Author Topic: Halberstadt CL.II  (Read 4540 times)
Re: Halberstadt CL.II
« Reply #15 on: April 13, 2023, 01:42:47 AM »
Ps
The pictures of the BFW version all appear to be dark wood? The profile shows a light wood oak type finish, but I guess that’s just artistic licence?
If I do go down the wood fuselage route - I’d be torn between decals and oils, the decals can look great obviously, but in all honesty, when I see pictures of wooden fuselages - it’s very hard to see any wood effect per se, it looks more like the modelling oils to my eye? What do you reckon?
Hi Guy,
Personally I prefer oils to decals.
I think decals look overstated with heavy grain and knots.
Also some look more like polished furniture wood than aircraft plywood's.
As you say, even at 1:32nd scale, wood grain is barely visible.
I feel the same about nail lines, which after market versions can make an aircraft look more like it's been built at a ship yard.
The sugestion of these effects is I think better than trying to 'accurately' model them,
« Reply #16 on: April 13, 2023, 02:23:11 AM »
Thanks Mike,
Yes, that’s my thinking too really, and it makes it easier too!
« Reply #17 on: April 14, 2023, 04:49:56 PM »
Ps
Like so much (not only in modeling  :)  ) I think it’s a matter of taste. I personally love to experiment how to achieve a “wooden” finish. I used both in the past, decals (always on clear carrier film) and Oils. I think to achieve a convincing wooden finish, post- and preshading, or better: playing with different color shades, is much more important than wood grain. I normally use several shades of “smoke” (e. g. Mr hobby’s) and tinted clears (orange and yellow, sometimes some red).
I am completely with Mike, often the wood grain on decals looks exaggerated. This comes, I’d say, mainly from a bad choice of decals by the specific modeler, as there are many decals on the market that show just very subtle graining. A problem with decals can be the presence of printing dots, which are especially visible when photographed with a macro-objective. I think the clues with decals are: 1. Never use decals printed on white decal paper (no preshading possible!) 2. Always choose carefully and have a bigger selection of decals to choose from, 3. use carefully tinted clear and/or oils to avoid the appearance of printing dots. You als can tone down wood grain which appears too exaggerated by over spraying it with a diluted version of the base color.
A problem with oils can be that it sometimes doesn’t look “right”. It doesn’t look like wood grain but just like what it is: smeared paint. Therefore I personally use only a very very tiny amount of oil color that has I “rubb” into the surface with a stiff brush rather than “streaking” it. I seal the surface with gloss clear before.
One thing I am still not sure about are PE spray stencils showing wood grain. A finish that was done with these quickly looks over exaggerated I am afraid. But perhaps I just need more practice. The wood grain, however, often looks more coarse and not as fine as done with oils or decals.
Best regards
« Reply #18 on: April 14, 2023, 06:09:19 PM »
Thanks Andreas,
Yes, I agree with all you’ve said, I too, have used decals to good effect but I’m also convinced by subtle oils too. I think it comes down to the skill of the builder!
I have a slight preference to oils, just because in macro, it’s hard to eliminate every edge of every decal to perfection, but I may well experiment or go with the ‘standard’ factory stipple which I know I can achieve to look realistic.
But in the hands of an expert, wood is hard to beat!
« Last Edit: April 15, 2023, 07:15:16 PM by Gisbod »
« Reply #19 on: April 29, 2023, 03:30:11 AM »
As always I am looking forward to seeing more!
