Author Topic: VERTIGO JIGS  (Read 3572 times)
VERTIGO JIGS
« on: October 22, 2020, 01:57:53 AM »
Greetings:  Apparently there is a lot of buzz over jigs.  I just purchased one, haven't got it yet, but it looks promising, from VERTIGO JIGS.  http://www.vertigo-miniatures.com/vertigo/eshop/15-1-JIGS  Check them out.  I have no affiliation with them, just passing on a bit of information.
Offline James
VERTIGO JIGS
« Reply #1 on: October 22, 2020, 02:01:49 AM »
Wow, they look nice. A lot of them. Anyone in particular you recommend?
Axes Grind and Maces Clash
Offline gcn
Re: VERTIGO JIGS
« Reply #2 on: October 22, 2020, 04:03:39 AM »
They do look nice. Looks like another parcel on its way to chez GCN.
I need a grown up to tell me the difference between the evo and basic
Offline Vickers
Re: VERTIGO JIGS
« Reply #3 on: October 22, 2020, 06:10:59 AM »
I have both the monoplane and biplane versions. They're very precise and plenty firm. Be sure to peel off the film prior to assembly- one of mine had blue film and the other clear. On the latter, I couldn't even tell that it had protective film on it until I tried to glue the upright to the base!
Re: VERTIGO JIGS
« Reply #4 on: October 22, 2020, 07:26:59 AM »
I was scoping out FB and found out, after I placed an order in Europe, there is a seller in the U.S.  http://www.umm-usa.com/onlinestore/index.php
Offline petrov27
Re: VERTIGO JIGS
« Reply #5 on: October 22, 2020, 09:40:40 AM »
Yep works very well for my needs also
-Patrick
Offline Berman
Re: VERTIGO JIGS
« Reply #6 on: October 23, 2020, 12:02:13 AM »
 I bought one of these. There is some cementing necessary. I found Gorilla clear glue much better than using epoxy or super glue. The rubber padding strips were applied with Weldwood contact cement.
Offline aircare84
Re: VERTIGO JIGS
« Reply #7 on: October 23, 2020, 06:43:02 AM »
I have been using a LMG jig. Works great. Also bought the biplane add on, but haven't used it yet.
https://www.amazon.com/LMG-BB-01-Airplane-Building-Jig/dp/B086ZY4BHS/ref=sr_1_1?dchild=1&keywords=LMG+model+building+jig&qid=1603399045&sr=8-1
Also, shows up on ebay occasionally.
Offline fruibal
Re: VERTIGO JIGS
« Reply #8 on: October 24, 2020, 06:11:31 AM »
I purchased the Vertigo Jig for 1/32 Biplanes, and I founded it to be nice but made with brittle plastic materials prone to break at any slight hit. Customer Service from Vertigo never sent the replacement part ( one of the holding legs). NO planning to buy anymore from this company and will stick with the plywood jigs, which are sturdier and cheaper
Re: VERTIGO JIGS
« Reply #9 on: October 27, 2020, 09:13:39 AM »
I was scoping out FB and found out, after I placed an order in Europe, there is a seller in the U.S.  http://www.umm-usa.com/onlinestore/index.php.
John at UMM-USA is a great guy, stocks great products. Beware, you'll break your wallet in there.  ;) ;)
WD
