Author Topic: CMK razor saw and handle and sanding stick  (Read 5330 times)
« on: January 04, 2021, 03:08:38 PM »
CMK Razor saw & handle and Sanding Stick
Reviewed by: Dave Wilson
Item:  CMK H1010 Razor saw & handle; H1011 Sanding stick
Price:   Via Special Hobby on-line and quality model retailers. Razor saw & handle 13.80€, saw blades 4.30€, Sanding stick 4.50 €
Review samples kindly provided by Special Hobby at: www.specialhobby.eu
Comment:
Every modeller has their preferred tools to help their builds and Special Hobby have sent samples of two indispensable items for every hobby work bench – a razor saw and sanding stick from their CMK products line.
The razor saw is a rather clever design as it features a plastic handle in two halves between which you can secure a double sided saw blade ( available in different blade grades). The handle and blade is held by screws and provides a remarkably stable and very robust cutting tool.
The handle set comes with a standard double sided blade but CMK also offer Very Smooth and Ultra Smooth grade blades featuring more teeth for finer cutting, which are interchangeable with the standard handle.
I have several fixed blade saws on the bench but the CMK set with its alternate blades has become my ‘go to’ razor saw now.
Equally important in modelling is a quality sanding stick and the CMK sanding stick is really four sanders in one. It’s divided into four grades of sanding surface- two per side- which range from coarse to fine. The stick is finished in a black surface so it can be difficult to see at a glance which sanding surface you are using. As always, check first.
That aside it’s a quality sanding stick and works very well providing a satisfactory result.
VERDICT: Highly Recommended.
Review items kindly provided by Special Hobby.
Please support the businesses that support your Forum.
