They were cut to the required length from shaped Evergreen strip as were the other struts. I used 25 thou rod for the wing skids:
The struts underneath the tail were added from 30 thou rod. The main undercarriage structure was made from 20 x 30 strip, filed to aerofoil shape and the thinner inner bracing was made from 25 thou rod. This was assembled by attaching the main lags first and then inserting the rod and gently pulling the structure together and supporting ithe legs with small strips of wood while the cement set. The result looks like this:
There are more details to add before I can rig the model but at last I can see the end in sight.
Thanks for looking.
« Reply #22 on: August 13, 2024, 04:44:53 AM »
I am sorry that things have been distracting you and hope it is nothing Major! That being said your Mars is looking terrific as a biplane. The paintwork came out nicely. I also always love your jigs and can certainly see why they were needed on this one!
« Reply #23 on: August 13, 2024, 06:06:29 PM »
Life often gets in the way of things like modelling so it's great to see you back on this one making substantial and very impressive progress. This is looking fantastic, there's some great modelling and problem solving going on here and it's fantastic to see this scratchbuild of a really interesting subject coming together. Keep us updated as and when you can and I hope modelling provides some brief respites from the pressures of everyday life.
« Reply #24 on: August 14, 2024, 01:59:48 AM »
Hello Stephen, it's really great you are able to crack on with this. That said, despite your distractions, your moving this on quicker than I would be, scratch building is sooooo muchhh lonnnngerrr than kit building.
Alan
Offline Flamingo
« Reply #25 on: August 14, 2024, 06:46:24 PM »
Starting to look like the real thing!
Regards Joachim
jets are for kids
Offline AngryJazz
    • @AngryJazz_Models
« Reply #26 on: August 19, 2024, 06:51:25 PM »
Great work! Im always amazed what you scratch building guys are able to pull off  ;D
« Reply #27 on: August 31, 2024, 04:40:50 AM »
Evening All,
The last parts have been added to the Mars and I have rigged it with rolled copper wire as per normal for my small scale models.
The axles for the wheels were cut from a paper clip and the wheels CA'd to the ends of the axles after the axles had been passed through holes drilled in the undercarriage legs. The small tail incidence wheel was made from thin rod wrapped around a paintbrush handle and immersed in very hot water, with the spokes of the wheel cut from 10 x 20 thou strip. The model was rigged over several days because I either lacked the time or energy to complete it more rapidly. Finally I glued the propellor to the nose:
I will post more photos in the completed models section shortly.
Thanks for looking.
Offline torbiorn
« Reply #28 on: August 31, 2024, 07:03:23 AM »
I’m afraid I have missed this thread. Like you I have been distracted from the hobby, including taking part in forums. Great work, I’m glad you foubd the time and motivation. It’s a curious looking type I had never seen before :) There is not a lot of models of types from just before the war. The rigging looks tricky, it was wise not to rush!
« Reply #29 on: August 31, 2024, 09:12:56 AM »
That is one of your most stunning builds, in my opinion! I think it is a very fitting tribute. Simply gorgeous and the rigging is incredible!
