Author Topic: WnW 1/32 Fokker E.IV "Oswald Boelke"  (Read 9027 times)
Re: WnW 1/32 Fokker E.IV "Oswald Boelke"
« Reply #15 on: July 12, 2023, 10:28:13 PM »
Beautiful workmanship. Love the sworl aluminum effect especially. And the wood, and the motor... well, pretty much everything, when it comes right down to it.
Great idea about the separate work areas... my Mom used to be into folk art, and stenciled trays and furniture with traditional bronze powders that were similar to the metallic powder here. We're still finding traces of the stuff at the old house forty years later.
Dave V.
« Reply #16 on: July 13, 2023, 06:08:42 AM »
Thanks Rick, Prze, Dave, Zac and Richie - your comments are appreciated!
The fuselage had to be trimmed down near the front to accommodate the different side panels for the prototype - provided in the kit with large, flat etched metal parts. Lining these up for cyano glue to adhere them was tricky, but I used small chunks of styrene rod in the locating holes to help.
When cementing the fuselage halves together I needed to spend quite a while trying to eliminate the seam down the spine using several sessions of putty and sanding. Initial paintwork on the fuselage shows the large white panels for Boelke's national crosses, and a bit of pre-shadow for the framework.
« Reply #17 on: July 13, 2023, 06:30:05 AM »
Excellent!  :o
« Reply #18 on: July 13, 2023, 06:43:24 AM »
Hi Greg,
Good to see you tackling the earlier Eindecker of Boelcke.
This is promising to be a great build,
« Reply #19 on: July 14, 2023, 09:30:54 PM »
Quick and Beautiful work Gary!
« Reply #20 on: July 14, 2023, 11:45:32 PM »
It’s shaping up very nicely!
« Reply #21 on: July 14, 2023, 11:50:10 PM »
More modelling loveliness! Is it my imagination or has the standard of work on show on the forum gone through the roof recently?
« Reply #22 on: July 15, 2023, 01:23:31 AM »
Ditto all the above !
« Reply #23 on: July 17, 2023, 04:04:11 AM »
Thanks to all for the encouraging words!
Ed - I remember meeting you over by Ken's model at the show in Omaha, when you and the guys voted it "Best WW1 Aircraft" back in 2017. Luckily I took quite a few photos of that model which has helped me through this build.
These are some progress photos taken after some of the decals had been applied and a bit of weathering added to the fuselage. One of the most difficult steps was to adapt the MG.08's to point forward without the severe upward angle of the three guns in the first prototype. Some surgery was required.
« Reply #24 on: July 17, 2023, 04:13:00 AM »
WOW! That is Gorgeous painting Gary!
« Reply #25 on: July 18, 2023, 07:17:52 AM »
What Rick said! 👏👏👏
« Reply #26 on: July 20, 2023, 12:34:05 AM »
Rick and Richie - thanks  :)
One of the points of research on this aircraft was whether it had a compass in the starboard wing. The first prototype 122/15 did not originally, but Boelke's possibly could have. Ken Nyles model which I referenced did have the compass, but I was unable to contact him to ask about his reference for that. Since Boelke's 123/15 had been modified for service, and to removing the compass would invariably leave an ugly mark on the wing (considering my previous experience in such procedures) I decided to leave it on.
I spent a fair bit of time on the upper and lower surfaces of the wings and elevator to give them a shadow of the framework, but most of it got airbrushed into oblivion after all of the colour had been applied. I did add some oil and dirt staining after the fact near the wing roots.
The last photo shows the beginning of the rigging and control lines being added to the lower fuselage.
After laying down some dark brown lines they were masked using strips of Tamiya tape - used from a previous build.
A light spray of XF-22 was applied, after which the tape was removed and the rest of the colour filled in.
The completed starboard wing after painting, gloss coat, decalling and some dark staining added.
After gluing the wings in place, the cement was allowed to dry as the wings were set so as not to droop. Afterwards they were dead straight.
For the rigging and control lines, I used EZ-Line and a combination of different turnbuckles. For the elevator controls, here are Gaspatch 1/48 resin turnbuckles.
« Reply #27 on: July 20, 2023, 06:04:34 PM »
Glad you got the wings to sit level, this was my first 1/32 WW1 kit and my wings sagged in the most comical fashion! I love your oil staining!
« Reply #28 on: July 20, 2023, 10:51:58 PM »
Breathtaking work Gary!  I’m using your post as reference for my current project. I like the scheme you chose and the turned metal looks amazing!
All the best,
Tim
« Reply #29 on: July 21, 2023, 12:28:48 AM »
I think I already used Gorgeous Paintwork so I will just say WOW!
