Author Topic: AMC DH.2 - Wingnut Wings 1/32  (Read 14867 times)
Offline Rafael Berlin
  • e^(i*pi)+1 = 0
Re: AMC DH.2 - Wingnut Wings 1/32
« Reply #15 on: May 18, 2021, 04:54:16 AM »
Thank you so much to all of you for your kind words. I'm very happy that you like it so much.  :)
Hopefully tomorrow I will send some pics from the motor.
Best regards
Rafael
« Reply #16 on: May 18, 2021, 10:07:37 PM »
Awesome work, Rafael.
  • e^(i*pi)+1 = 0
« Reply #17 on: May 19, 2021, 04:28:47 AM »
Hello everybody,
as promised here are the pics of the motor. Please tell me, if it is too detailed. I have the feeling that most construction reports show more or less final results from major steps and not the way to the result.
But OK. This is how the WingnutWings part looks like. Missing material, but 2 spark plugs per cylinder in order to be prepared for different motor variants (Oberursel U1 has spark plugs at the rear side).
20201204_182650_resized by Rafael Berlin, auf Flickr
I decided to try the Taurusmodels Gnôme Monosoupape, which is a model of its own with approximately 90 resin parts
20200825_164752 by Rafael Berlin, auf Flickr
Direct comparison...
20201204_195822_resized by Rafael Berlin, auf Flickr
But take one step back. The cylinders were primed glossy black. Afterwards they only have been sprayed with Alclad 2 Aluminium more or less directly from above and from the under side. So the gaps between the ribs stay dark.
20201209_173636 by Rafael Berlin, auf Flickr
Excellent fit of the parts
20201210_122016_resized by Rafael Berlin, auf Flickr
Now for the valves. Valves, rocker arms etc are all made from individual parts. You don't have spare parts, so you have to be very careful.
2 valves are displayed open, others clothed
20201210_170759_resized by Rafael Berlin, auf Flickr
The rocker arms are extremely fragile.
20201210_173023_resized by Rafael Berlin, auf Flickr
My method to cut them off the sprue: First cut it off with lot of the sprue material. Afterwards make several orthogonal cuts. Now you can cut off the remaining sprue in little squares
20201210_173825_resized by Rafael Berlin, auf Flickr
Assembly. They clip together and are movable. I painted them black and drybrushed them. The color kind of fixes them.
20201211_165214_resized by Rafael Berlin, auf Flickr
Here are the spark plugs. Later I changed the black color to white, because of a photography in the WnW instruction. Both variants seemed to be common, but I like the contrast a little bit more.
20201214_165311_resized by Rafael Berlin, auf Flickr
Cylinders with valves (one open, the other closed) and white spark plugs.
20201221_132325_resized by Rafael Berlin, auf Flickr
Some parts are really tiny as for example the following one. I lost 2 of them and it cost literally hours, to find them again. Lukasz, please add some spare parts to future models!!!
20201225_142508_resized by Rafael Berlin, auf Flickr
It directly fits on the rocker arm. Movable!
aufgeklipst by Rafael Berlin, auf Flickr
More small parts. Put the silver joint heads into gold openings. Then assembly. Decals are from the WnW kit.
20201221_134013_resized by Rafael Berlin, auf Flickr
20201221_140053_resized by Rafael Berlin, auf Flickr
20201221_173135_resized by Rafael Berlin, auf Flickr
For assembly with the aircraft the WnW shaft has to be cut ("muss weg"). The radius at the shown place is to large ("Radius zu groß"). Needs some adjustment to fit to the Taurus.
Bauteil Bearbeitung by Rafael Berlin, auf Flickr
Modified shaft glued to the Taurus motor:
20201222_121813_resized by Rafael Berlin, auf Flickr
Put in all cylinders
20201225_211724_resized by Rafael Berlin, auf Flickr
As already mentioned, everything is still movable (or removable). Rocker arm removed, rod glued to the tiny joint part.
20201227_121102_resized by Rafael Berlin, auf Flickr
Put it back into place...
20201227_120036_resized by Rafael Berlin, auf Flickr
... and glue it to the other joint:
20201227_120314_resized by Rafael Berlin, auf Flickr
Several hours later
20201227_183459_resized by Rafael Berlin, auf Flickr
Now for the commutator. Made from bakelite. Ir sprayed first a layer of desert yellow and afterwards a layer of clear orange (both Tamiya). I added some black pigments for the structure.
20201228_161109_resized by Rafael Berlin, auf Flickr
For the electrical connections I did NOT use the parts of the Taurusmodel, but some nickel silver rods 0.2mm from Albion alloys. Afterglueing, they were blackened and afterwards painted with brass color.
20201228_162548_resized by Rafael Berlin, auf Flickr
20201228_171258_resized by Rafael Berlin, auf Flickr
20201228_172349_resized by Rafael Berlin, auf Flickr
Dry assembly:
20201228_173701_resized by Rafael Berlin, auf Flickr
The commutator plate has a nice side (which you have seen) and a not so nice side with some glue points. For the final model I will change it in a way that the unfavourable side faces to the frame and will not be seen in the later airplane.
For wiring I used single wires from an old monitor cable. Wrapped them around a 0.2mm drill and slightly pulled them apart
20201231_172456_resized by Rafael Berlin, auf Flickr
Here are some pictures of the finished taurusmodels Gnôme Monosoupape
20210101_131235 by Rafael Berlin, auf Flickr
20210101_131139 by Rafael Berlin, auf Flickr
20210101_130608 by Rafael Berlin, auf Flickr
20210101_125728 by Rafael Berlin, auf Flickr
Thanks for watching.
Best Regards
Rafael
« Reply #18 on: May 19, 2021, 04:45:30 AM »
That is not too detailed: it is inspiring! That assembly must have taken you hours and cost a great deal in patience. Brilliant modelling.
« Reply #19 on: May 19, 2021, 04:46:33 AM »
You can never have enough detail , all depends how far the rabbit hole you are willing to travel ! Beautiful job on the rotary !
Offline Todd Holaday
« Reply #20 on: May 19, 2021, 06:10:37 AM »
Fantastic work and photos.  Thanks so much for sharing.
« Reply #21 on: May 19, 2021, 06:50:03 AM »
Brilliant, I enjoyed the all the step by step progress details.  That engine is spectacular!
« Reply #22 on: May 19, 2021, 07:05:49 AM »
Okay, it's official now.
I'm going to take up knitting...
This is Champions League modelling. Showing all the construction steps is very helpful, please continue this way!
« Last Edit: May 19, 2021, 06:12:17 PM by Rookie »
« Reply #23 on: May 19, 2021, 04:56:28 PM »
Wow, Rafael. This is mind-blowing. These tiny parts.... incredible. Please go on with your detailed step by step construction thread it could never be too detailed.
Chapeau,
Offline Von Salza
« Reply #24 on: May 19, 2021, 05:16:17 PM »
As for me Your report is perfect and seems to be a guide for beginners, like me.
So, please, don't stop ;)
« Reply #25 on: May 19, 2021, 05:55:13 PM »
Lovely job on that Gnome Mono. But you should try Taurus Clerget engine once. It has almost 300 elements... ;)
« Reply #26 on: May 19, 2021, 06:24:46 PM »
Inspiring stuff, Rafael - you have the patience of a saint.
I'd be doing a "Ballistic Bob" with those millimetric parts I think!
see attached
https://www.youtube.com/watch?v=dbNyGXRp_iE&list=PL34D8A838206B5339&index=6
Offline kkarlsen
« Reply #27 on: May 19, 2021, 09:51:52 PM »
Awesome detailing going on here Rafael, very inspiring!!!
Kent
« Reply #28 on: May 19, 2021, 10:14:20 PM »
Incredible work on all of those TINY details! The paint work looks terrific! I am joining Willem in the Knitting circle...anyone want to buy a WNW DH2  ;D
Offline Matti
« Reply #29 on: May 20, 2021, 03:37:59 AM »
Outstanding detail work.
