Author Topic: Another Nostalgia Build - 1/48 Monogram Bf-109G-10  (Read 11703 times)
Re: Another Nostalgia Build - 1/48 Monogram Bf-109G-10
« Reply #15 on: December 10, 2021, 11:51:02 PM »
Getting ready for paint!! Looks great. Decided on a JG? I always like JG5. Black and yellow DOTR bands and yellow trimmed black numbers.
Online Brad Cancian
    • Brad's Models
« Reply #16 on: December 12, 2021, 08:06:06 AM »
Thanks Steve - probably going to go something different (but only slightly) - probably Hungarian or ROA; a bit bland for some but different enough to be slightly interesting :)
BC
« Reply #17 on: December 12, 2021, 01:31:54 PM »
That's why there's chocolate and vanilla. You pick what you like!
Online Brad Cancian
    • Brad's Models
« Reply #18 on: December 16, 2021, 06:34:45 PM »
Basic colours are now on. I forgot how much 'fun' it is painting Luftwaffe colours... far from great but, well, good enough.
BC
« Last Edit: December 16, 2021, 07:05:45 PM by Brad Cancian »
« Reply #19 on: December 17, 2021, 01:39:55 AM »
   Wonderful results on the panel pre-shading Brad, just a spectacular realistic finish. Yet another fine example of what can be done with a vintage Kit, lovely work!
« Reply #20 on: December 17, 2021, 02:56:07 AM »
Brad, my friend, I can only echo Lance's comments.  Your paintwork is
just great and your preshading is first-rate!  Wunderbar!
Online Brad Cancian
    • Brad's Models
« Reply #21 on: December 17, 2021, 05:41:57 AM »
Thanks Lance and Ernie! :) Next challenge will be masking and spraying the markings.
BC
Online Brad Cancian
    • Brad's Models
« Reply #22 on: December 18, 2021, 06:12:54 PM »
I've now sprayed some national markings. I also had a go at masking and spraying the aircraft number.
Still needs a couple of minor touch ups but good enough. Next up, a clear coat and decals, before I start getting into some weathering.
BC
« Reply #23 on: December 19, 2021, 02:22:58 AM »
Excellent work!! The pre shade worked well. Looking forward to the weathering.
« Reply #24 on: December 19, 2021, 02:25:17 AM »
BTW, noticed the third hand device holding the model. What's the base look like that will hold the entire length of the model by the nose and not tip?
Online Brad Cancian
    • Brad's Models
« Reply #25 on: December 19, 2021, 06:21:52 PM »
Thanks Steve!
Here's my little stand:
The base is quite heavy. I picked this up probably 15 years ago (if I remember correctly it also came with a magnifying glass, which is long gone).
I sometimes try to use this to paint with; especially if I am going into long paint sessions (like with this model).
Cheers!
BC
Offline Whiteknuckles
« Reply #26 on: December 19, 2021, 07:30:59 PM »
Brad, can you quickly run through your process of getting the canopy to look so great please.
(I have a rough idea but it would be good to get details).
Eternal Apprentice
Online Brad Cancian
    • Brad's Models
« Reply #27 on: December 20, 2021, 08:29:39 AM »
Hi Andrew - nothing too complicated, just used the Tamiya polishing compounds (course, fine and finish, in that order) with a q-tip, washing with water and using clean q-tips between each grade of polish.
Cheers!
BC
« Reply #28 on: December 20, 2021, 08:45:13 AM »
Cheers!
BC
Thanks Brad, it's very effective!
Eternal Apprentice
Online Brad Cancian
    • Brad's Models
« Reply #29 on: December 21, 2021, 03:09:42 PM »
Well this is about as far as i'm going to get on her this year; about to hit the road for Christmas and New Year. Stencils are now on, and a little bit of panel line shading with sprayed on thinned black / brown.
Was hoping to get it done before the end of year, but there was just too much to get done in the end. Such is life, as they say!
BC
