Author Topic: AMC DH.9 Spetsai (1/32, Wingnut Wings)  (Read 23336 times)
Re: AMC DH.9 Spetsai (1/32, Wingnut Wings)
« Reply #45 on: March 12, 2024, 04:19:28 AM »
Thank you  :)
A small step, perhaps, but done with your usual sense of fine craftsmanship.
I was friends with the late Leo Opdycke from WWI Aero magazine, who built a 1:1 Bristol Scout in his basement over a period of about ten years. I asked him how he managed to do it once and he said “I made sure I did something on it every day. Sometimes it was just cutting out a rib or drilling a hole in a fitting, but I always managed to do something.”
And just think, the best part is that you won’t have to knock a hole in your basement wall in order to get the D.H. out like he did with his plane!
Good points, David.
I indeed tend to do at least a small bit every day. It is also because of my addiction. If I do not spend some time a day at my bench I become anxious...
So here are some recent steps. The colouring has started at the undersides. Self made masks are at work. There will be some small retouches required around the rib tapes, but it works fine overall.
And here are the decals which arrived exactly today from LMDecals to replace the apparently wrong-coloured and some wrong-shaped kit decals.
Offline acewwi
« Reply #46 on: March 12, 2024, 06:51:28 AM »
I like it
 :-* Spyros
« Reply #47 on: March 12, 2024, 06:52:59 AM »
Yay, more masking for the people! Those rib tapes really are a nuisance when masking, but this looks good!
/F
« Reply #48 on: March 12, 2024, 10:00:14 AM »
You’re a braver man than I am, PrzemoL. No way I’d attempt masking like that… but it looks gorgeous.
DV
Online NigelR
« Reply #49 on: March 12, 2024, 06:54:25 PM »
Wow, this is going to be very colourful! Great work with the masking, a few touch ups will have it looking superb. Excellent research on this one as well.
« Reply #50 on: March 12, 2024, 10:17:04 PM »
Superb work!  :o :o :o
« Reply #51 on: March 13, 2024, 05:51:57 AM »
Thank you very much for your kind words.
The retouches were straightforward. And first LMDecals on - they are easy to place, conform to the rib tapes almost without any pressure, very highly recommended.
Offline acewwi
« Reply #52 on: March 13, 2024, 06:46:15 AM »
 8) 8) 8)
Spyros
« Reply #53 on: March 13, 2024, 07:33:35 AM »
That is a truly spectacular masking job Prze, bravo!
« Reply #54 on: March 13, 2024, 09:26:11 AM »
[/img]
Hi Przemol,
I took a look at LM Decals and the don't seem to make 1:32nd scale decals normally.
Closest are !:35th.
Were your decals a special order?
« Reply #55 on: March 13, 2024, 04:52:08 PM »
[/img]
Hi Przemol,
Closest are !:35th.
Mike, they have LMX series which are printed on order in any scale. Mine is LMX0032 set but without the blue arrow decal which was for earlier Spetsai scheme. I decided to skip it to reduce the cost which depends on the decal area. It is an advantage of that series, you can pick up what you really need.
Offline acewwi
« Reply #56 on: March 13, 2024, 10:25:35 PM »
Przem,
what color did you use for the linen and red?
Spyros
« Reply #57 on: March 13, 2024, 11:53:26 PM »
Superb work, Prze. Not sure how I've missed this one before.
Lovely stuff
« Reply #58 on: March 14, 2024, 02:10:32 AM »
Thank you, everyone.
Przem,
Spyros
Linen is Pactra A112 Mid Stone, red is Vallejo RLM23 red. It is all going to be postshaded along the rib tapes with beige.
Also note, that the WB in my mobile phone camera is not perfect.
Offline statz
« Reply #59 on: March 14, 2024, 08:46:11 AM »
Fantastic work PrzemoL! I 've seen that the roundels on LMDecals do not have the white circle which is present in WnW decals (like the  RAF ones). Is this considered to be more accurate in case of Greek Navy?
