Author Topic: Fokker Trilogy  (Read 19320 times)
Offline acewwi
Fokker Trilogy
« on: December 08, 2020, 12:59:58 AM »
Αfter a while I open a new topic.
Fokker D.VII (WNW)
Fokker D.VI  (Roden)
Fokker Dr.1  (Meng)
Coming soon.
My heartfelt greetings to all members.
Spyros
Re: Fokker Trilogy
« Reply #1 on: December 08, 2020, 01:41:39 AM »
I am looking forward to your Trilogy! Should be a great thread to watch!
Re: Fokker Trilogy
« Reply #2 on: December 08, 2020, 02:43:40 AM »
This will be an interesting thread - three Fokkers showing variations on a basic theme.
Offline acewwi
Re: Fokker Trilogy
« Reply #3 on: December 08, 2020, 02:43:55 AM »
1. Fokker D.VI, Max Speidel, Jasta 80b, Summer 18
Roden kit plus parts from Meng DR.I, Wingnut Wings Fokker D.VII (fok) and Le Rhone engine.
Spyros
« Last Edit: December 09, 2020, 10:42:17 PM by acewwi »
Offline Fvdm
Re: Fokker Trilogy
« Reply #4 on: December 08, 2020, 08:27:58 AM »
Hey, a D.VI. Great. I will pull up a chair and will follow. Have fun
Re: Fokker Trilogy
« Reply #5 on: December 08, 2020, 01:23:45 PM »
Excellent work on kitbashing those parts. I assume you modified the F1 horizontal tail plane from the Meng kit ? Also the coaming panel from the DVII looks great. When I get ready to build one of these I will have your thread bookmarked for sure!
Offline acewwi
Re: Fokker Trilogy
« Reply #6 on: December 09, 2020, 06:25:23 AM »
Hi  Rick,
yes the tail plane and the rudder come from the pieces for F1 type (Meng)
Spyros
Offline acewwi
Re: Fokker Trilogy
« Reply #7 on: December 10, 2020, 06:04:20 AM »
Introduction
RODEN D.VI is an honest kit for the money. Relatively correct in its dimensions, with sufficient detail for its time (mold of 2005), but with some inaccuracies and shortcomings such as:
-   the span of the axle wing
-   the bogus step on the horizontal tailplane
-   the lack of detail of the cowling
-   the lack of rib tapes in the wings
-   the complete lack of detail at the bottom of the fuselage
The reason for its construction was the purchase of 2 kits of Dr.I of MENG, one for early and one for late type. Because the kit contains all the parts for the construction of both F.I and Dr.I (early and late) there are enough parts that will not be used in the end.
1.1 Preparing the parts
Undercarriage
Horizontal tailplane and Rudder
coming soon
Spyros
Re: Fokker Trilogy
« Reply #8 on: December 10, 2020, 08:06:23 AM »
Thanks for the very clear steps in altering the Extra Meng Parts! Really looking great!
Offline acewwi
Re: Fokker Trilogy
« Reply #9 on: December 11, 2020, 07:51:15 AM »
Hi
Fuselage
The lack of any detail at the bottom of the fuselage in D.VI is obvious. The comparison with the similar section of Meng’s Dr.Ι proves it.
The D.VI fuselage is based on the equivalent of the Dr.I, except for the wing cover, while the wings to D.VII with shorter wingspan.
First remove a 10 mm piece of plastic from the fuselage. From a WNW sprue cut a rectangle measuring 22x17 mm and install 4 Fokker type fasteners which we remove from I27 not use part (WNW Fokker D.VII (fok)) as the similar part of D.VII.
Copy on foil the fuselage seam from the Dr.I.
Make the access panel of the engine subsystems from a 0.15 mm thick sheet. Place a plastic strip on the bottom of the firewall.
to be continued
Spyros
« Last Edit: December 30, 2020, 06:29:11 AM by acewwi »
Re: Fokker Trilogy
« Reply #10 on: December 11, 2020, 11:17:47 PM »
You are doing a remarkable job on updating the DVI kit! On a side note if I used a "Double Edged" razor blade the blood would be pouring from MY fingers  ::)
Offline acewwi
Re: Fokker Trilogy
« Reply #11 on: December 12, 2020, 12:08:50 AM »
Thank you Rick.
I pay a little more attention  ::) ::)
Spyros
Re: Fokker Trilogy
« Reply #12 on: December 12, 2020, 10:59:02 AM »
Nice project you got your self going  :)
Re: Fokker Trilogy
« Reply #13 on: December 13, 2020, 03:00:57 AM »
Some great mix - and - match going on here! And some wonderful ideas I will borrow shamelessly! I do like your problem solving methods, and what a great group of subjects! Regards, Marc.
Offline acewwi
Re: Fokker Trilogy
« Reply #14 on: December 18, 2020, 07:47:23 AM »
Thanks all for the comments.
Continue with the preparation of the parts for the upper fuselage.
and cowling
some dry fit
continue soon with the wings,
Spyros
