Author Topic: Jeannin Stahltaube - a scratchbuild in 1/144 scale  (Read 37068 times)
Offline MR Bentley
    • My Instagram feed
Re: Jeannin Stahltaube - a scratchbuild in 1/144 scale
« Reply #60 on: May 28, 2024, 08:17:11 PM »
This is seriously incredible. Good job!
Offline Dirigible-Al
« Reply #61 on: May 28, 2024, 11:31:23 PM »
That's an incredible piece of workmanship. Seeing it dry fitted together shows just what a beautiful aircraft this was.
Alan.
« Reply #62 on: May 29, 2024, 03:07:59 AM »
Just incredible work in this tiny scale ............
Offline AngryJazz
    • @AngryJazz_Models
« Reply #63 on: May 30, 2024, 06:43:33 PM »
Wow im amazed how you are able to create the shapes! Just WOW!
//Ben - @AngryJazz_Models
« Reply #64 on: June 04, 2024, 07:37:03 PM »
Top notch work again William!
Makes me curious to the tools you use....
« Reply #65 on: June 04, 2024, 07:57:08 PM »
Gobsmacked!
Offline Thumbs up
« Reply #66 on: June 05, 2024, 03:40:28 AM »
A masking masterclass!
« Reply #67 on: June 07, 2024, 06:56:25 PM »
Seeing that last photo made me absolutely speechless.
Offline William Adair
« Reply #68 on: June 10, 2024, 01:00:21 AM »
Thank you everybody for your kind words. It helps keep me going!
Here is the latest on the taube. Over the last couple of weeks, I've been pecking away at the cockpit details. I often had to refer to photographs of WNW builds for reference and dimensions, so some of the parts may look familiar to those who own the 1/32 kit.
The cockpits have quite large openings, so a lot of the interior will be visible. There are still quite a lot of parts to go yet, so hopefully I can get it looking very busy by the time it is done.
I'm a little bit stuck on the colour of the sidewalls inside the cockpits however and hoped to ask the advice of any resident experten.  I'm planning to do Stahltaube A.283/14 which had a dark fuselage very similar to RLM Grey (Tamiya XF-22).  To tried and represent the plain interior fabric with a coat of grey on the outside, I have started with a light CDL colour, then given it a sort of speckly overspray of darker tones to depict the bleed of grey paint from the exterior (sample swatch below).
I applied this colour to the cockpit, but it suddenly occured to me that the German aviation industry might have applied one or more base coats of Clear dope first, the same as the British did, before adding a pigmented top coat. If this was the case, I would expect the interior fabric to be lighter than what I have done below. I'm also ludicrously colour blind too, so if anyone can tell me if it is too light or too dark, or too pink or too green... I will be forever in your debt!
Offline Thumbs up
« Reply #69 on: June 10, 2024, 02:41:19 AM »
[/quote
Tom Thumb lent him his toolbox!
« Reply #70 on: June 10, 2024, 03:50:55 AM »
 ;D
Offline ondra
« Reply #71 on: June 10, 2024, 04:18:12 AM »
No idea about the right shade, but I have to say the interior parts look tremendous.
Thumbs up from Yoda. ;)
Ondra
« Reply #72 on: June 10, 2024, 11:01:56 AM »
What Ondra said, I have no idea and it looks wonderful.
To quote Lawrence Welk, "Wonnerful, Wonnerful!"  ;)
« Reply #73 on: June 10, 2024, 11:24:01 AM »
 ;D ;D ;D
Thank you sensei! I tried to keep the wood grain effect in scale and it seemed to work better this time. I'm looking forward to trying it on a plywood fuselage one day.
« Reply #74 on: June 10, 2024, 11:25:44 AM »
Hey thanks Warren!  :)  I always second-guess myself when it comes to colours. I wish I had the knack.
