Author Topic: wnw sopwith pup RNAS  (Read 24657 times)
Offline Epeeman
Re: wnw sopwith pup RNAS
« Reply #75 on: April 02, 2013, 01:37:59 AM »
Coming along nicely, Michael.
I meant to ask earlier, how did you get on with the lower wing installation?  I understand from some threads I've read that this seems to be an area of tricky fit?
Offline dirk
« Reply #76 on: April 02, 2013, 07:58:45 AM »
Hi Michael,
beautiful work, especially on the weathering on the fuselage. So sorry that I missed your work until now,
Dirk
Offline Pete Nottingham
« Reply #77 on: April 02, 2013, 08:37:56 AM »
Hi Michael;
Looking good now, as regards the rigging, if a you are using monofilament fishing line, to get a wire tight, use a pin heated in a candle flame and hold it about 1 to 2 mm from the line, the line should spring tight, but be careful or you will melt through the line, before you try on the model, try gluing a piece of line between some sprue with just a little slack in it and try the hot pin on that.
Pete.
« Reply #78 on: April 02, 2013, 09:37:12 AM »
You're doing great work with the rigging Michael.
To pull lines taut, I use forceps which I clip onto the excess piece of line. I can easily apply tension by gently pulling the forceps or allowing it to hang down so the weight of the tool applies the tension.
I clip my excess line with a cuticle clipper. As it's like pliers, it works very well.
Offline michael
« Reply #79 on: April 02, 2013, 06:52:48 PM »
Thanks for the kind words and tips everyone i will take them onboard  :)
Dave - yea i had problems with the fitting of the wing/cockpit area, just some sanding down though nothing real major.
Pete that to me sounds a scary procedure - my face would be a picture if i melted the rigging  :'( you would think the ilne would expand when hot, but i never was any good at science. cheers Pete  :)
cheers
michael
« Reply #80 on: April 02, 2013, 11:53:38 PM »
  Michael,
Any of the above mentioned techniques should work well my friend. That being said you could default to drilling through the lower wing and pulling the thread through. You can hold the line by hand or weight until secured with super glue. The downside is the repairs require after.
« Reply #81 on: April 03, 2013, 02:29:18 AM »
I think your rigging looks great, Michael!  Tight enough, to my eye.  Pete's suggestion about using heat is the way I'd go about tightening up any sagging lines, if you really feel it's necessary.  I use wooden matches, though.  Probably a bit more risky in tight spaces.  I light a match then blow it out.  While it is still smoking, I hold the match under the line and and let the smoke drift up to the line.  Not too close.  I use the smoke to indicate where the heat is going.  You have to use a new match for each line you are doing.  Whichever method you use, like Pete said, experiment first.
« Reply #82 on: April 03, 2013, 09:24:08 PM »
Bud, if you prefer the wooden match method, you could always re-light the match from a candle.
Pete.
« Reply #83 on: April 03, 2013, 09:39:30 PM »
I find one of the easiest ways to tension the lines is to use a small soldering iron. Let the soldering iron get nice and hot then hold it under the line you want to tension, move the iron up and down the line a few times being very careful not to touch the line, a few seconds is all that is needed. Dont hold the soldering iron in one spot either, it will melt the line very quickly. A little bit of practice and you will find that adding tension to a slack line is very simple.
Offline Jan K
« Reply #84 on: April 03, 2013, 10:16:27 PM »
Nice work. I hope the ailerons are not fixed yet, they are supposed to work opposite way - one side up, the other side down.
(Excuse my clumsy English, please.)
Jan
Offline michael
« Reply #85 on: April 04, 2013, 01:22:05 AM »
Cheers Jan
woops i did not know that about the ailerons  :-[
but no worries i fixed them on with fuse wire, so they can be put right  :)
and your English is perfect no need for excuses
many thanks
michael
« Reply #86 on: April 04, 2013, 06:33:02 AM »
The rigging looks very consistant and taut. I light a toothpick to tighten lines but Des' idea sounds the best - most control and consistant heat.
Offline Jan K
« Reply #87 on: April 05, 2013, 09:29:12 AM »
I use a regular soldering gun, it seems to be an easy way to me. Just be careful to approach the line from the right side -  as the line tightens quite fast it is quite easy to underestimate the distance and to destroy the line by touching it with the gun tip.
(shrinking shown by the blue arrow)
« Last Edit: April 05, 2013, 09:40:18 AM by Jan K »
« Reply #88 on: April 05, 2013, 11:56:54 PM »
I have to agree with Jan, using the hot pin method I always heat the underside of the line, however reading the method Des uses, I think I might give that a try.
Pete.
« Reply #89 on: April 06, 2013, 09:11:55 AM »
I use a miniature soldering iron too, but be careful as it's easy to carelessly touch the barrel on a wing with dire results.
That 'oops' took some fixin'!
