Author Topic: CSM Bristol Scout C: and Roden Sopwith 1 and 1/2 Strutter 43 sq. RFC  (Read 46566 times)
Re: CSM Bristol Scout C: and Roden Sopwith 1 and 1/2 Strutter 43 sq. RFC
« Reply #105 on: August 22, 2023, 09:10:51 AM »
Nicely done!
Thanks Andreas!
Good progress here despite having to redo those roundels. All that CDL is a bit daunting...... ;)
A little more paint work done on the Scout. Upper rib tapes painted a lighter CDL. Should look good after a wash is applied to the edges of the tapes. I also did another layer on the underside "See Through" prior to overpainting. I was really pleased until I realized the roundels were a bit too far outboard. Oh well, good practice  :-[
At least you painted the rings in the right colour order, unlike me! But as you say, it's all good practice. If you are going to strip the wing entirely (which I had to do), maybe try your CDL overspray first to see how it looks over the roundels and rib tapes on the underside?
Yep, at least the colors were in the right order.  ::)  So I have done a repaint on the lower surface of the upper wing. First though, we have the Masks for the Strutter . Thanks Fredrik, they look Awesome!
and the Very Subtle repaint of the undersides see through.
In real life the roundels are "Just" visible as are the ribs and spars. If I do another CDL see through thing I will be a bit more daring !
« Last Edit: August 22, 2023, 09:17:28 AM by RAGIII »
« Reply #106 on: August 25, 2023, 09:07:40 AM »
A little more progress on the Scout: All major painting and decaling has been completed. Now for weathering and touch up!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #107 on: August 25, 2023, 03:31:25 PM »
Really starting to come together! Looking really nice  ;D
//Ben - @AngryJazz_Models
« Reply #108 on: August 25, 2023, 05:58:48 PM »
This is coming together really well, excellent progress.
« Reply #109 on: August 27, 2023, 03:33:22 AM »
Thanks for the comments!
Thanks Nigel!
« Reply #110 on: August 27, 2023, 07:10:35 AM »
Beautiful work RAGman, she really is looking the part!!
« Reply #111 on: August 28, 2023, 07:53:50 AM »
Thanks Zac. Todays progress was a bit of weathering and mounting the upper wing.
and the gear is mounted:
« Reply #112 on: August 28, 2023, 06:38:53 PM »
Looking really good. It looks like it's all gone together relatively trouble free, these are great kits to build.
« Reply #113 on: August 28, 2023, 07:43:19 PM »
Looking great, Rick. You make me want to get mine going too. I'm impressed by your ability to keep two plates spinning in the air at the same time, something I fail at!.
« Reply #114 on: August 28, 2023, 09:33:29 PM »
Nice work, Rick.  Won't be long until the Scout is done.  What's your impression of the molded wing rib tapes, now that you have paint on the wings?
« Reply #115 on: August 29, 2023, 02:40:52 AM »
Your Scout is looking lovely Rick, especislly the oil staining. The kit seems to go together really well too.
« Reply #116 on: August 29, 2023, 04:33:54 AM »
Thanks Nigel. It has gone together well....lets hope it stays together  8)
Thanks Sandy! Multiple planes spinning sometimes causes disaster  :o I actually have an Off topic build going also!
Thanks Ken. Still a way to go but it is getting closer. As for the Rib Tapes, I think they are too pronounced for scale. That being said I feel the same way about WNW kits  :-X My opinion is Rib Tapes are the "New" Starving cow syndrome. JMHO,
Thanks Richie. I am making use of the photos provided in the instructions. Still some more layers to add.
« Reply #117 on: August 29, 2023, 06:25:42 AM »
Catching up with progress Rick. I am very impressed indeed with the shadow effect of the roundels under the wings - they look just right to me.
The Scout is an impressive model and was quite a small aircraft: if I ever get to scraatch one in the True Scale I will need to remember just how small they were.
« Reply #118 on: August 31, 2023, 01:39:36 AM »
The Scout is an impressive model and was quite a small aircraft: if I ever get to scratch one in the True Scale I will need to remember just how small they were.
Thanks Stephen! I would love to see you do one!
« Reply #119 on: August 31, 2023, 02:56:59 AM »
Looking terrific RAGIII.  I like the weathering and choice of scheme.
