Author Topic: Macchi M.5 in 1/144  (Read 6476 times)
Offline torbiorn
Re: Macchi M.5 in 1/144
« Reply #15 on: September 23, 2023, 03:16:15 AM »
I knew I was in for a treat when I saw the thread title. The M5 is one of favourites and the model is simply mindblowing.
Not a sliver of silvering on the decals either. I’m out of superlatives  :-X
« Reply #16 on: September 23, 2023, 11:51:42 PM »
Magnificent piece of art!  This is impressive on so many levels but I’m particularly interested in your fabric effect. You have perfected a look I can barely get in my preferred 1/72 scale!   Always a pleasure seeing your work.
All the best,
Tim
Offline William Adair
« Reply #17 on: September 24, 2023, 10:09:41 AM »
Thank you everybody for such kind words! I'm glad the extra work that went into it paid off. The kit is very accurate in outline, although it does have a very grainy texture due to the limitations of the 3D-printed material. The easiest solution was to file all the external details off, smooth everything down, and then reapply the details by hand. The struts were all replaced too.
I think it was the 12x piece engine mount that nearly broke me. I did three versions before getting it correct.  :'(
Tim, I'm glad you liked the CDL. I sprayed a lightened version of Mr.Color 45 'Sail Color' on first. Then masked off each rib tape and lightly sprayed the rest of the exposed wing with a thin mist coat of straight Sail Colour to contrast it. I think next time however I will start with a white basecoat, rather than a grey primer to try to suggest the slight illumination you get from a semi-opaque wing.
Offline davec
« Reply #18 on: September 24, 2023, 09:27:28 PM »
The model came out beautifully.
Offline Flamingo
« Reply #19 on: September 26, 2023, 05:50:13 PM »
Wow, that would be a terrific model in any scalel! But in 144th it's out of this world.
The printed parts on the last photo do not look very promising, requiring a lot of cleaning up.
Remind me of the rivets 50 years ago. ;D
Greetings joachim
jets are for kids
« Reply #20 on: September 28, 2023, 11:38:06 AM »
1/144? No way. No. That can't be true.
WOW!!
Offline NinetythirdLiberator
« Reply #21 on: October 04, 2023, 02:20:14 PM »
Agree with Zac.  No way.  Where did you get the huge match box/stick?
Stunning.
Dan
« Reply #22 on: October 04, 2023, 09:39:00 PM »
Incredible work, William. I would have never thought this was 1/144 scale.
Offline osterkamp
« Reply #23 on: October 14, 2023, 07:00:37 AM »
awesome work,a true masterpiece ...difficult to find the words
Offline Gene K
« Reply #24 on: November 05, 2023, 12:38:53 AM »
Limitations of the 3D-printed material? I think it's a limitation of the printer that was used. Better/more equipment wouldn't have that grainy "texture".
Great job to produce such a beautiful display.
Gene K
Offline Brad Cancian
    • Brad's Models
« Reply #25 on: November 05, 2023, 02:21:21 PM »
That's it, I give up, nothing left for me to do but chew on paintbrushes in the corner, rocking slowly backwards and forwards... brilliant work!  ;D
BC
« Reply #26 on: November 06, 2023, 02:36:58 AM »
My brushes are already gnawed down to nubs, Brad :)
If only it were possible to set this gem alongside Mike N's new HPH build when it's done, what a contrast that would be!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #27 on: December 12, 2023, 06:14:56 PM »
Wow pure magic! I would struggle to build this in 1/32  ;D
//Ben - @AngryJazz_Models
