Author Topic: WNW Albatros for local IPMS club 'Build Same Kit' competition  (Read 13522 times)
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
Re: WNW Albatros for local IPMS club 'Build Same Kit' competition
« Reply #30 on: May 02, 2012, 01:13:17 PM »
I have discussed the engine access hatch issue with Wingnut Wings and Richard Alexander commented that the placement of the hatch varies between the 160hp engined Albatros and the 180hp engined Albatros
"The kit's draincock cover/hatch was modelled in the correct position for the majority of the kit decal schemes, which are 160hp Daimler-Mercedes D.III powered Albatros D.V.
The draincock on the 180hp D.IIIa engine, which powered almost all Albatros D.Va, is further forward."
. . . which just goes to show how much research WNW do. When the deluxe version of the kit comes out I expect there will be PE hatch covers which can be attached in either position.
Happy Modelling
James Fahey
Offline phs Paddy
« Reply #31 on: May 02, 2012, 10:08:16 PM »
James,
Just a thank you for your thorough research and supporting comments. Good stuff.  :)
Paddy
« Reply #32 on: May 03, 2012, 01:08:29 AM »
James,
Paddy
I'd like to second that, James.  You're our go-to guy for detailed reference photos.
Cheer,
Offline kornbeef
« Reply #33 on: May 03, 2012, 03:21:09 AM »
Yes I noticed a long time back about the access panel under the nose, it sits under the oil pump housing beneath the engine, the rear most panel is for the fuel tank drain offs..  All the research I've done shows it in this location, the basic engine casing never changed and the oil pump was always in the same location I believe.
shows its position internally
Externally (both on a stalled strip down DVa I have sitting on the side.)
Keith
