Author Topic: Valom 1/144 - "Sopwith F.1 Camel" - Series 'Duels in the sky'  (Read 7138 times)
Mistakes happen , we all make them  ;)
What type of glue are you using ?
Offline Baracca
Dear Alexis I'm using the REvell Contacta glue ... the one with the fine spout
Just a question as to the glue not drying. Did you remove the paint from the surfaces to be glued? This can make a big difference.
I have not tried the Revell glue so can't comment on it . But Rick is right if the paint isn't removed on the gluing surface this can slow down the drying time or just not dry at all . Also the amount of glue you add will slow down the drying time as well .
I can recommend Tamiya glues if you are able to get them . Either their Extra thin in the dark green cap or their quick setting in the light lime green cap which dries faster then the extra thin .
Offline Baracca
Thanks to both of you
It could be the reason of my mistake.
Effectively i painted the piece, then i glue the Seat on mano structure
Offline Baracca
Sopwith Camel valor 1/144
https://imgur.com/a/RwzHFKs
Dear all...please Is there Simeone Who can explain me hot to post Simply image using android smartphone...
In avoiding to post only for this reason
Your little camel is moving along nicely!  I wish I could help you with the photo posting but I download the Photos from My Android to Postimage then upload them here from My Laptop.
Offline Baracca
Thanks RAGIII
I think i started with a medium level of complexity... Others valom kits seems more "smart"
The build of second Camel was mooooore fast
Any suggestion are welcome
Offline Baracca
Offline Beto
Please re-check the location of the undercarriage legs if possible. The front legs should be just under the firewall.
It looks like you figured out how to post good photos! I also think that you should check that landing gear. Could be on reversed, or perhaps just needs to be further forward like stated. All in all looking good!
« Last Edit: May 27, 2021, 02:23:01 AM by RAGIII »
Glad that you figured out on posting photo's .
I really like the work you have done so far both builds are coming along nicely . But I agree with the others . If you are able to remove the landing struts and place the under the fire wall .
Keep up the fine progress and I look forward on your next up-date  :)
Offline Baracca
Thanks guys... Sadly i followed the the images of the instructions provided..but the image on the box it's right.
I decided to mantain them as Is.
But i have more Planes.
And them Will be built Better than these ones.
Im happy .
Thanks all for your help please  go on with them because are so usefull.
Thanks
Offline Baracca
Re: Valom 1/144 - "Sopwith F.1 Camel" - Series 'Duels in the sky'
« Reply #28 on: May 30, 2021, 04:27:09 AM »
« Reply #29 on: May 30, 2021, 12:09:17 PM »
I like it , you are doing well so far  :)
