Author Topic: Airco DH2, Eduard 1/48, Upd 16.5.22 Finished  (Read 25157 times)
Re: Airco DH2, Eduard 1/48, Upd 17.3.22 Wings
« Reply #15 on: March 18, 2022, 07:51:39 AM »
Beautiful work Frank, the shadow effect is lovely! Fine work.
if you wanted, you could likely sell these, perhaps start a "side hustle" as a strut merchant...? 8)
Some time ago I already thought about selling wooden air screws but I'm to slow with manual work. So nobody would pay that work.
Finally, I decided not to do any commercial model work until the kits in my huge stash are all built. 8)
I have to admit my idea was partially to help you financially, but also for folk like me without the skill/patience/will to do it themselves  ;D
Nice to see the DH2 is such a popular subject here lately (Rick, Alexis, DaveB, William).
That's because it's so cool! I agree that it's been wonderful to have so many "De Havillands" (as I believe the Germans called them?) on the go.
Offline hrcoleman66
« Reply #16 on: March 18, 2022, 09:38:48 AM »
Wow!
How did I miss this?  I have both versions of the Eduard DH2 in my stash...  1/72 and 1/48.   I'm going to be making notes!
Hugh
« Reply #17 on: March 18, 2022, 05:13:11 PM »
« Last Edit: May 31, 2022, 01:45:19 AM by Bughunter »
Airco DH2, Eduard 1/48, Upd 18.3.22 Rotary and air screw
« Reply #18 on: March 18, 2022, 05:17:08 PM »
« Last Edit: May 31, 2022, 01:45:26 AM by Bughunter »
Re: Airco DH2, Eduard 1/48, Upd 18.3.22 Rotary and airscrew
« Reply #19 on: March 18, 2022, 08:25:57 PM »
Frank, engine and prop look first rate!
« Reply #20 on: March 18, 2022, 09:24:41 PM »
I like the prop, Frank.  You have probably mentioned this somewhere, but I could not find it - what type of wood did you use for the prop?  Is it the same as you used for the struts?
« Reply #21 on: March 19, 2022, 05:06:21 AM »
Another gem is taking shape. Very interesting struts building technique.
« Reply #22 on: March 19, 2022, 05:36:14 AM »
Well done Frank - a REAL aeroplane at last!!!!
The propellor is another of your masterpieces and will look the part with the engine which is also first class. I am just pleased that I do not intend to build a DH 2 because I could never reach your standard.
« Reply #23 on: March 19, 2022, 05:59:17 AM »
Frank, while I'm also very impressed with your Mono the side-on photo of the prop literally took my breath away - it's utterly gorgeous!!! See, this is another item I'd gladly buy from you!
I'm very excited to see your next update.
« Reply #24 on: March 19, 2022, 06:56:02 AM »
Thank you Gaz, Ken, Giuseppe, Stephen and Zac!
Your comments sound like you are well entertained here 8)
Ken this is pear. Struts and airscrew are both pear veneer. I tried to mix the veneer for the airscrew. You can see that some layers looks different. This comes from different sheets, but all is pear. The struts are unpainted, the airscrew has primer, wood lacquer and some clear paint with airbrush applied.
It will be a shame to paint the struts grey. But the kit struts are too flexible for me. Then I wanted to make them from squeezed brass tube but is hard to file away a lot and close the joint with solder to reach the bellied shape.
Since the original ones are made from wood it is much easier and faster to sand them from wood.
Zac, I think the next update can show the tail booms :D
« Reply #25 on: March 20, 2022, 03:55:12 AM »
I am catching up on posts today as my vacation has interrupted My regular post's. I can only say that I am glad you held off until my WNW DH2 build was finished  8) As always you are showing us what skills and hard work can accomplish.
Airco DH2, Eduard 1/48, Upd 19.3.22 Tail booms
« Reply #26 on: March 20, 2022, 04:26:03 AM »
« Last Edit: May 31, 2022, 01:45:34 AM by Bughunter »
Re: Airco DH2, Eduard 1/48, Upd 19.3.22 Tail booms
« Reply #27 on: March 20, 2022, 04:40:45 AM »
Superb tail booms Frank. This really is going to be a very fine example of a real aeroplane.
« Reply #28 on: March 20, 2022, 05:26:58 AM »
Those Booms are amazing! Typical of your outstanding work.
« Reply #29 on: March 20, 2022, 06:23:07 AM »
Great to see you working on that one, Frank. I know your stripped down DH-2 and I am keen on seeing a dressed one off your bench.
