Author Topic: Fokker Dr.1 1/32 Roden and maybe more...  (Read 40534 times)
Re: Fokker Dr.1 1/32 Roden and maybe more...
« Reply #180 on: May 19, 2021, 02:42:17 AM »
Thank you Rick, Alexis and Von Salza for the comments! The leather colour is Simply Tamiya Enamel XF-9 Hull red, painted on quite thickly - it seems to settle down with it's own highlights! I'm going to use it more often... Regards, Marc.
« Reply #181 on: May 19, 2021, 03:46:41 AM »
Great work Monty, nearly there! Slow progress much better than no progress.
Offline Fvdm
« Reply #182 on: May 21, 2021, 12:47:52 AM »
Looking good so stay focused.
« Reply #183 on: May 23, 2021, 12:38:02 AM »
Thank You Richie and Ferry for the comments, and yes, I must get moving on the Roden kit! There is no reason now not to turn it into a Triplane, and I used my favourite glue - Micro Krystal Klear! It just seems to work... the engine and cowling demanded to be added and the engine still rotates in the cowling! Another Roden win... Some center section struts need to go on next, and I am making progress on the undercarriage...
Regards, Marc
« Reply #184 on: May 23, 2021, 12:47:27 AM »
Such neat and clean work! Really looks great Marc!
Offline Rafael Berlin
  • e^(i*pi)+1 = 0
« Reply #185 on: May 23, 2021, 05:16:27 AM »
Hi Marc, terrific work! I love the beautiful clean and clourful result and hope for more to come :D
Rafael
« Reply #186 on: May 24, 2021, 12:34:48 AM »
Thank you Rick and Raphael, the encouragement is appreciated... So today I unusually had a few hours free and the Roden model jumped ahead... Here all the kit parts are on, still some paint touch-ups to do and the rigging, but so nice to get a model to this stage! Quite a lot of glue has to dry, my favourite Krystal Klear! The pics are not great, sorry poor light and poor depth of field, will do better in future...
Regards, Marc.
« Reply #187 on: May 24, 2021, 12:50:58 AM »
Looking very impressive all together! Neat and clean assembly and a lovely red as I said previously! You are inching closer to the finish line  ;D
« Reply #188 on: May 24, 2021, 11:44:50 AM »
Second Ricks comments  :)
« Reply #189 on: May 26, 2021, 08:20:33 AM »
Very nice work
« Reply #190 on: May 26, 2021, 08:25:41 AM »
Eye candy! Lovely one, Marc.
« Reply #191 on: May 26, 2021, 08:27:29 AM »
It's looking very nice indeed Marc - looking forward to your completion!
« Reply #192 on: May 26, 2021, 08:05:31 PM »
Beautiful work Marc!
« Reply #193 on: May 26, 2021, 08:28:02 PM »
« Reply #194 on: September 27, 2021, 03:35:31 AM »
I'm pretty sure everyone thought this thread had demised, but there is some progress on the Meng Triplane! And I need to express my thanks to everyone who commented on the Roden kit - I still need to add a few touches and do those final beauty shots! But here are some potos of today's work, a lovely experience to be building again...
Firstly, the lower surface of the middle wing and the two side pieces of the cockpit cover (here painted silver) don't worry that it's a bit rough, it won't show! But the instructions show that the transverse bar that supports the gun butts (part A59) needs to be added first. It's fit is quite secure and precise, and if your cockpit upper parts are broken off or loose, this will help strengthen the entire assembly... Also check at this stage if it fits onto the two dry-fitted fuselage halves, this will save frustration later!
I also did a whole lot of little decals, the instruments that went on well and will look good once I add a bit of clear varnish for the glasses, and the Axial decals on the prop, strangely not supplied by Meng but here taken from a WNW kit. I also started with the PE seat belts, here dry-fitting and bending started, and will be painted before assembly.... Note the cross wires on the rear bulkhead are simply stretched sprue glued in place, smoke 'n mirrors, as Rick says!
Thanks for watching and have fun modelling! Marc
