Author Topic: 1/24 Spitfire Mk Ia Airfix 1970 boxing  (Read 17159 times)
Re: 1/24 Spitfire Mk Ia Airfix 1970 boxing
« Reply #45 on: August 18, 2023, 08:24:17 AM »
Some scarily brilliant work and a huge amount knowledge you are pouring into this project. It's going to be so beautiful!
« Reply #46 on: August 27, 2023, 02:17:29 PM »
Thanks Richie
Trial assembly -- learned a few things! but rudder bar and elevator control column both are functional...
« Reply #47 on: August 27, 2023, 07:16:04 PM »
It is simply amazing what can be achieved with this 3D printing technology: provided that one has the time, patience and skill to use it!
Another wonderful, (and mind blowing), update!
« Reply #48 on: August 27, 2023, 10:44:10 PM »
Great detail, but how are you going to detail paint it?
« Reply #49 on: August 27, 2023, 11:58:41 PM »
Have to figure out how to put it all together first. Once it’s worked out, I’ll remake a production version (these are low res, fast prints) to be painted before assembly per usual practice…
« Reply #50 on: August 28, 2023, 10:42:07 AM »
a little more progress.
« Reply #51 on: August 28, 2023, 05:05:15 PM »
:o you could've fooled me! Wow!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #52 on: August 28, 2023, 05:46:52 PM »
Just keep getting impressed!
Also dont know how you get so perfect prints. My prints are usually not this clean. My latest print of a Vickers seat was not good enough, backrest was too soft/thin and the part was bulging out.
I have a ABS / flex resin I mixed, but I think I have to try a better suited resin for this task  :)
//Ben - @AngryJazz_Models
« Reply #53 on: August 28, 2023, 10:39:13 PM »
ABS is probably not the best starting point for detail parts (although should be strong!). My go-to is Phrozen Aqua 8K mixed with Siraya Tenacious at 9:1. Beyond that it's usually a matter of getting exposure and lift timing right. A good test model helps. Ameralabs has a great calibration test .stl file you can grab for free: https://ameralabs.com/blog/3d-printer-calibration-part/
« Reply #54 on: August 28, 2023, 10:43:53 PM »
yup, the stuff shown above was all done @ 50um layer height. Final versions will be printed at 20um, the prints just take much longer, but the layer lines and staircasing are virtually invisible.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #55 on: August 28, 2023, 11:44:11 PM »
Thank you Tony!
Yes its very strong! Need to be throwing it to break the part. Had some accidents with other resins being to brittle and snap in half.
I usually go with Cones of Calibration, they are very easy to read. Interesting with the lift timing - have to read more about it.
I have some Phrozen Aqua 4k, maybe I should retry the print. Its a fun learning experience.
In any case, thanks for the tips. I really enjoy following the build evolve  :)
« Reply #56 on: August 28, 2023, 11:51:57 PM »
Whatever works! The Ameralabs "town" test piece is free for the price of giving them an email address. So far I have not been bombarded with marketing spam from them. Anyway the little town test will really give your printer a workout -- if you can print all of the details on it successfully, you will know you have it locked in for making detail parts for your models.
« Reply #57 on: August 29, 2023, 01:46:30 PM »
Incredible. Thanks for explaining!
