Author Topic: 1:32nd scale Roden - Nieuport N.28C1  (Read 19252 times)
Re: 1:32nd scale - Nieuport N.28C1
« Reply #30 on: November 19, 2020, 01:34:37 AM »
Quite stunning painting effects, Mike.. we observe and learn ... thank you for the detailed explanations.. Regards, Marc.
« Reply #31 on: November 19, 2020, 09:09:59 AM »
Lovely Camo colors and pattern Mike!
« Reply #32 on: November 20, 2020, 07:32:47 AM »
I've applied the decals to the wing struts and the rudder from the ‘SuperScale’ WW1 Nieuport 28C-1 (MS320243) set.
The pre-moulded lined wrappings around the struts were way to thick.
I sanded them away and replaced them with white 1.5 mm wide white stripes from the ‘Xtradecal’ parallel stripes white (XPS2) set.
Also applied are the wing decals, which are ‘Aviattic’ aged varnish CDL (ATT32094) linen effect decal undersides and Linen Weave Effect (ATT32236) on top surfaces.
The decals are glossy due to the base coat, but will be toned down eventually,
« Last Edit: November 20, 2020, 09:45:38 AM by Mike 'Sandbagger' Norris »
« Reply #33 on: November 20, 2020, 10:32:26 AM »
Excellent progress Mike...and I really Love the fabric decals!
« Reply #34 on: November 20, 2020, 10:50:01 AM »
Stunning results, Mike!  Those linen decals are really amazing.
Offline Dave Brewer
« Reply #35 on: November 20, 2020, 01:53:55 PM »
Looks wonderful Mike,terrific progress.
Dave.
« Reply #36 on: November 20, 2020, 04:34:10 PM »
Great painting and the linen decal effect makes all so realistic.
« Reply #37 on: November 23, 2020, 04:30:06 AM »
Apart from the propeller, all of the decals have now been applied.
Undersides using ‘Aviattic’ aged varnish CDL (ATT32094) over base colours.
Top surfaces 'Aviattic' Linen Weave Effect (ATT32236) over base colours.
Individual marking from the ‘SuperScale’ WW1 Nieuport 28C-1 (MS320243) set.
Final sealing coat of 'Alclad' Light Sheen (ALC-311) lacquer.
Now I'll need apply weathering before adding details, such as the retaining strap for the engine cowl and ring supports for the front of the machine gun cooling jackets.
Then it'll be pre-rigging and start the construction,
« Reply #38 on: November 23, 2020, 10:19:13 AM »
I've applied the 'Flory Models' Dark Dirt fine clay wash.
Most will be removed to leave the desired weathered look,
« Reply #39 on: November 23, 2020, 07:21:47 PM »
Looks horrible...  ;)
But seriously, great progress, as usual Mike. I doubted your claim about OOB build. And I was right  :D
« Reply #40 on: November 23, 2020, 11:53:17 PM »
As always your paint work and use of the Linen decals is Gorgeous Mike! Almost a shame to dirty it up  8)
« Reply #41 on: November 24, 2020, 12:47:32 AM »
Most of the clay wash has been removed to leave subtle dirt weathering.
'AK Interactive' Kerosene wash (AK2039) and Engine Oil (AK2019) applied around filler cap and on underside of fuselage, rear of engine cowl..
'Tamiya' Weather Master Set A (Mud) and Set D (Engine Oil) sponged to the engine cowl, underside of lower wings and fuselage.
Now to create the engine cowl retainer band and forward support rings for both machine guns,
« Reply #42 on: November 24, 2020, 01:04:13 AM »
Excellent weathering Mike!
RAG
« Reply #43 on: November 24, 2020, 04:31:24 AM »
Mike, your attention to detail and ability to work with texture and colour is phenomenal.. This is a Modelling Masterclass! Regards, Marc.
« Reply #44 on: November 25, 2020, 12:07:37 AM »
Just a few tweaks to the fuselage and weapons.
The engine cowl was secured to the fuselage with a metal strap around the rear edge of the cowl.
To represent this strap, I used a strip of ‘Bare-Metal’ Matte Aluminium self-adhesive foil.
This was then covered with 'Flory Models' Dark Dirt clay wash, to dirty it up, then sealed with 'Alclad' Light Sheen lacquer (AL-311).
In-flight the main fuel tank was pressurised by a 'Baden' type venturi, which was connected to the tank by an air pipe.
This was represented by drilling into the venturi and fuselage and adding 0.3 mm 'PlusModels' lead wire.
The wire inside the venturi was painted Brass and the rest with 'Tamiya' Rubber Black (XF85).
Both machine guns had elliptical blast deflectors, fitted below the muzzles and these are not represented on the replacement ’GasPatch’ weapons.
The two machine guns were fixed to a mounting under the breach block and also supported at the fuselage by clamping rings around the front of their cooling jackets.
The blast deflectors were cut and shaped from 0.2 mm thick plastic card and CA glued to the weapons.
The rear gun mounts were made from 0.4 mm and 0.2 mm diameter Nickel-Silver tubes. The front mounts were also pinned to the fuselage with 0.3 mm tube.
The front clamping rings were cut from 0.2 mm thick plastic card and CA glued to the cooling jackets.
« Last Edit: November 25, 2020, 01:26:22 AM by Mike 'Sandbagger' Norris »
