Author Topic: Halberstadt CL.II, Mirage 1/48; 20.3.2021 Parabellum - THE END  (Read 65572 times)
Re: Halberstadt Cl.II, Mirage 1/48; 2.2.2021 Engine
« Reply #75 on: February 03, 2021, 06:40:28 AM »
Beautiful Frank!
Offline acewwi
« Reply #76 on: February 03, 2021, 06:57:22 AM »
Just wonderful Frank.
But should if possible even to move the generator backwards into the cover.
Spyros
« Reply #77 on: February 03, 2021, 07:33:36 AM »
Thank you Guy and Spyros!
Hmm, too late.
1. it is glued in place
2. the generator is not be visible on both positions ???
3. as far as I found out both positions are possible.
 Some engines have generator mounts on the crankcase:
I have not found a picture with mounted generator, but here also a WNW model of a D.IIIa (from youtube):
So I think both solutions are possible.
« Reply #78 on: February 03, 2021, 08:17:08 AM »
Still fun, and amazing, to follow!
« Reply #79 on: February 03, 2021, 10:47:21 PM »
Outstanding work on the engine Frank. This one is really moving forward now!
« Reply #80 on: February 03, 2021, 11:25:18 PM »
Coming along wonderfully Frank  8)
« Reply #81 on: February 04, 2021, 02:34:07 AM »
Nice detailing, Frank.
« Reply #82 on: February 04, 2021, 06:03:33 AM »
Superb detailing - especially thos evalve springs.
« Reply #83 on: February 04, 2021, 08:03:43 AM »
Always the same small community here - I can count on you! :) Thank you dear friends!
There is still enough on the ToDo list ...
I got 0.15mm enameled copper wire in red, black and blue to wire a jet model with LEDs (never finished that project either). The blue one lost its color in direct sunlight on the workbench and now looks slightly yellow and blue like steel - I took that one.
Offline ColonelKrypton
« Reply #84 on: February 05, 2021, 04:05:58 AM »
Fabulous as always.
[/quote]
One of my other interests is amateur radio and I build a lot of small transmitters and receivers some of which use very small ferrite toroid cores and wire between 30 and 40 AWG -  0.15mm is about 35AWG. Consequently I have on hand a good supply of this size enamel coated soft copper wire in various colours that I use for all sorts of model detailing, soft, easily cut and formed, very handy.
For those who may not know, this kind of wire is also commonly referred to as magnet wire, not that it is magnetic but it is commonly used for winding electromagnetics and electric motors ( of course ).
It is surprising that your blue wire was effected by sunlight as I have never noted that with the wire I have been using, I will have to look more closely in the future.
cheers, Graham
Offline Fvdm
« Reply #85 on: February 06, 2021, 11:20:26 PM »
Really beautiful Frank. I appreciate al the steps you show us of how it's done. We can learn a lot from this.
Halberstadt Cl.II, Mirage 1/48; 6.2.2021 Question: Splatter
« Reply #86 on: February 07, 2021, 03:15:21 AM »
Thank you very much!
It doesn't have to be the last word, it's just my way. ;)
Graham, here is the copper wire, on the left there is the original blue. Hard to show the real colors with the camera.
And now a question:
Splatter
The kit provides two variants of decals for fuselage.
I'm not sure, if I like this. Only the upper one is an option:
Should look like this:
So I experimented a bit. Painted a piece of plastic in the layout of the middle wing with five colors according to WNW, followed by a splatter painting with very low pressure.
The same piece, just on a white background.
In real it looks a bit different, hard to picture ist like it looks for the naked eye.
What do you think?
Re: Halberstadt Cl.II, Mirage 1/48; 6.2.2021 Question: Splatter
« Reply #87 on: February 07, 2021, 04:03:48 AM »
Better then the decals Frank , looks really good actually  :)
« Reply #88 on: February 07, 2021, 04:16:09 AM »
I agree with Alexis! Besides you know you won't be happy if you don't do it yourself  ::)
Pedja
« Reply #89 on: February 07, 2021, 04:22:33 AM »
Must say that i like it. I would leave this as it is.
