Author Topic: 1:32nd scale Mosca-Bystritsky MB bis fighter  (Read 13133 times)
Re: 1:32nd scale Mosca-Bystritsky MB bis fighter
« Reply #45 on: July 07, 2021, 06:28:37 AM »
The linen decals have now been applied.
White primed base coat, polished then pre-shaded with 'thinned 'Tamiya' Smoke (X19).
The decals were cut from a sheet of the ‘Aviattic’ Clear Doped Linen (CDL) bleached (ATT32044).
The Russian cockard decals supplied in the kit are ink jet printed and not 'cookie' cut.
Typical of these type of decals, that are very easily surface damaged, before or after application.
If possible, I'll probably airbrush the cockards using templates - we'll see.
« Reply #46 on: July 09, 2021, 01:20:08 AM »
Looking good Mike!
« Reply #47 on: July 09, 2021, 04:09:29 AM »
Very good results with the Aviattic decals, Mike . They look like airbrushed on the surface.
Bye Manni
« Reply #48 on: July 10, 2021, 10:02:34 PM »
I thought of replacing the Russian markings using masks and airbrushing the three colours.
However, aligning concentric circles accurately and without over spray was always going to be tricky.
Therefore I decide to print the decals instead, using an Inkjet printer, not Laser.
This is the process I used:
Create the decal in Photoshop Pro software or similar.
Test print on paper to check size.
NOTE:  As the centre of the Russian markings are white, I used Mr. Decal White decal paper, to avoid the surface below the applied decal showing through too much.
Place the decal paper into the printer feeder tray with the glossy side facing up.
Adjust the printer setting for the paper to ‘Premium Gloss Photo paper’ or equivalent and set the print resolution to high.
Print the decal sheet.
Leave the printed decal sheet for several hours to allow the ink to fully dry.
NOTE: During the following step, do not apply too much sealer over the decals, as it can flood the surface and when dry cause a ’fish eye’ effect. Also spray at a shallow angle to the decal sheet, not at 90  degrees and at a distance of 12 inches or more away. Wear a respirator and spray in a well ventilated area.
Apply a several light coats of sealer over the decals, using such as ’Krylon’ Acryli-Quik acrylic lacquer or similar.
Allow each coat to thoroughly dry before applying another coat.
Check decals are fully covered and sealed with the clear coat.
NOTE: If using White decal paper, make sure you cut around the decals as close to the outline as possible, to avoid the white decal paper showing at the edges.
Carefully cut as close as possible around the decal to remove it from the backing sheet.
Make sure the model surface is smooth and has clear gloss acrylic coat, such as ’Alclad' Aqua Gloss 600 or similar.
NOTE:  Adding PVA adhesive (white glue) to the water, used to detach the decal from its backing paper, can improve adhesion of the decal to the model and help prevent ‘silvering’ (trapped air) under the decal. Also take care not to ‘stretch’ the decals when removing the water.
Apply the decals to the model as for standard water slide decals.
« Reply #49 on: July 10, 2021, 10:26:07 PM »
Thanks for explaining that process  so clearly Mike.
This is someting I am definitely going to try!
« Reply #50 on: July 10, 2021, 10:47:28 PM »
The markings really bring the aircraft to life Mike! My Favorite part of any build  8)
« Reply #51 on: July 10, 2021, 11:16:48 PM »
Top job on the decals Mike. Getting rid of the white edge is never easy.
« Reply #52 on: July 11, 2021, 12:15:10 AM »
The markings look splendid Mike!  What sort of printer do you use?  Thanks.
Best regards,
« Reply #53 on: July 11, 2021, 12:43:14 AM »
Best regards,
Hi Bob,
Nothing fancy - just a standard Canon IP7250 using aftermarket ink cartridges.
Offline Fvdm
« Reply #54 on: July 12, 2021, 02:28:19 AM »
The markings look great Mike. The tip of using PVA glue in the water is one I'll remember
« Reply #55 on: July 12, 2021, 02:36:44 AM »
You create here again a wonderful model of a rarely seen aircraft!
The aftermarket parts and brass replacement will enhance the kit to a complete different level.
« Reply #56 on: July 12, 2021, 08:08:51 PM »
The weathering has been applied and sealed.
'Flory Models' Dark Dirt and Grime fine clay washes.
Now onto the pre-rigging before construction,
Offline Europapete
« Reply #57 on: July 12, 2021, 09:58:03 PM »
Just caught up with this one Mike, it's coming along great. Well done on the CDL, you get better results with every build. Regards, Pete in RI
« Reply #58 on: July 13, 2021, 04:58:43 AM »
A bit of progress.
The carburettor air intakes, engine, landing gear and wheels have been fitted.
Also the tail unit, consisting of upper and lower rudders, tail plane, control horns and rudder/elevator control lines.
Finally the tail skid assembly including the 'bungee' type suspension cords.
The next step is to pre-rig the wing warping control lines and bracing wires before the wings are fitted,
« Last Edit: July 13, 2021, 08:55:42 AM by Mike 'Sandbagger' Norris »
« Reply #59 on: July 13, 2021, 02:35:38 PM »
Really great looking results!
I like your efforts with the decals as well.
