Author Topic: Albatros DV - Ace of Hearts  (Read 7362 times)
Offline drdave
Re: Albatros DV - Ace of Hearts
« Reply #15 on: February 10, 2013, 08:56:57 PM »
Wonderful work. Love the wood grain.
Offline KANiles
« Reply #16 on: February 10, 2013, 09:15:55 PM »
Ken, excellent work and great to see all those particular techniques used. With the wood effect decal explosion out there its nice to see the "old" way of doing it executed so well.
Steve,
I'm so new to this "posting thing," I hope I do this  response correctly and I hope others haven't taken offense that I had not replied to their kind comments earlier than this.
I've not seen any decals applications for wood grain in person ( model shows, etc.) but have seen it used many times on forums such as this. They do look good, no doubt. I just have so much fun "slapping" the oils around until it looks right!  One other technique that I use, after all paint, washes and pin washes are on ,are many clear coats to " bury " the decals that are used , with many micro-mesh sandings in- between. The decal option would not stand up to that treatment too well. There is just so much subtle detail on the WNW kits too, that I would hate to loose all that under decal sheets also.
Offline KANiles
« Reply #17 on: February 10, 2013, 09:23:04 PM »
That is really very nice, not only the Albatros but the figure and base really set it off.
I'd like to know how you did the base as well.
The base is a piece of 10 x 10 red oak that I sanded, stained and put  little felt feet on to raise it slightly. The goundwork is a standard "plastc wood" filler that spread around into an appropriate outline with some very fine gravel ( model RR supplies) pressed in before dry. Diluted white glue was painted on then for some static grass and  grass clumps placed randomly to break up the unifomity of the static grass. All sprayed with highly thinned earth tones, some dark washes and dry brushing complete the scene.
Offline KANiles
« Reply #18 on: February 10, 2013, 09:58:43 PM »
As the others said, KANiles, that's quite a triumphant introduction. Beautiful bird!
Any chance you've got in-progress photos so that you could post an abbreviated build log? I'd love to see a step-by-step of your weathering and wood work. I'm sure you'd have a captive audience here.
Looking forward to some more,
Lindsay
Lindsay,
I dug up a few more shots. I hope you enjoy, I don't have any in-progress shots of the wood graining. I have a Roland in the stack for my next project. I'm looking at turning that one into a "B" version, and then a full natural wood finish. All that planking!!
The fuselage drain holes are framed by small p/e washers, and the fuel sump extending through one of the covers was added. The cross bracing goes up through the holes in the fuselage and attaches to the fuselage formers under the pilot's seat.
The intake manifold is "asbestos wrapped" with Tamiya tape.
The spark plugs, of which you can see down through the exhaust pipes from each cylinder, are made up of 5 parts each ( I wish I had the Taurus ones!) a stretched tube, brass wire through, a model RR plastic nut and then a brass p/e nut slid over that then a smaller p/e nut slid over the attached spark plug wire.
In this shot, please note the magneto key hanging outside the cockpit in "safe mode."
« Reply #19 on: February 10, 2013, 10:05:16 PM »
Absolutely superb, bottom fuselage details are perfect as is the rest of it.
Offline LindsayT
« Reply #20 on: February 10, 2013, 10:57:14 PM »
That was great.  Thanks for posting those.
LT
Offline Pete Nottingham
« Reply #21 on: February 10, 2013, 11:36:57 PM »
Welcome to the forum KA, a truly stunning build of an Albie, look forward to seeing many more.
Pete.
« Reply #22 on: February 11, 2013, 03:16:46 AM »
  KA,
Absolutely stunning build my friend. The finishing is just excellent,I love the wood works. Very impressive work on your modified Voss figure. Last but not least welcome aboard our outstanding forum.
Offline Jan K
« Reply #23 on: February 11, 2013, 09:03:48 AM »
Interesting camouflage, very well done!
Offline JastaB
« Reply #24 on: April 19, 2013, 05:09:52 AM »
KA
Great modeling job on Strasser's  Jasta 17 Albatros! I' have been laboring on a Jasta 17 Albatros of myself. I hope I can come close to your great modelling achievement. Your build has inspired me to keep slogging along!
Keep up the good work!
Tim
-Sören-
« Reply #25 on: April 19, 2013, 05:18:11 AM »
Your Albatros is one of the nicest which I have seen. Very well done!
« Reply #26 on: April 19, 2013, 08:54:39 AM »
Fabulous woodwork effect!
Offline Vickers
« Reply #27 on: April 19, 2013, 01:20:02 PM »
That is one beautiful Albatros from nose to tail. Excellent wood tone and weathering, and such a striking lovely scheme.  May I ask what brand of paint and colors you used on the upper camoflage? I have some Xtracolor tins for the greens and mauve, but have not had an opportunity to try them. Your camoflage colors look really great!
Offline KrzysiekK
« Reply #28 on: April 19, 2013, 04:58:32 PM »
B&W picture is outstanding!!
regards
K
« Reply #29 on: April 20, 2013, 02:10:07 PM »
Thanks for the additional close up shots. They really show off the detail, paint and weathering work youve put into it!!
