Author Topic: 1:32 Matchbox SS100 Jaguar  (Read 23502 times)
Re: 1:32 Matchbox SS100 Jaguar
« Reply #45 on: July 08, 2024, 11:35:50 PM »
I really don't have words!
« Reply #46 on: July 21, 2024, 10:03:29 PM »
Thanks Dutch!
C'mon Rick, that's not like you!  ;)
Right then. After multiple episodes of "prime, fill, sand, repeat" I think I've finally reached a state with the front wings that I'm happy with. They have been widened at the front 15mm to make them run straight all the way from front to back, and the curves on the front ends have been adjusted to be as equal as I can get them, with the apex in the right place relative to the wheels.
Having just checked after the latest repaint, there's still a small area inside the right wing front that needs a little more smoothing off, but other than that it's OK.
I also primed the seats to get a better idea of how they looked and see if I needed to do any more work on the design.
I've found some pics of a car with seat backs that had a slight curve, so I think I'll go with these now.
Certainly a big improvement over the kit seats!
Onwards!
Thanks for looking in folks!
« Reply #47 on: July 31, 2024, 10:19:28 PM »
Just catching up. Outstanding work!!
« Reply #48 on: December 10, 2024, 04:26:59 AM »
Blimey, over 4 months have passed apparently!
Ooops!
In my defence, along with a loss of mojo, a lovely lady has entered my life and takes up a lot of what used to be my modelling time, although she fully supports my hobby, so that's a plus!
So what have I been doing ? The answer is, quite a lot of 3d designing, test printing, tweaking designs, reprinting, etc.
Most of this work has been in the front wing/suspension area. The kit has no braces for the front wings, or friction dampers, so those had to be done.
These are the braces:
The trick here was to get the curve right! I started by looking a little more closely at the inner wings where they meet the chassis and realised that the moulded bodywork was too rounded at that point. Problem solved simply enough by attacking the inner wings with a scalpel blade and paring it back to a) give a sharper edge, and b) take the edge back to meet the chassis rails. Then a piece of solder was pressed into the wing to give me the correct shape. I took a photo of that against a pair of rulers. The pic was imported to Fusion as a canvas to give me a reference to work from.
[/url]
The basic design...
That was printed to check the fit, adjusted as necessary, and detail added. I had to reduce the length by a couple of mm but the curve was good first time. This pic also shows how much I removed from the inner wings to take them back to the chassis rails and square them off.
The final version looks like this
One further issue I noted was that the kit moulded front springs are flat across the top instead of curving downwards. After measuring everything and realising that the springs are pretty close to the correct thickness and the axle is at the correct height, I decided to accept the kit springs as I don't want to get into issues with the ride height (it's correct as it is).
After printing the wing braces, the next item to tackle was the friction shocks.
Since I had no size references, I decided the best way to go was to cut a paper mock up, try it for size, adjust it, then take a pic against a ruler and import as a canvas in the same way as I did for the braces.
It was pretty small!
The design was pretty straight forward.
Printing revealed that the two legs are not the same length so that was adjusted, and they were reprinted.
There is also a small linkage between the front crossmember and the damper attached to the rear of the wing brace, so I decided to adjust the front crossmember and reprint it. I also adjusted the front brake drums slightly to lower the actuating arms and reprinted those too.
A test fit of the new front end parts was satisfactory!
While I was on a roll I decided to go ahead and print the steering linkages. I don't have any pics that show the fitting to the left brake drum so I had a best guess.
The connection to the steering box was deliberately made too long, that will be adjusted later, but the fit and angles are, I think, OK.
After that little lot, I looked at the steering wheel mounting and realised that the dashboard was wrong.
The moulded recess where the steering column mounts should not be there!
So I snipped it out with a pair of snips. Bad move!
Oh well! Nothing for it then other than to design and print a replacement dashboard!
I managed to remove the part without damaging the bodywork, photographed it, and imported as a canvas to draw around.
Some small tweaks were required to the left edge, and I enhanced the dial bevels a little, giving me this...
Sometimes it helps to be clumsy with the snips! I think that's a big improvement!
While in that area I decide to do the grab handle for the passenger.
I seem to have forgotten to take a pic of the printed handle, but they have come out nicely!
I have since painted the new parts and will update soon. The next step will be to get some bodywork colour on the undersides of the wings and running boards before fitting the chassis and new parts.
Stay tuned, I promise to update again within 3 months!
Thanks for looking in!
Offline hsmed
« Reply #49 on: December 10, 2024, 05:24:44 PM »
This build is getting out of control - in a very good way 👍 So interesting and inspiring to follow. I simply have to learn 3D-drawing....among many other techniques 😊
« Reply #50 on: December 10, 2024, 07:45:54 PM »
There is a lot of madness on this thread, most of it involving 3D! Amazing stuff.....
Offline DaddyO
« Reply #51 on: December 10, 2024, 09:42:30 PM »
Nice work on the dash Ian (and everything else)
ps - If you could do something similar to your dash but about 1200 long I could use it in mine  ;)
« Reply #52 on: December 11, 2024, 12:11:53 PM »
The more I see, the more I feel I should learn CAD. Beautiful work Ian!
« Reply #53 on: December 19, 2024, 02:33:36 AM »
Continuing to be Gobsmacked by your work on this one! No one will recognize this as the kit it started out as  8)
« Reply #54 on: January 27, 2025, 07:57:12 PM »
Less than 2 months - I'm getting better!
Thanks to all for your patience and support!
Still, even after 2 months I don't have much to show. A trip home for Christmas and New Year and a busy work schedule combine to ensure that. However, I haven't been totally idle. Design has been completed on replacement door trim panels.
Since I removed the sides of the rear cockpit tub and replaced them with plastic card the kit panels wouldn't fit even if they had been accurate because the kit tub sides extend forward of the rear of the doors! I'm not sure why, but that's the way it is.
This is what I came up with. Photos show slightly different arrangements for fasteners, etc, so I decided on one I prefer and ran with it.
and after a quick disclosing coat of Tamiya white...
I think those will work! I now need to design a replacement for the gearbox tunnel as it should be higher at the front where the gearlever is mounted. I have already added the kit rear shelf parts and filled the gaps left by widening the tub, and that has also been painted white to see if any further work is required.
That will hopefully complete the interior parts needed (except the steering wheel) so I should be able to start getting some final paint colours on it soon!
Offline Allan31
« Reply #55 on: January 28, 2025, 08:06:20 AM »
Yum....amazing.
« Reply #56 on: February 07, 2025, 10:10:31 PM »
Thanks Allan!
As a special treat you now get an update LESS THAN 1 MONTH after the last one!
I didn't bother to design a new gearbox tunnel - it just didn't seem to be worth the effort. Especially when there's Milliput!
Once cured, it was sanded to shape...
I think that will work, and so much quicker than designing and printing it!
So on with the paint then!
First up was the BRG (Tamiya X5) on the underside/interior.
A quick check of the fit and to make sure I didn't miss any areas that will show, and all looks good!
I made up some trim panels for the scuttle to match those on the doors thickness-wise, (so 0.5mm sheet) and then some Vallejo leather was "thrown" at it all (including the inside of the scuttle not included in the new panels).
The side panels got a coat of satin clear, and I think the carpets need a little more texture, so I've ordered some flocking powder to try that.
I'm not too worried about a top-notch paint finish on the underside, but I did polish up the large flat areas a little to remove any irregularities.
That's it for now. Next up will be detail painting on the door trim panels and painting the upper body surfaces. I had originally thought about darkening the X5 a little, as I did on the 1:12 Bentley, but I'm glad I didn't as it seems quite dark enough and I'm very pleased with the colour. The dashboard is also coming along and has also received a coat of BRG with the instruments masked off. I plan on  punching out masks for the inside and outside of the dials to paint the bezels, and we'll see if that works soon! Decals received for those too so it should start progressing fairly quickly now.
Except I still need to lace the wheels.....
See you soon, and thanks for looking in!
« Reply #57 on: February 09, 2025, 01:06:01 AM »
All incredible!!
« Reply #58 on: February 28, 2025, 10:28:17 PM »
Thanks Steve!
Dashboard finished. The large dials are a little small but they'll do.
and the exterior has been painted. First coats...
and the final coats done
That last shot was during the final polishing. It's not perfect, but I'm more than happy with the finish.
The interior was finished with flocking powder. Recommended by @81-er and duly ordered!
which was then fitted to the finished body.
That was when I remembered that I hadn't yet fitted the foot pedals or gear lever. Oh well, nothing like making life harder for yhourself!
and for some strange reason I thought it would be a good idea to fit the door trim panels, even though it will be weeks before they're needed.
b****r!
I guess that will need to be done again then!
So that's where it sits as of this afternoon. I may just leave it a while longer so I don't ruin the rest of the paintwork!
« Reply #59 on: March 13, 2025, 12:11:06 AM »
You have broken down the parts, added amazing details, and Now it is beginning to look like an Automobile! Lovely work!
