Author Topic: Lukgraph Hanriot HD-1 and HD-2  (Read 9817 times)
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
Re: Lukgraph Hanriot HD-1 and HD-2
« Reply #15 on: July 06, 2023, 06:15:10 PM »
For further inspiration to build a Hanriot, have a look these hi-res images covering TVAL's original, restored Hanriot HD1:
https://jamesfahey.smugmug.com/Hanriot-HD1/
Happy Modelling
James Fahey
Offline Eric Armstrong
  • Expectation is a prison
« Reply #16 on: July 07, 2023, 05:01:57 AM »
Really nice photos.  I had no idea how close the air intakes for the carburetor and the fuel tank were to the pilot.  It's practically in his lap!
Honor Necessity
« Reply #17 on: July 07, 2023, 05:55:48 AM »
James,
 Thanks for the pictures.
Is this the Hanriot that came over from the RAF museum Hendon?
Offline Pup7309
« Reply #18 on: July 07, 2023, 06:55:19 PM »
 :) CSM  ;Hanriot HD1 and Lukgraph HD2 - we live in good times
‘Not all who wander are lost‘
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #19 on: July 08, 2023, 12:44:24 PM »
James,
Yes it is Bob. TVAL sent across an Albatros DVa, an RE8 and a Sopwith Snipe (non-flyable) and in return received a Farman F40 (which needed restoration), the Hanriot (which didn't need too much done to become flyable again) and a very decrepit Sopwith 1 1/2 Strutter. Not sure if there was any more involved in the swap, maybe some parts etc
Happy Modelling
James Fahey
« Reply #20 on: July 13, 2023, 06:55:36 AM »
Final renders of the Hanriot HD-1 and HD-2 float in 1:32 scale (there will also be a HD-2 wheeled version).
Offline Naimbs
« Reply #21 on: July 14, 2023, 06:50:10 PM »
Hi,
You'll have to watch out for the carburettor outlet on the sides of the Hanriot HD.2 hood (I'm not sure if I'm wrong about the function of these tube outlets).
It was not positioned in the same place as the Hanriot HD.1.
Eduard had made the same mistake.
Arnaud
« Reply #22 on: July 14, 2023, 07:07:15 PM »
Hi,
Arnaud
Offline Naimbs
« Reply #23 on: July 14, 2023, 07:17:02 PM »
Hi,
Arnaud
Hello Mike,
« Reply #24 on: July 14, 2023, 09:37:08 PM »
Hi Arnaud,
I should have stated why I posted the photograph  ;)
It was to show the carburettor air intake position, as you correctly pointed out  :)
« Reply #25 on: July 15, 2023, 07:43:37 AM »
Gosh that looks pretty.
Offline jeroen_R90S
« Reply #26 on: July 15, 2023, 04:35:50 PM »
Regarding the HD-2, that large hatch looks different from the HD-1 as well.
The renders look nice, although I freely admit I just can't warm up to the Hanriot... I am really happy for those that have been waiting for a long time for a model of this aircraft!
Jeroen
« Reply #27 on: August 31, 2023, 11:23:20 PM »
Hanriots HD.1/HD.2 - now available for pre-order
HD.1 (Le Rhone 9J engine)
https://lukgraph.pl/en_GB/p/Hanriot-HD.1-132-Pre-order/241
HD.2 Float version (Clerget 9B engine)
https://lukgraph.pl/.../Hanriot-HD.2-FLOAT-132-Pre-order/244
HD.2 wheels version (Clerget 9B engine)
https://lukgraph.pl/en_GB/p/Hanriot-HD.2-132-Pre-order/242
Kit-set contains:
Resin Casting Parts:
Fuselage, wings (steel wire reinforced), horizontal and vertical fins, ailerons, tail wings, floats (HD2)
3D printed parts:
Full Interior, propeller, guns (2 pcs.), undercarriage.
All struts, ABS resin printed with holes to easier connect parts with wire.
3D printed parts packed in an additional box to ensure maximum protection.
- photo-etched parts (over 100 pcs.)
- steel  wire to connect wings (1.2mm) and copper wires (0.5, 0.3mm)
- Windscreen - PE+film
- Decals 8 schemes for HD.1
- Decals 5 schemes for HD.2 wheel version
- Decals 4 schemes for HD.2 Float
- Colored instructions
« Reply #28 on: September 01, 2023, 01:10:06 AM »
Beautifully done by Lukgraph.  Will wait to see what CSM offers as resin is not really my thing.  All the best to Lukgraph.
« Reply #29 on: September 06, 2023, 10:36:03 AM »
Is it too early to write to Santa? I have, after all, been a good boy  ;D
I'm very excited to see these kits in the wild and on the forum.
