Author Topic: Eduards Red Baron 1/48  (Read 13105 times)
Re: Eduards Red Baron 1/48
« Reply #15 on: March 26, 2021, 05:39:09 AM »
Good start Alexis (except for breaking the seat support...!), - looks as though this one is going to come together quickly.
« Reply #16 on: March 26, 2021, 07:15:43 AM »
Thanks Gary , I don't recall what I did with the pin . I think I ended up giving it to my brother , He collects pins .
Well Kevin , hope I can keep up with my standards then  ;)
Marc , thanks for the approval  :) Last one I built was a quick build and I have a feeling this will be as well . Already repair the seat support .
Hi Stephen , yup a nice quick easy build ...fingers crossed  ;)
I started with the painting of the dope linen and the cockpit parts which need black . Black basing for the engine is done as well . This is drying as of right now . Pic's will follow once the pit is finished .
« Reply #17 on: March 27, 2021, 06:43:12 AM »
Here is where I'm at this moment with the build . All the cockpit parts have their base coat on the the wood effect is done using pencil crayons , only a top coat of clear yellow was used for paint . With a sealing coat of future with a bit of brown paint was used as a wash and wipe away off the fabric areas with a brush . Engine has it's base coat , set for further weathering .
« Reply #18 on: March 27, 2021, 06:43:33 AM »
« Reply #19 on: March 27, 2021, 07:05:34 AM »
Outstanding start on the pit Alexis! Lovely wood tones! Looking forward to More!!
« Reply #20 on: March 27, 2021, 10:43:28 PM »
Thanks Rick  :)
« Reply #21 on: March 28, 2021, 01:42:49 AM »
Looks good! I like your crayon wood finish.
Offline phil2015
« Reply #22 on: March 28, 2021, 04:35:41 AM »
Whose clear yellow do you use?  I've used both GSI and Tamiya.  Both come out too YELLOW.  Yours has a nice tone.  I'm sure I'm doing something wrong....
« Reply #23 on: March 28, 2021, 04:36:18 AM »
Such a great start, Alexis! I get flashbacks to my build, but yours is better! You are right about the black framework... ATB, Marc.
« Reply #24 on: March 28, 2021, 04:50:15 AM »
Neat work Alexis  ;)
« Reply #25 on: March 28, 2021, 10:07:37 AM »
Thanks guys for the positive comments  :)
Phil , I used Tamiya clear yellow . What helped with the tones is the base shade and the effect of the pencil crayons . For the base I used Tamiya deck tan followed by four different shades of the crayons and used a blending stick over top . I sealed this with two thin coats of Tamiya clear you . 50/50 with their lacquer thinner .
Halves are joined together and there was some fit issues but nothing major . I did end up losing one of the filling caps , but I used have spare PE for this . The lower stitching part was wrapped and didn't sit flush . I used it anyway , sanded it , filled it , sanded some more and will replace this with spare PE from the parts bin . Engine is ready for assembly once the paint has fully dried .
« Reply #26 on: March 28, 2021, 10:08:01 AM »
« Reply #27 on: March 28, 2021, 10:08:24 AM »
« Reply #28 on: March 28, 2021, 10:08:49 AM »
« Reply #29 on: March 28, 2021, 10:09:15 AM »
