Author Topic: Royal Aircraft Factory Fe2b in 1/144  (Read 24465 times)
Re: Royal Aircraft Factory Fe2b in 1/144
« Reply #60 on: September 05, 2021, 05:25:38 AM »
I agree with Sandy - cutting out white surrounds in this scale borders on maniacal behaviour!
Who am I to argue with such wisdom  ;D Incredible!!
« Reply #61 on: September 06, 2021, 12:14:31 AM »
I have the same problem with the tail numbers for a future project, but I cannot assume that I'm able to cut decals that clean.
So I draw the numbers to cut mask with the plotter, but it failed. This was too small, the knife pulled the small pieces off the backing paper  >:(
I need another solution, but for now I try to avoid to cut the decals by hand.
Offline William Adair
« Reply #62 on: September 07, 2021, 01:50:59 PM »
I think it’s worth giving it a try.  A brand new scalpel blade and a firm but slightly yielding cutting surface seems to do the trick.  I put mine on an old plastic gift card and used it as a cutting board.
Working on channeling my inner Sir Peter Jackson at the moment:
« Reply #63 on: September 09, 2021, 06:21:51 PM »
Well, I am also in love with Fee. But I would not dare build it in 144th scale even from a kit if it existed.
And I have no idea how I missed this thread. To call it spectacular is far too little. I am in awe for your achievements. Every step of this build is amazingly planned and executed. Needless to say, I will now be following it to the glorious end.
« Reply #64 on: September 10, 2021, 06:14:44 AM »
Oh William you are both mad and utterly brilliant at the same time! Perfect white surrounds cut to tiny little numbers. Utterly worth it, all those incredible little details all combine to make this the special little gem it is turning out to be. You're still a bit mad though.... 😀
« Reply #65 on: September 11, 2021, 03:05:58 PM »
Oh I don't know about mad.  In truth I think you've got to be leaning more towards ruthless deliberation a lot of the time.  Or idiot persistence...  Definitely one of the two!
Here's the week's progress for this, errr... week.
I made some bomb racks from styrene strip and glued these in place with PVA.  A bit more rigging was added to the undercarriage and out from the lower wing to the pulleys near the ailerons.  The wheels got a tiny wash of grotty coloured oils to pick them out as well.  I also made the nacelle grab handle and wingtip skids from 0.15mm wire and glued them in place.  I still need to make the control horns and add a couple of last wires before the undersides are done.   I'm really looking forward to signing off on that bit so I don't have to keep flipping the thing over onto its back.  I'm quickly running out of places to pick it up from!
I turned it over again for a Captain Cook (look).  I'm happy with the sense of weight in the tyres.  It makes the whole thing look a bit more meaty and bigger than it truly is.
I also added another dozen bracing wires to the booms.  That's the last of them there, save for the control wires that will go in later.  I think I'll forever associate those wires with Doctor Who season 11-12, which I've been binge streaming in the background while all this has been going on  :P
I also received my 1917 shilling in the mail today, so I couldn't resist a couple of vanity shots  ;D
« Reply #66 on: September 12, 2021, 04:52:02 AM »
Lost for words. Will stunning do?
« Reply #67 on: September 12, 2021, 05:27:49 AM »
Lost for words too, I'm in shock!
Offline torbiorn
« Reply #68 on: September 12, 2021, 05:40:01 AM »
Yeah, to quote someone, this sort of thing makes me consider taking up knitting instead. :o
Top notch!
« Reply #69 on: September 12, 2021, 06:54:14 AM »
SUPERB!!!!
« Reply #70 on: September 12, 2021, 06:36:12 PM »
Unbelievable -  still can't picture this being only 1/144 scale - mindblowing ...........
What material did you use for rigging?
« Reply #71 on: September 15, 2021, 03:49:04 AM »
Remarkable craftsmanship  :)
« Reply #72 on: September 15, 2021, 07:39:00 PM »
Thank you again!  Almost there now.  I can hardly believe it.   :D
Dave, I use 0.05mm nichrome wire for the rigging.  There's a picture of the stuff at the bottom of page 2.  I roll it out flat and trim it to size and it holds its shape well.  It pays to be careful using it though, to ensure that no tiny offcuts are left lying around.  You wouldn't want specks of it getting swept off the desk and landing in your lap...  Having a splinter of that near invisible wire lodged near where the sun don't shine would not be fun!   ;D
Offline torbiorn
« Reply #73 on: September 16, 2021, 12:04:54 AM »
The spool looks like crazy wire company wires, which I have tried to order from. Unfortunately they seem only to deliver woth courier outside the UK (40 GBP).
« Reply #74 on: September 16, 2021, 03:49:28 AM »
