Author Topic: 1/32 WnW 120hp Beardmore engine with a scratch built Airco DH1A attached: anothe  (Read 5023 times)
Online lone modeller
Evening All,
Before WingnutWings disappeared earlier this year I bought one of their excellent 120hp Beardmore engine kits and some Gaspatch wire wheels. I also had some Airscale instrument transfers and HG bezels, so I thought that I might build a de Haviland 1A as there is no kit of this type in 1/32 scale. I cobbled the model from the usual materials for a scratch build: brass bar and rod, plastic strip and card, wood, wire and assorted odds and ends. A fellow modeller provided me with some Eduard mesh for the radiator, (thanks Jim). I used plans from the DataFile number 148. My thanks too to Dennis on Britmodeller for directing me to other plans which enabled me to make a more accurate representation of the cockpit interiors. I found that the engine kit lacked an exhaust pipe and oil tank, so I had to make them and add some extra details such as ignition wires, etc. I also employed lots of smoke and numerous mirrors.
For those who do not know what a DH 1A looked like here is a conversion that I made in 1/72 scale from the Airfix DH 4 some years ago:
I wanted to take some photos outside but the weather broke a few days before I completed the model and it has been too windy since. In addition I have not prepared the base yet so these are of the model as photographed on a neutral base in my house. I also saw that I had not touched in part of the nose after I had taken these photos - this issue has now been dealt with!
I decided to build a strip down model because I frequently read how modellers add large amounts of incredible detail to the interiors of cockpits and fuselages, engines and other parts, and then cover them all up for eternity, never to be seen again. Well I thought that if I am going to spend time adding lots of extra detail, others might like to see it. In addition, with the relatively simple WW1 types which do not have too much internal detail, why not show a little more - such as the whole aircraft structure. So I decided to reveal everything.......
When G. de Haviland left the Royal Aircraft Factory in 1914 to join the Aircraft Manufacturing Company as chief designer he had been working on the FE 1 and BE 2 designs. His first design for his new employer was a two seat tractor biplane, but the War Office wanted a pusher similar to the FE 2. Consequently de Haviland produced a two-seat pusher, the prototype of which was powered by a 70 hp Renault V8 engine. This first flew in January 1915 and an order for 49 machines followed. Called the DH 1 this machine took a long time to get into production, (like all other British aircraft at this time), and it was not adopted by the RFC because the FE 2b had already been ordered in large numbers and had a better overall performance.
The DH 1A was an attempt to improve the performance of the original design by installing a 120 hp Beardmore engine, (the same as powered the FE 2b), with a radiator behind the pilot and a gravity tank under the port upper wing. It was armed with a single Lewis machine gun on a mounting in front of the observer, and one behind: the observer sat in the front cockpit.
About 23 machines were built and delivered to the RFC of which 6 were sent to Palestine to no 14 Sqdn who operated it alongside other types. It was used mainly for escort duties but at least one enemy aircraft was shot down - a Rumpler two-seater. The remainder of the DH 1 and 1A's were sent to home defence squadrons in Britain or to training squadrons where the survivors were finally withdrawn from service in the autumn of 1918.
I have dedicated this post to the memory of our founder as it was he and you who post on this forum who gave me the ideas, inspiration and confidence to try out something different every time I build a new model. Without him and you I would never have dreamed of building something like this. Thanks to all of you for your generous and continuing support.
Thanks for looking.
« Last Edit: October 07, 2020, 10:12:16 PM by lone modeller »
Always enjoy your builds and I must Stephen that this one went rather quick for you . She looks fantastic . I really like the different tones in the woods and those details really set it off !
Whats next ?
Quite the piece of work.  I like your idea of showing off everything rather than cover it all up.  A novel idea and the execution of it is brilliant. Outstanding work and joy to look at.
Online lcarroll
    Well Stephen you've done it again, another superb model and true to form better then those you presented before it! This is a great piece of work and, having followed your progress, didn't come easy! Your patience and improvisation skills really stood out on this one and the consistent improvements your results show are commendable. Great modelling, and a real pleasure to follow your work!
A big WOW! I am in absolute awe!
Inspirational!
Jar dropping masterpiece, Stephen. What a wonderful build!
Wonderful !!
I'm also a fan of such stripdowns, but only build some from a kit. But I would immediately reject the idea of building such a part completely by myself for reasons of time and effort! All the greater is my respect to implement such an idea so perfectly.
And now I will scroll back to view the pictures of this masterpiece again ...
Brilliant doesn't begin to describe your work on this one! I enjoyed following your build and your build is Stunning!!!
Well written text about and beautiful photos of a truly wonderful and unique model!
If you took your inspiration from Des and others on the forum, I dare say that you give plenty of inspiration back.
Offline jeroen_R90S
+1 !!
Thank you everyone who has left such complimentary remarks - they are much appreciated.
Frederik: I really am very grateful to Des for having established this forum where I and others can share our interest in a conflict which for many has been overshadowed by later ones. My personal interest is in early aviation which I know is a minority pastime, but to have so many knowledgeable and skilled individuals writing on this forum and showing all their techniques and superb models is, for me at least, a dream come true. During the time of my earlier incarnation as a modeller there was no such group as this and I modelled very much on my own and had no real idea about what standard of skill I had achieved. If I am able in any way to help others then I am simply giving something back to a very generous community.
Terri: I will be shortly staring something which you have described as rather "steampunk" in the near future. However I can see life looming large in the next couple of weeks, so although I will be returning to the True Scale, progress may be a little slow - as usual!
A fantastic build, Stephen.  I'm glad to see it finished so superbly.  These stripped models allow one to see the level of technology in place a hundred years ago.
I'll be looking forward to your next project!
Thanks Ken.
