Author Topic: 1:48th scale Sopwith Camel  (Read 4810 times)
Re: 1:48th scale Sopwith Camel
« Reply #15 on: November 28, 2024, 05:47:23 AM »
Weathering applied using 'Flory Models' Dark Dirt wash.
Overspayed with 'Alclad' Light Sheen (ALC-311).
Now its onto the pre-rigging!!
« Reply #16 on: November 28, 2024, 06:21:49 AM »
I wonder what serial number you'll be giving this Mike.
Corgi etc have May's Camel as D3326 but the Camel File from Air Britain (The Bible as far as I'm concerned) has it as D3328.
I wonder what's in the Eduard kit.
Hi Sandy,
This aircraft was indeed Serial No.D3228.
Below is what 'Eduard' say about this aircraft.
Camel D3328 was built at the Clayton Shuttleworth factory and served with No. 9(N) Sqn RNAS from March 12, 1918.
The unit was redesignated No. 209 Sqn RAF from April 1, 1918.
On April 21,1918, "Wop" May was flying this Camel during the epic dogfight, which ended with the death of Manfred von Richthofen.
May was the pilot the Red Baron attacked before he himself was hit by fire from Capt. Brown, ground machine gunners, or both.
There is no photo of the whole aircraft.
One close-up photo shows May in the cockpit of the aircraft with the LUCY inscription.
The photo was taken in the second half of April, it is therefore possible that D3328 was so named.
In another photograph, the first in the line of the No. 209 Sqn Camels is an aircraft with a combination of white fuselage stripes and a fuselage cockade.
Some Camels of the Squadron only had stripes on the fuselage, we opted for a more attractive version for the D3328.
The serial numbers of the aircraft, which had them painted on the fin, disappeared under the red color paint, which along with the red nose was the squadron's distinctive coloring.
« Reply #17 on: November 30, 2024, 02:49:50 AM »
Excellent stuff, Mike.
FYI here is the rest of the Camel's story, from the Air-Britain File
S
« Last Edit: November 30, 2024, 02:54:56 AM by macsporran »
« Reply #18 on: November 30, 2024, 09:31:02 PM »
Hi Sandy,
As this model is 1:48th scale, I'll not be writing a build log (just for 1:32nd scale models).
However, this is interesting information  - thanks.
I have the Air Britain edition for the SE5, but not the Camel,
« Reply #19 on: December 01, 2024, 04:19:04 AM »
The interplane and cabane struts are fitted.
Also the windscreen, gun sight and gun cooling jackets fitted.
Landing gear bracing wires fitted and upper wing pre-rigged with 0.12 mm diameter mono-filament.
Next is to fit the upper wing onto the struts,
« Reply #20 on: December 02, 2024, 07:46:50 PM »
Good progress Mike, that is looking very nice indeed.
« Reply #21 on: December 05, 2024, 10:09:03 PM »
Great progress.
One doubt, though - the interplane struts were dead parallel in Camel and in your model they seem not to be.
« Reply #22 on: December 05, 2024, 11:29:18 PM »
Great progress.
Hi PrzemoL,
It does look that way in that photograph.
However, the struts were only partially cemented in the lower wing until the upper wing was located.
With the upper wing fitted, the struts were fully cemented.
As you can see the struts are all correct,
« Reply #23 on: December 05, 2024, 11:46:43 PM »
It is indeed excellent, the earlier photo must have been distorted.
Again - great progress, Mike!
« Reply #24 on: December 06, 2024, 07:29:24 PM »
Looking very good Mike, I do like the wood tones on this one. Very nice.
« Reply #25 on: December 15, 2024, 06:13:56 AM »
The aircraft model is complete.
Rigged with 0.08 mm diameter mono-filament.
I added tie down rings to the lower wings.
Also the pitot static tubes and pipe from the Rotherham pump on the landing gear.
Now onto the figures and display case,
« Reply #26 on: December 15, 2024, 07:52:23 PM »
Lovely job Mike, that's turned out really well. Nice job on a nice kit!
« Reply #27 on: December 18, 2024, 12:26:41 AM »
The 1/48th scale figures are completed.
Both are from 'Model Cellar',
« Reply #28 on: December 20, 2024, 02:32:06 AM »
The completed model is now in the 'Completed Models' page.
Thanks for your support and comments throughout this build,
