Author Topic: What gauge monofilament for 1/72?  (Read 2292 times)
Offline Softscience
« on: November 26, 2020, 04:51:16 AM »
As stated in the title, what gauge monofilament would look nice for 1/72 wiring. Looking around online, the smallest I found was 0.22 mm, but that seems a little on the heavy side.
I've been using nylon thread, for control wires and such, but I have a really hard time getting the floppy threads through small holes, and feel like mono would work better.
Offline Stuart Malone
Re: What gauge monofilament for 1/72?
« Reply #1 on: December 01, 2020, 04:55:45 AM »
Softscience,
My reply to Jim on 1/48th scale rigging contains 1/72nd and 1/32nd scale sizes as well.  Here's a quick link:
https://forum.ww1aircraftmodels.com/index.php?topic=9806.0
Hopefully you can find a cross reference from measured size to fishing line gauge.
Stuart
Offline specialops
« Reply #2 on: December 03, 2020, 09:49:14 PM »
On 1/72 I use Maxima Chameleon 1lb mono filament 0.08mm
hope this is some help.
Tony
Offline Berman
« Reply #3 on: December 03, 2020, 11:52:23 PM »
 Tippet line is a bit more flexible than standard fishing line. This is an advantage when used for rigging.  Can be purchased at fly fishing shops. The size numbers are like drill numbers where a higher number indicates a small diameter. These dimensions are in inches.
 5X is .006
 6X is .005
 7X is .004
 8X is .003
« Reply #4 on: December 04, 2020, 07:42:45 PM »
I use this
It scales out to 4.32mm which is almost bang on for 1:72. You'll need to run it over a permanent marker so you can see it though!
