Author Topic: A load of old French Tripe in the Garden!  (Read 4607 times)
Offline xmald
Re: A load of old French Tripe in the Garden!
« Reply #15 on: January 17, 2013, 07:48:23 PM »
Simply great, but the weathering of the bottom is outstanding!
Best regards
Filip
Offline drdave
« Reply #16 on: January 17, 2013, 08:23:39 PM »
Thanks mate.
I sprayed light coats of gunze oil and smoke over the dirtiest areas and copied Ray Rimmell using a post it note moved along the under fuselage as a mask to put muck where the formers are.
Then I dry sponged polyscale mud  on with a scrap of sponge
 Finally a tamiya small qtip soaked in cellulose thinners was used to focally  wipe bits away. I Also brushed on dollops of oil and streaked them in the airflow direction.
The effects are used less and less as you move away from the under engine.
Key point is study a photo and use focal point weathering rather than global effects.
